Old 02-11-2013, 02:53 PM   #17386
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,260
Can anyone recommend an inexpensive carb rebuild kit?
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 02-11-2013, 03:51 PM   #17387
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,026
There u go:
NEW SUZUKI DRZ400S DRZ 400 400S 2000-2009 NEW CARB CARBURETOR REBUILD REPAIR
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 02-11-2013, 04:38 PM   #17388
150ron
150ron's Avatar
Oddometer: 1,426
Made a new/different bracket for my TTO gauges just now, think i like it better this way compared to how i had them before.
Just some dude...
150ron is offline   Reply With Quote
Old 02-11-2013, 06:58 PM   #17389
DualSportDad
DualSportDad's Avatar
Oddometer: 2,446
Bsr? You can buy stock carbs for like $50 shipped. What is wrong with your carb?
Sent from my Galaxy Note 2 using tapatalk 2
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
DualSportDad is offline   Reply With Quote
Old 02-11-2013, 07:07 PM   #17390
Greg MacD
Greg MacD's Avatar
Location: Flying at 1500 foot AGL over the Gulf of Mexico
Oddometer: 471
Originally Posted by farkleface View Post
The battery was low before I put it on the charger, but it had power to everything at that time also?? The charger did something to kill all the electrical ??
Sounds like you "cooked" your battery. The battery when charged will have the water (electrolyte) evaporate and leave the poor thing dead.
2003 Aprilia RST1000 Futura
2006 Harley Davidson FLHTPI
2004 Suzuki DR-Z400s (Motard)
"Drinking Rum before 10 am does not make you an Alcoholic, it makes you a Pirate"
Greg MacD is offline   Reply With Quote
Old 02-11-2013, 07:16 PM   #17391
MikkSteel
MikkSteel's Avatar
Oddometer: 32
Where exactly are they selling stock carbs for $50? Mine is toast after the air/fuel mixture screw broke off inside.
2006 XT225
MikkSteel is offline   Reply With Quote
Old 02-11-2013, 07:40 PM   #17392
DualSportDad
Oddometer: 2,446
I put a wtb thread in the flea market and got a carb with 500 miles on it with a stage one Dyno Jet kit for $50 shipped if I remember correctly. Back when I was looking for a bsr it looked like about $25-$50 was the normal going rate.
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
Old 02-12-2013, 03:53 AM   #17393
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,260
Originally Posted by DR650SEDDY View Post
Thanks, I was looking for something a bit less $
Float needle / seat need replacement. FIgured I replace other rubber bits while I was in there.
Old 02-12-2013, 06:18 AM   #17394
mars
Starbucks anyone?
mars's Avatar
Oddometer: 1,900
has any one tried the sw mototech panier mounts? I have a set of Zega bags and one is wider than the other. SW's racks look to accommodate a narrow bag on the non exhaust side and they look bulletproof too.
mars is offline   Reply With Quote
Old 02-12-2013, 07:12 AM   #17395
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Sanjoh...... At least try a 25 pilot jet and a Keintech Extended fuel screw set at about 2.5 turns. And work with the needle clip or space it. This alone makes a BSR 36 work better off bottom. There is no substitute for the blue JD needle though eventually. It is specially machined and the R&D on it is $$$$. But it works.
buls4evr is offline   Reply With Quote
Old 02-12-2013, 07:13 AM   #17396
DualSportDad
Oddometer: 2,446
If it's leaking it is probably just the o ring around the seat. That's what it had been 90% of the time on my bike and my friends. You can buy a viton o ring kit for $10 at the parts store that will have the needed size. One time I had a clogged gas cap vent cause the problem to but that was on the stock e gas cap.
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
Old 02-12-2013, 11:06 AM   #17397
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,026
Originally Posted by 150ron View Post
Now that is a nice piece, i had the Vapor on another bike, never an issue, please put up some pics once its on your bike, will like to see how you end up mounting it, congrats.
I bought a project box from Fry's Electronics made from aluminum. I took my Striker with me to make sure it'll fit snugg inside the box. Once i decided where it should be located i made my mesurements upon that, and build 2 small brackets, slitly curved,
By the way i replace my hand guards to Moose Racing now.
I sat on the bike to make sure it's at the right angle before i drill it in place.
Almost the final product, i still have to connect the wires and speedo cable tonight, and testing it in rough terrains later on is critical.
Old 02-12-2013, 11:13 AM   #17398
blaster11
Heading North!
blaster11's Avatar
Oddometer: 7,023
Pictures of you speedo sensor install?
I am starting my Trailtech Vapor install and was wondering how you guys installed the magnetic pickup on your bike, no sense in reinventing the wheel so to speak. Looking for pictures of the sensor down on the wheel.
blaster11 is offline   Reply With Quote
Old 02-12-2013, 11:17 AM   #17399
4TooMany
4TooMany's Avatar
Oddometer: 329
Hey, what "caliber" is your key? Looks like a .45, but the case appears to be stepped. My friend and I are trying to figure it out.
MSF RiderCoach
2012 BMW F800GS Trophy
2011 Suzuki DRZ-400S
4TooMany is offline   Reply With Quote
Old 02-12-2013, 12:21 PM   #17400
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,026
i was trying to figure this out myself last nite but i got too tired , if anything i'll wait till my neighbour cross the street get back in town he's got the same bike and device. He told me to wait he'll help me out on that. If i only can peak into his bike quickly . i'll post up a pix soon as i get it done.
Times are GMT -7.   It's 03:16 AM.
