Old 02-05-2013, 07:57 PM   #7231
beergut
Thumper
beergut's Avatar
Oddometer: 426
I installed a different jet in the clutch tonight and now the stupid thing wont shift gears. Any tricks? I havent been able to start the bike yet, its totally tore down. I tried moving the rear tire, I took it off the center stand rocked it back and forth pretty hard...nothing. -pulling in the clutch does not move it into neutral.
My KLR
DIY rear top rack
beergut is offline   Reply With Quote
Old 02-05-2013, 08:54 PM   #7232
StevefrmGV
MotoBro's RetroCycle's
StevefrmGV's Avatar
Oddometer: 406
Originally Posted by SierraJeep View Post
You finally gonna fix that custom stick in that exhaust mount before it gets crispy?
Maybe I should keep it, it worked great and if needed could be used as kindling?
Here's a sneak peek of the new look:
[IMG][/IMG]
Suspension off to Perry Patton for overhaul and set up:
[IMG][/IMG]
Think I will powder coat the swing arm black.
May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.
Edward Abbey
StevefrmGV screwed with this post 02-05-2013 at 09:04 PM
StevefrmGV is offline   Reply With Quote
Old 02-05-2013, 10:13 PM   #7233
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,145
Thats the problem with too large a clutch oil jet. and oh, its not the bike who's stupid
Blip the throttle with the clutch pulled in and then try to shift gears. Of course you need to start the engine up to be able to do this.
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 02-05-2013, 10:31 PM   #7234
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,315
I wanted some longer pegs to spread the load across the entire width of my foot.
I found some donor pegs and cut the tips off.
Welded them together, squirted on some paint, and baked it in the oven for an hour.
Installed on the bike & took for a test ride. Nirvana.
Net cost: 50 cents of spray paint and 4 cents for the electricity to weld & grind.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 02-06-2013, 11:59 AM   #7235
KTMSAM
KTMSAM's Avatar
Oddometer: 123
Farkles and Such
Today I added rim stickers, KTM top case, went through all of the suspension settings, mounted the right mirror on the new bar clamp and off of the master cyl, added the orange frame protectors by the foot pegs, and installed UNI prefilter. Spring can't come soon enough!
[IMG][/IMG]
"KTM? Who makes that?"
KTMSAM screwed with this post 02-06-2013 at 12:04 PM Reason: added the list of things
KTMSAM is offline   Reply With Quote
Old 02-06-2013, 12:16 PM   #7236
dirtybikefrank
Beast wrestler
dirtybikefrank's Avatar
Oddometer: 433
Yeah KTM!
Just finished a major tune up.
Get this...47k miles of romping and...
-Waterpump looked great, no need for replacement but put in the CJ one anyway.
-Valves were spot on, last checked at 36k.
-Nothing leaks or squeaks.
This bike has been ridden hard and maintained on time every time. It's comforting to have a bike that's built so well and can go the distance.
Well done my Austrian brothers. Well done.
dirtybikefrank is offline   Reply With Quote
Old 02-06-2013, 07:47 PM   #7237
Orangecicle
Orangecicle's Avatar
Oddometer: 2,562
Pelican cases
Other than cam lock installations, the Pelican cases are done. Wahoo!
Orangecicle is offline   Reply With Quote
Old 02-07-2013, 11:48 PM   #7238
Mr_Snips
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
I installed some new to me hepco and becker ktm panniers...finally found a good deal on them.
Originally Posted by Reprobate
Familiar. My stock response: "Most people die in bed. So, where do you sleep?"
Mr_Snips is offline   Reply With Quote
Old 02-08-2013, 10:30 AM   #7239
Themastermike
Passin gas
Themastermike's Avatar
Oddometer: 744
pulled
pulled off the CPR Rottweiller with hopes of selling it...........
Siphoned fuel out to pull the tanks for the first time.
Taste of gas never is good.
pulled upper plastic
to be continued
Themastermike is online now   Reply With Quote
Old 02-08-2013, 11:04 AM   #7240
Supahflid
Wheelieless
Oddometer: 3,699
Why?
Supahflid is offline   Reply With Quote
Old 02-08-2013, 05:51 PM   #7241
Themastermike
Passin gas
Oddometer: 744
reason
Originally Posted by Supahflid View Post
Why?
It runs great now that is for sure. I want to go back to stock and hopefully map for a few more mpg.
Stock horsepower is going to be plenty for me.
Old 02-08-2013, 11:30 PM   #7242
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,315
to be continued
First, why wouldn't you just pull the tanks with gas in them? Second, why syphon instead of draining it out thru the petcocks?
Old 02-09-2013, 05:06 AM   #7243
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,145
Bought a Shindengen FH020AA R/R and installed it.
This is the new update part no. for the FH020AA with the upgraded heat sink.
removed stock R/r and check the fit
measured and checked wiring length
crimped the new connectors. btw i cut off the stock wires from the alternator close to the conenctor to install the new Furukawa connectors.
will it fit using the stock mounting holes ?
looks like it will
i'll just need to trim some plastic here and it will fit using the stock mounting holes
took care of the grounding used a new ring lug.
For the positive connections from the R/R, i cut off the stock 2-pin connectors and used two separate bullet connectors from the FH020. Sorry but you cant see this clearly in the pic.
this is what i took off the bike. It not faulty or broken i just wanted a project
Old 02-09-2013, 03:44 PM   #7244
Dr LC8
...soon or later
Dr LC8's Avatar
Oddometer: 936
[IMG][/IMG]
[/QUOTE]
Where are these stickers coming from?
Cheers
Nic
Explore Alps Off Road: www.over2000riders.com
2012 Ducati Multistrada 1200
2008 KTM LC8 990 ADV S
2003 KTM LC8 950 ADV
Trips:Europe,Africa,Asia
Dr LC8 is offline   Reply With Quote
Old 02-09-2013, 03:44 PM   #7245
prince
prince's Avatar
Oddometer: 88
new 990 adv rider
Just got me a 2007 990 and was wondering if any of you recommend a good mechanic in the Los Angeles area. Looking for someone who might not be corporate anymore, has his own shop and can teach me a few things while working on my bike as i plan on taking her around the world.
thanks in advance.
prince is offline   Reply With Quote
Times are GMT -7.   It's 11:26 AM.
