02-08-2013, 05:37 AM
#616 |
Oddometer: 1,017
you can buy an inverter off amazon for less than $50 , about the size of a good sized wallet. plug it into a cigarette lighter socket and charge all you electronics at once while riding with their ac cords. or overnight, plug in you light power requirements like cell phone. so camped in the woods, you can still charge electrics.
2012 VSTROM ADV 650 |
02-08-2013, 07:47 AM
#617 |
This is Liv'n!!!
Location: Northeast PA, Some... On HIGH ADVENTURE Most!
Oddometer: 1,226
Your local Wallyworld has a Shumaker for 19.99 140watts continuos-280w peak.
Here: http://www.walmart.com/ip/Schumacher...Specifications Or a T/A (or other) Truckstop will stock them too! |
02-08-2013, 08:06 AM
#618 |
aka SoulDreamRider
Oddometer: 491
I don't mind charging while riding, but draining the battery while camping just seems like a bad idea!
I realy love the whole solar power setup!
Am I awake, or am I dreaming? http://advrider.com/forums/showthread.php?t=806962 http://nomadgals-klr650-adventure.blogspot.com/ |
02-08-2013, 08:40 AM
#619 |
I'm with you there. It's not even like it takes up much space, and sometimes I camp for days at a time. I'd rather not have a flat battery. It's kind of like a water filter. If you're going to be near towns all the time, it's not necessary, but if you're not, it's very nice to have.
Ongoing Ride Report: Wherever I May Roam - One Woman Livin' on a DR650 Feyala's Wanderings |
02-08-2013, 02:33 PM
#620 |
Phaneropter
New follower
Have been following your report here and on the blog. Really enjoying it. As in improving massively a windscreen, turning it into a functional work of art. Cool stuff. Noticed a buddha sitting on the handlebar, is it glued on? I also admire the way you've dissected the engine and put back together. Top surgery and nicely documented.
All in all very appreciative of your approach, ie the casual roaming, the many pictures. It is my preferred way too. You might like to know I live near a place called Nederland. It has a population of app. 16 million. ![]() ![]() Some time ago I got interested in solar charging electronics. Investigating the matter cooled down my enthousiasm rapidly. Promising technology but not yet, unless investing in very expensive equipment and uninterrupted direct sunshine. Now you rekindled my interest. As far as the bounds of this thread allow could you elaborate a bit? I would like to know from an actual user whether the more basic, affordable equipment, has become useful in not perfect (as in not perfect sunshine) conditions.
Moriunt omnes pauci vivunt |
02-08-2013, 06:15 PM
#621 |
aka SoulDreamRider
Oddometer: 491
I am pooped! Haha, can I write that?
Anyway, had a long day working on Spirit replacing both drive and rear wheel sprocket. Of course I ran into quite a few glitches, it's turning out to be normal ![]() I had forgotten that I didn't have the socket for my drive wheel nut, so I had my mother in law drive me to AutoZone to get one. Luckily, even though my adjustable wrench said it would be a 26mm socket, I decided to buy a 27mm one too, because I couldn't help but think that I used a 27mm one at Steven's. Sure enough, it needed a 27mm. Also got very lucky in that my in-laws happened to have a metal tube lying around that I was able to use as leverage to take the nut off. Then I couldn't get the nuts off the rear sprocket, with my 1/4 inch wrench and couldn't use my 3/8 because I didn't have the adapter for the socket. Back to the store to buy a 12mm socket for a 3/8 wrench and an adapter. Another reason to go back to the store was that the drive sprocket was not the right one. It was meant for an older KLR, and was way to thin. To make up for the thickness I bought a thick large washer. I think I got it pretty near the normal size. While we were out again we stopped by a sporting goods store to check on rain gear, I had no desire to ever get soaking wet again! Again I was lucky in that the gear that I liked was not only on sale, but very thin and compact as well. A very light beige color that should be very visible. Got some reflective tape too that I'll stick on the arms for better visibility. As you noticed, no pics! I decided that there were way to many pics on my RR of Spirit being partially or whole decommissioned. ![]() One thing I did find out unfortunately, is that there are no camping places in or near Pharr TX, at least not for a tent. I am going to have to figure that out somehow............
02-08-2013, 06:24 PM
#622 | |
aka SoulDreamRider
Oddometer: 491
02-08-2013, 06:34 PM
#623 |
Oddometer: 76
Hi Nomadgirl!
I just love following your problem solving! I think it's good when you describe what and how you do things. The pictures and explanations help less experianced people do the same things on their bikes. Some people would never attempt the projects you have tackled. With a few pictures and explanations from people like you who are not afraid to try, it makes things easier. Keep up the good work! ![]() ![]() ![]() Regards....just jeff |
02-08-2013, 09:06 PM
#624 |
Oddometer: 242
well you could always stealth camp he he he he
2012 YAMAHA WR250R 2013 KAWASAKI KLR650 "Take the long way home" YOU GOT TO WATCH ---->http://vimeo.com/53311329 |
02-09-2013, 10:05 AM
#625 | |
Phaneropter
![]() It is really part of the charm of the report. ![]() Nomadgirl Sure you can say pooped. It is what motorcycles do to all of us once they crave for some affectionate attention.
02-09-2013, 12:24 PM
#626 |
Oddometer: 1,856
Beware of hardware store raingear. The thin stuff doesn't really hold up well in a 60mph wind....
Feike Said James to Red Molly, Now Nortons and Greeves and Indians won't do- they don't have a soul like a Vincent '52 |
02-09-2013, 05:30 PM
#627 | |
aka SoulDreamRider
Oddometer: 491
It was on sale and I think it's really good quality. Brand name says Coastal Conservation, and it's really marine gear. I think it should be sufficient, but will find out on Monday when I leave for Pharr
02-09-2013, 05:33 PM
#628 |
aka SoulDreamRider
Oddometer: 491
Finally found a campground that will accept tents! Yay!
Not only is it 10 minutes from the Pharr Costco, but they are giving me a break for camping out there 12 days, $144. It's got showers and electricity, and I won't have to worry if my gear is still there when I get off work at 8PM. I only hope it's not too noisy!
02-11-2013, 06:07 PM
#629 |
aka SoulDreamRider
Oddometer: 491
Take it from me, the longer you stay somewhere, be it camping or just staying at a friend's or relative, the longer it takes you to pack up your bike! Holy cow! It took me forever to finally hit the road again this morning.
The weather really wasn't looking too good, and the rain came down in huge spats occasionally, but by the time Spirit was all packed up, it looked like it might stay dry a while. Of course getting out of any huge city takes a while, so when I finally hit Hwy 35 going south, I breathed a little easier. ![]() The say looked gloomy, and I honestly did not see too much that I wanted to take a picture of. ![]() I did want to see how fast I could get the camera started and take a shot. With this camera, very fast! Saw the cows in the trailer as I was passing them and thought, hey a funny pic ![]() ![]() That blue building is a hotel I rode toward Corpus Cristy and checked my email at a McD I had heard back from SaltWindandFire, and called him to say I was near. Unfortunately we kept playing phone tag, and I decided to check out the free campsite off interstate 37. Other than noisy it is really a cool campsite, if you don't count the stray cats crawling around you tent, and inside your vestibule, looking for food. Shall I give them my leftovers????
02-11-2013, 06:56 PM
#630 | |
Irreverent Reverend
Oddometer: 2,079
... btw .. awesome trip and RR .. I look forward to reading your adventures .. keep 'em coming kiddo .. .. also .. the Moose Racing front sprockets work great with an Eagle Mike's nut holding it on .. just sayin' .. I keep one in 14t, 15t, and 16t around and adjust accordingly to where I'm wandering .. fwiw, the 16t sucks on anything other than highway traveling with minimal hills .. .. Ride Blessed young Lady ..
"On the road less traveled there ain't no TP, bring your own and that will make all the difference.." RevBill's SmugMug Shenanigans My '06 KLR |
