Old 02-10-2013, 03:00 PM   #7156
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,024
lower
Originally Posted by The Walrus View Post
There are several ways to skin this cat....I bought hardened bolts and used a Delrin shoulder to replace my stock bolts....no problems at this point....I think it was a $10 fix.
Yes I did the same thing on the lower tank bolts also, easy fix. It was the upper ones that made me think of a cheaper (KLR) way to fix them lol.
The road less traveled is the road I travel more.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." Dean Martin
StepOnIt is online now   Reply With Quote
Old 02-10-2013, 03:07 PM   #7157
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Really liking the RR EVO2 tanks, they sure do snug in very well!
The only issue I had with the install was mounting my upgraded Reg/Rect, I need to make a bracket to position it lower. My RR has plugs instead of leads, so the width is wider than the stock R/R that comes on the 690. Personally, I think it's in a better place for cooling anyway but it's also probably more prone to damage. I'll post pics when I get it sorted out!
The HDB Nav tower is great, love the simplicity and the dual Squadrons should provide plenty of light
Just say'IN
crankshaft is offline   Reply With Quote
Old 02-10-2013, 03:09 PM   #7158
DirtRideRoader
Armed and Dangerous
DirtRideRoader's Avatar
Oddometer: 410
Originally Posted by StepOnIt View Post
I had my upper tank bolts kinda made for cheap. Ground off the threaded part ( that breaks) and had it drilled and tapped out then put in a new stronger threaded piece. So far so good and it only cost $20 to do both sides.
How did you remove the broken piece out of the frame? Drill and easy out or can you just thread it out to the inside with a pair of visegrips?
Chris
IBA #23263
DirtRideRoader is offline   Reply With Quote
Old 02-10-2013, 03:25 PM   #7159
Honkey Cat
Tailights Fade!
Oddometer: 1,108
Can you put up a front shot of bike?
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 02-10-2013, 03:27 PM   #7160
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Best I can do at the moment....
Just say'IN
Old 02-10-2013, 04:00 PM   #7161
Honkey Cat
Tailights Fade!
Oddometer: 1,108
Hdb
Thanks looks great. Might have to get one..
Old 02-10-2013, 05:59 PM   #7162
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,157
Very slick Aaron...
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 02-10-2013, 06:52 PM   #7163
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Originally Posted by Pantah View Post
Very slick Aaron...
Thanks Bob! It's all coming together, the EFI is working very well. Slowly dialing in the tuning and it just keeps getting better. It should be pretty damn close to 70 hp at the rear wheel,when all is said and done. 12 ft lb gain in the mid range after the last dyno session. You can take it for a spin in Mexico if you want!
Just say'IN
Old 02-10-2013, 07:11 PM   #7164
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,024
vise grips
I was lucky that there was enough thread left to get some vise grips on it from the inside. Also I notice in my friends driveway vs on the trail. I did the other side vs waiting for it to fail.
Old 02-10-2013, 07:18 PM   #7165
Chris 690R
Oddometer: 66
Man, this bike is sweet, but boy do I hate being 5"8. I might have to sell it or trade it for a different bike. Gonna try a link first.
Get a 2012 model much lower. I am 5"9 and still tippy toes, but easily doeable and does not bother me at all!!
Chris
Chris 690R is offline   Reply With Quote
Old 02-10-2013, 07:54 PM   #7166
MrHix
MrHix's Avatar
Oddometer: 384
Chris
I'm 5'8" too. I had Superplush Suspension (in CA, USA) respring, revalve, and lower the bike 1.5". The only disadvantage is that I have only 8.5" of travel now, but I don't ride the bike like I did with my KTM/Thumperracing 320 XCF-W.
Cheers,
MrHix
MrHix is offline   Reply With Quote
Old 02-11-2013, 07:59 AM   #7167
ten.98
...leave a trail
Oddometer: 51
Trail Tech Voyager KTM 690 Install w/LFI
Destroyed my stock instrument cluster while on an enduro ride this weekend. Looks like the stock replacement is around $330. Also looking at the trail tech voyager as a possible replacement. Would save me about $50. Has anyone else put one of these on their 690 yet? It doesn't look like they make a model specific version, which would mean you would have to run separate leads for all of the monitoring and bypass the stock wiring harness. Not sure how I feel about that. Also, I'm guessing theres no low fuel indicator or Fault Indicator lamp access as well.
The FI I'm not as concerned about, but lack of LFI would be troubling. Anyone know if there's a way to rig a separate LFI lamp outside of the stock instrument cluster?
ten.98 is offline   Reply With Quote
Old 02-11-2013, 08:17 AM   #7168
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,670
Originally Posted by The Letter J View Post
I see a lot of people changing the lower tank bolt (good idea) but not too many people changing the bushings themselves. My lower bushings were sloppy as all hell by the time I hit 3k miles so I replaced them with Delrin bushings that I purchased from "partmaker" in the vendor's forum here on ADV. Absolutely no slop in the 9k miles since!
This.
I went through a few sets on my 08 in the first 15k miles. Installed the Delrin ones from Partsmaker, and no issues for the 15k miles after that. I'll probably end up pulling them out of the 08, and installing in the 2012 at some point.
BK.RD.RNR is offline   Reply With Quote
Old 02-11-2013, 08:49 AM   #7169
Velociraptor
TrackBum
Oddometer: 1,118
Those tanks look a lot narrower than the old style tanks I am using!
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 02-11-2013, 08:56 AM   #7170
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,545
I just compared my bike from the front with this photo and I would say you are correct. I think the new tanks are closer to the Rally bike design and get away with a flatter design but similar volume..The old tanks are not horrible by any measure but the new ones are a nice setup.
Seth S
Seth S is offline   Reply With Quote
Times are GMT -7.   It's 04:09 PM.
