Old 02-11-2013, 02:53 PM   #17941
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,665
Can anyone recommend an inexpensive carb rebuild kit?
Old 02-11-2013, 03:51 PM   #17942
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,178
There u go:
NEW SUZUKI DRZ400S DRZ 400 400S 2000-2009 NEW CARB CARBURETOR REBUILD REPAIR
DR-Z400E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is online now   Reply With Quote
Old 02-11-2013, 04:38 PM   #17943
150ron
150ron's Avatar
Oddometer: 820
Made a new/different bracket for my TTO gauges just now, think i like it better this way compared to how i had them before.
Just some dude...
150ron is offline   Reply With Quote
Old 02-11-2013, 06:58 PM   #17944
DualSportDad
DualSportDad's Avatar
Oddometer: 2,113
Bsr? You can buy stock carbs for like $50 shipped. What is wrong with your carb?
Sent from my Galaxy Note 2 using tapatalk 2
Alex
Cape Coral, Fl.
2003 KLX400R tagged
DualSportDad is offline   Reply With Quote
Old 02-11-2013, 07:07 PM   #17945
Greg MacD
Greg MacD's Avatar
Location: Flying at 1500 foot AGL over the Gulf of Mexico
Oddometer: 126
Originally Posted by farkleface View Post
The battery was low before I put it on the charger, but it had power to everything at that time also?? The charger did something to kill all the electrical ??
Sounds like you "cooked" your battery. The battery when charged will have the water (electrolyte) evaporate and leave the poor thing dead.
2003 Aprilia RST1000 Futura
2006 Harley Davidson FLHTPI
2004 Suzuki DR-Z400s (Motard)
Greg MacD is offline   Reply With Quote
Old 02-11-2013, 07:16 PM   #17946
MikkSteel
MikkSteel's Avatar
Oddometer: 26
Where exactly are they selling stock carbs for $50? Mine is toast after the air/fuel mixture screw broke off inside.
_______________________________________________
'05 DR650
'04 DR-Z400S
MikkSteel is offline   Reply With Quote
Old 02-11-2013, 07:40 PM   #17947
DualSportDad
Oddometer: 2,113
I put a wtb thread in the flea market and got a carb with 500 miles on it with a stage one Dyno Jet kit for $50 shipped if I remember correctly. Back when I was looking for a bsr it looked like about $25-$50 was the normal going rate.
Alex
Cape Coral, Fl.
2003 KLX400R tagged
Old 02-12-2013, 03:53 AM   #17948
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,665
Originally Posted by DR650SEDDY View Post
Thanks, I was looking for something a bit less $
Float needle / seat need replacement. FIgured I replace other rubber bits while I was in there.
Old 02-12-2013, 06:18 AM   #17949
mars
shipwrecked in ER
mars's Avatar
Oddometer: 1,672
has any one tried the sw mototech panier mounts? I have a set of Zega bags and one is wider than the other. SW's racks look to accommodate a narrow bag on the non exhaust side and they look bulletproof too.
mars is online now   Reply With Quote
Old 02-12-2013, 07:12 AM   #17950
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 1,610
Sanjoh...... At least try a 25 pilot jet and a Keintech Extended fuel screw set at about 2.5 turns. And work with the needle clip or space it. This alone makes a BSR 36 work better off bottom. There is no substitute for the blue JD needle though eventually. It is specially machined and the R&D on it is $$$$. But it works.
buls4evr is offline   Reply With Quote
Old 02-12-2013, 07:13 AM   #17951
DualSportDad
Oddometer: 2,113
If it's leaking it is probably just the o ring around the seat. That's what it had been 90% of the time on my bike and my friends. You can buy a viton o ring kit for $10 at the parts store that will have the needed size. One time I had a clogged gas cap vent cause the problem to but that was on the stock e gas cap.
Alex
Cape Coral, Fl.
2003 KLX400R tagged
Old 02-12-2013, 11:06 AM   #17952
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,178
Originally Posted by 150ron View Post
Now that is a nice piece, i had the Vapor on another bike, never an issue, please put up some pics once its on your bike, will like to see how you end up mounting it, congrats.
I bought a project box from Fry's Electronics made from aluminum. I took my Striker with me to make sure it'll fit snugg inside the box. Once i decided where it should be located i made my mesurements upon that, and build 2 small brackets, slitly curved,
By the way i replace my hand guards to Moose Racing now.
I sat on the bike to make sure it's at the right angle before i drill it in place.
Almost the final product, i still have to connect the wires and speedo cable tonight, and testing it in rough terrains later on is critical.
Old 02-12-2013, 11:13 AM   #17953
blaster11
Are you a Sheeple?
blaster11's Avatar
Oddometer: 4,688
Send a message via Skype™ to blaster11
Pictures of you speedo sensor install?
I am starting my Trailtech Vapor install and was wondering how you guys installed the magnetic pickup on your bike, no sense in reinventing the wheel so to speak. Looking for pictures of the sensor down on the wheel.
Bruce
IBA # 46755
Adventures of Blaster and Dorito
blaster11 is offline   Reply With Quote
Old 02-12-2013, 11:17 AM   #17954
4TooMany
4TooMany's Avatar
Oddometer: 232
Hey, what "caliber" is your key? Looks like a .45, but the case appears to be stepped. My friend and I are trying to figure it out.
MSF RiderCoach
2012 BMW F800GS Trophy
2011 Suzuki DRZ-400S
4TooMany is online now   Reply With Quote
Old 02-12-2013, 12:21 PM   #17955
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,178
i was trying to figure this out myself last nite but i got too tired , if anything i'll wait till my neighbour cross the street get back in town he's got the same bike and device. He told me to wait he'll help me out on that. If i only can peak into his bike quickly . i'll post up a pix soon as i get it done.
Times are GMT -7.   It's 02:52 PM.
