Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 02-11-2013, 09:46 AM   #16756
Two Moocows
Oddometer: 7
Talking A Sunny afternoon ride in the Middle East.
Took the Scram out for a ride in Bahrain on Saturday. It was a beautiful day.
Lovely sunsets in this small country.
Enjoy.
Two Moocows is offline   Reply With Quote
Old 02-11-2013, 09:52 AM   #16757
vicvegas
eager beaver
vicvegas's Avatar
Oddometer: 192
Beautiful pictures Two Moo, can you say new desktop background!
vicvegas is offline   Reply With Quote
Old 02-11-2013, 10:16 AM   #16758
Tin Shack
Oddometer: 15
Originally Posted by 40cu.in.of.furey View Post
How many of you guys with scramblers have the Zard exhaust that goes under the frame like the hammarhead scrambler? How loud is it and is it bareable on long trips?
Not loud at all with the baffle in.................you will have to cut out the small crossbar at the end of the baffle or you will have the annoying "chirp" mentioned above!
Tin Shack is offline   Reply With Quote
Old 02-11-2013, 10:19 AM   #16759
Dcc46
Dcc46's Avatar
Oddometer: 509
Talking
Fun in the Sun, and sand along the ICW . Sorry no mountains or grass here, but it is 80 degrees and sunny atm. 800 miles on it since last week when i bought it. This bikes a hoot.
“People sleep peaceably in their bed at night only because rough men stand ready to do violence on their behalf.” –George Orwell
Dcc46 is offline   Reply With Quote
Old 02-11-2013, 02:14 PM   #16760
Mastodon
Mother F'n Dinosaur
Mastodon's Avatar
Oddometer: 671
My Metal Mule racks and Kriega luggage came in a few days ago, but I spent the weekend out of the country, so I couldn't really do much with it until today.
The pipe-side rack mounted easily enough
but I ran into a problem with the off-pipe side. When I tried to mount it behind the footpeg bracket, the rack would push into the spring a fair bit. The rack itself looks straight, and since I remember the bike falling on that side on the highway a few years ago, there is a chance that the footpeg bracket was bent in slightly. I do have scrapes on my swing arm where that bolt sticks out at. A local bike shop suggested the same a few weeks back while they were mounting my tires, but other than the marks on the swing arm, couldn't find any other hints of the frame being bent.
The MM instructions mention that if I had the Arrow pipe, and had bought that rack, there would be spacers to mount the rack to the outside of the footpeg bracket. Since I didn't have that kit, I went down to Home Depot and bought some nylon ones.
Racks seem solid, and when I used them to pick the bike off of the side stand and shake the rear end up and down a bit, there wasn't even a wiggle of play in the racks. And that's without using the cross brace connecting the two racks together as a 4th mounting point. I still need to come up with a good spacer for that.
So, with a steady rack, I mounted the Kriega bags, the Overlander 60 set. I liked how adjustable the setup was, since instead of a bag, I could put on two Rotopax containers. Thats either 60L of dry storage or 8 gallons of fuel/water. Or a combination of anything between I just have the drybags for now, but with the short range of the Scram, I'll definitely trade in one bag spot for the extra fuel.
I think I'm gonna have to take a nice long trip sometime soon to give this the proper workout.
Mastodon is offline   Reply With Quote
Old 02-11-2013, 04:04 PM   #16761
xaman
Oddometer: 607
Thanks for those pics, that's a great Kriega setup.
xaman is offline   Reply With Quote
Old 02-11-2013, 09:04 PM   #16762
Motoblag
Replacing skill with will
Motoblag's Avatar
Oddometer: 394
Anyone rebuilt their rear caliper? Mine is all kinds of mangled from riding in the rain and dust/dirt and it looks like the pistons aren't retracting: the piston side is worn down to 30% and the other side is at 90%, after about 5,000 miles!
I've got an Up & Over bracket on there now but it'd be best to refresh the parts to keep this from being an issue.
I've heard Honda ST1100s share the same brake caliper, but that may just be for the pads: looking at pictures online they don't appear to be the same caliper. Anyone able to shed light on this?
Motoblag is offline   Reply With Quote
Old 02-11-2013, 09:36 PM   #16763
tvscum
tvscum's Avatar
Oddometer: 141
Lots of info here:
http://www.triumphrat.net/twins-tech...placement.html
Current: 2012 Triumph Scrambler;
'97 Honda XR440 (plated)
Past: '83 Honda XR500; '84 Honda XL600;
'86 Yamaha XT350
tvscum is offline   Reply With Quote
Old 02-12-2013, 01:40 AM   #16764
kiwicaveman
Oddometer: 49
It's a sliding calieper and the pins need lubricating every few thousand kms i do mine every time i change the oil any brake specialist will have the correct grease
kiwicaveman is offline   Reply With Quote
Old 02-12-2013, 04:54 AM   #16765
TerryK
Ulysses
Oddometer: 1,783
Lucas tail light
So got my Lucas tail light & it looks great but not happy with the mounting.
It needs 2 holes drilled in the rear of the fender & the front bolt is on the wrong angle, yes I could just whack a few holes in & bolt it up but to me it will look like crap. The light looks like the NB unit but they offer a mount to allow a no drilling fitting.
Has anyone fitted a lucas light to a Triumph classic ?
cheers Terry
Triumph Scrambler Blue & White
Triumph Thruxton Red
Yamaha TT-R250
Check out my Youtube channel http://www.youtube.com/user/KaneTerry?feature=mhee
TerryK is offline   Reply With Quote
Old 02-12-2013, 06:13 AM   #16766
Goat_locker
Oddometer: 122
Originally Posted by TT RDHS View Post
Without the "db killer" installed, it is VERY loud at high revs.
It sounds absolutely glorious.
With the db killer in, it's quiet and has an intermittent high pitched "chirp", that I found annoying...
I shortened the db killer about 1,1/2" - 2", and cut out the little bar that goes across the inside of the insert.
Now it sounds nice. Maybe a bit louder than is "politically correct", but not loud enough to piss off my neighbors.
Got the same exhaust and have been thinking about doing what you did. What do you think was causing that "chirp"?
2006 Triumph Scrambler, 1971 Triumph T120RV Scrambler, 2007 BMW R1200GSA Scrambler , 1976 Honda XL350
Goat_locker is offline   Reply With Quote
Old 02-12-2013, 06:42 AM   #16767
none
Oddometer: 154
Originally Posted by TStorm View Post
This photo does make it look like the subframe is outa kilter.
none is offline   Reply With Quote
Old 02-12-2013, 10:16 AM   #16768
Mikey Boy
Mikey Boy's Avatar
Oddometer: 265
Subscribed. Thinking about a 2012 Scrambler to replace my I-4 snore machine...
2014 Tiger 800xc
1985 Honda Elite 150D
Mikey Boy is offline   Reply With Quote
Old 02-12-2013, 06:24 PM   #16769
Motoblag
Motoblag's Avatar
Oddometer: 394
Originally Posted by tvscum View Post
Thanks, already read through there a few times. Best I could glean from the thread was the front caliper seals may work on the rear and it's still about $80 for parts.
I think this may be the problem: I don't really maintain brakes aside from visual pad inspections and brake fluid every other year. I guess I've got to get used to inspecting and cleaning calipers on the Triumph. My Scrambler doesn't lap up neglect and abuse like my Honda, I suppose. :)
I may spring for some pricey super-awesome brake lube instead of the general Valvoline chassis grease I normally use on everything. I'll report back when I get more miles on it with properly cleaned/lubed brakes.
Old 02-12-2013, 10:30 PM   #16770
ferals5
800+652
ferals5's Avatar
Oddometer: 1,211
G'day motoblag
I'd just hit the slide pins with some CRC brake clean or similar to clean the grime off, no lube. Lube will just act as a brake dust collector and compound your problem.
oh and a word of warning these products are hazardous to ones health in aerosols so hold your breath
cheers
Mark
ferals5 is offline   Reply With Quote
Times are GMT -7.   It's 12:12 PM.
