Old 02-11-2013, 02:43 PM   #33076
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,905
Originally Posted by Scott_PDX View Post
I got the 270's I think they are fine, but then I don't rail corners on the WR and hear they can be squirmy (i've not noticed it). I actually liked the Sinko's 244 better which have a similar pattern and are even cheaper.
Loving the 244s on my 17's... will do that again
Mr. Fisherman is offline   Reply With Quote
Old 02-11-2013, 03:40 PM   #33077
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,778
the dreaded swingarm boogie
Woo-hoo. I got back yesterday from 5 weeks in Baja, plus a week of taking the long way to get there from Nor Cal via Death Valley. The WR was awesome.
Unfortunately, I got too complacent and let the chain slack and lubrication get away from me. Conditions were very tough--salt spray, sand, mud that was more like cement (both wet and dry). The chain wore, got corroded, and I didn't notice it until it was too late and have suffered the painful-to-look-at swingarm damage. Chain slider gave way, chain slack was excessive, some of the links started to kink, and now I've got approx. 2-3 mm deep grooves worn in the bottom leading edge of my swingarm pivot.
I'd appreciate hearing from fellow WR owners on how they've recovered from this. Options I see are:
1. Replace the swingarm
2. Get it welded.
3. Fill with quicksteel.
4. Ignore it, and keep riding.
All of the options include replacing the chain slider and chain...
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 02-11-2013, 04:25 PM   #33078
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,755
2. Get it welded.
Cry, Replace Slider, Ride.
Sucks, but you aren't the first this happened to.
Would love to see if anybody else's fixes for this are though. It's my nightmare.
Have heard of some folks replacing the lower slider with a piece of "Delrin" (look it up) to keep this from happening again in the future. Kinda too late for you though.
On the plus side, looks like that weld you cut through had excellent penetration!
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 02-11-2013, 05:08 PM   #33079
jon_l
jon_l's Avatar
Oddometer: 3,465
2. Get it welded.
haven't done it myself, but I have read everything i could find about this before buying a WRR.
Personally, I'd go with #3, and as you said, install new sprockets, chain, and seal-guard.
On Page 3 is a write-up by a guy who used JB Weld or similar to fill in the grooves: http://wr250rforum.forumotion.com/t4...eaten-by-chain
CBF1000 & PCX150, PCX Fuelly
jon_l is online now   Reply With Quote
Old 02-11-2013, 05:19 PM   #33080
UtahFox
UtahFox's Avatar
Oddometer: 446
Here it is, my new WRR. Picked it up 120 miles from here, where I'm staying with my parents in Palm Springs. Heading back up to SLC in a week or so, via Death Valley and central Nevada and Utah. More pics later. Fun ride!
UtahFox is offline   Reply With Quote
Old 02-11-2013, 05:37 PM   #33081
AZ TOM
Oddometer: 4,152
Congrats, looks brand new!!
AZ TOM is online now   Reply With Quote
Old 02-11-2013, 06:37 PM   #33082
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,661
Laugh
You shoot your eye out!
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 02-11-2013, 08:04 PM   #33083
avgas
amateur
avgas's Avatar
Oddometer: 83
bearings
I think I'm going to dive into the head bearing to make sure it has enough grease/regrease it. I think the only special tool I need is a steering stem spanner, is that correct? Anyone know what size? Will this one work? http://www.rockymountainatvmc.com/p/...Spanner-Wrench
Since I'm talking about greasing bearings, are there any other ones that I really should check?
2012 Yamaha WR250R
avgas is offline   Reply With Quote
Old 02-11-2013, 08:39 PM   #33084
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 761
I got mad at mine. I kept the old worn out chain and tried to repair the chain slider with various materials. I tried cutting board but it wore quickly. I tried lexan but the JB weld did not stick well enough and it fell off. I was fed up so I bent a piece of steel and attached it to the slider with screws. The chain actually ate into it pretty well and I have replaced the steel piece once. Maybe when I get a job I can afford to replace the sprockets and chain. The chain is not visibly kinked but it still pretty bad and needs replacing.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 02-11-2013, 10:24 PM   #33085
skierd
Wannabe Far-Rider
Oddometer: 2,990
Swingarm pivot. I've been trying to get mine loose for a week, but its still stuck solid.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is online now   Reply With Quote
Old 02-11-2013, 10:55 PM   #33086
UtahFox
UtahFox's Avatar
Oddometer: 446
Thanks Tom. Yeah it does. There are some scratches, but all of them are in places that I'm going to replace or places I simply don't care.
It's really tall, and I'm going to have to lower it some. First up is the seat. Turns out I'm really close to Seat Concepts here, so have an appointment to get the seat redone on Wednesday. I'm hoping to get a pic or two at their shop. I'll wait until I get home to do the factory lower, which I think will be enough.
The bike had 372 miles on it when I picked it up, but will have triple that by the time I get back home. I have a Rotopax, tank bag, and a USB power port arriving this week for the trip back. Lots more to do, but I am looking forward to the ride home.
Is there any way to display a tach, or do I need to install an add on computer for that?
Old 02-12-2013, 05:56 AM   #33087
30Bones
30Bones's Avatar
Oddometer: 4,703
People with swingarm damage, what front sprocket are you running? 12 or 13?
30Bones is offline   Reply With Quote
Old 02-12-2013, 06:08 AM   #33088
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,390
I'm running a 13. Right now a 12. But mostly a 13. Bike has 30,000 kms and I have replaced 3 guards, need another one right now but waiting a bit. I am going to do a full swing arm movement adjustment. I found that the more I weight the bike down the sooner the guard is destroyed. Slack is set fine for normal riding or empty bike but gear up or two up and it will be too tight.
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 02-12-2013, 06:34 AM   #33089
Mr. Fisherman
PROUD 2B Riff Raff!
Oddometer: 10,905
I had a 13, switched to a 14 and came up with a chain adjust and check tech that has worked well so far.
Old 02-12-2013, 07:14 AM   #33090
SkidMarx
SkidMarx's Avatar
Oddometer: 2,335
I run a 12 or 13.
Was running the 13 when I got the damage. Stock chain was not that old, but It got kinky when I let the maintenance slip. Kinks will eat that slider faster than anything.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Times are GMT -7.   It's 05:18 PM.
