02-12-2013, 05:56 AM
#33091 |
Oddometer: 4,572
People with swingarm damage, what front sprocket are you running? 12 or 13?
Today is the tomorrow you worried about yesterday |
02-12-2013, 06:08 AM
#33092 |
Cert. bike whore
Oddometer: 879
I'm running a 13. Right now a 12. But mostly a 13. Bike has 30,000 kms and I have replaced 3 guards, need another one right now but waiting a bit. I am going to do a full swing arm movement adjustment. I found that the more I weight the bike down the sooner the guard is destroyed. Slack is set fine for normal riding or empty bike but gear up or two up and it will be too tight.
2009 WR250R "Da Mini Bike" "That's our colour: mud!"
02-12-2013, 06:34 AM
#33093 |
oneandahalfassed
Oddometer: 9,806
I had a 13, switched to a 14 and came up with a chain adjust and check tech that has worked well so far.
Round Way Round, 2 months and several thousand miles on a WR250X |
02-12-2013, 07:14 AM
#33094 | |
Oddometer: 1,325
Was running the 13 when I got the damage. Stock chain was not that old, but It got kinky when I let the maintenance slip. Kinks will eat that slider faster than anything. |
02-12-2013, 07:24 AM
#33095 | |
Oddometer: 4,572
02-12-2013, 07:29 AM
#33096 | ||
Harvey Mushman
Oddometer: 1,326
In my case I think the damage was caused by 1. Chain/sprocket wear, leading to excessive slack. 2. Several weeks exposure to salt air, 1000's of miles of sand trails, and one spectacularly impassable mud pit that caused the rear wheel to completely lock due to mud packing around the swingarm, chain guide and front sprocket area. Grit and water got past the x-rings and eventually caused several links to kink up. 3. Riding with the above conditions with a full load of camping gear on extremely rutted/washed out dirt roads, where g-outs and 6" potholes are as common as cardon cacti. The loose and kinked chain tends to wrap upward as it leaves the bottom of the front sprocket under acceleration, add in the upward movement of the rear wheel under a g-out which further pulls the chain toward the bottom of the swingarm... I'm sure you can get swingarm damage in other situations--say a too tight chain--but it is very clear that the damage in my case was NOT caused by a tight chain. (i.e., much respect to BigDog, but my data simply doesn't jibe) I tightened up the chain slack, lubed the heck out of it, and got home with no more significant damage.
"Coffee first..." Next Trip: didn't get enough...Death Valley "it's a dog's life.............and I love it" HardWorkingDog screwed with this post 02-12-2013 at 07:43 AM |
02-12-2013, 07:40 AM
#33097 |
Oddometer: 2,366
Utah Fox good luck on your trip. If you can set the shock sag to 4+ inches, should help with the height. Seat Concepts will be a big plus. I am here in Prescott AZ, if you have any issues along the way on your trip just give a shout & I will give any help I can. Good luck & ride safe.
02-12-2013, 07:42 AM
#33098 |
armchair asshole
Oddometer: 2,558
In case anyone is in the market I got this email from rockymountainatvmc.com this morning about clearance prices on a battery.
To our valued customer: This email has been sent to let you know of a machine-specific clearance offer: AGM No Maintenance Battery clearance items are now available in limited quantities for your 2009 YAMAHA WR250R at special clearance pricing! Clearance price: $23.99 Reg Price: $54.99 Hurry! Clearance items move quickly and are limited to stock on hand. http://www.rockymountainatvmc.com/p/...-Battery-CTZ7S |
02-12-2013, 07:50 AM
#33099 |
Oddometer: 1,950
>"AGM No Maintenance Battery clearance items are now available in limited quantities for your 2009 YAMAHA WR250R at special clearance pricing! Clearance price: $23.99"
Hmm... the online reviews for this battery are not very good.
Whales were everywhere. On the beach, on the hillsides. One crossed the road in front of us… it was a big beluga! |
02-12-2013, 07:58 AM
#33100 | |
armchair asshole
Oddometer: 2,558
I didn't look into it at all just passing it along. I bought a new battery about a month ago so it's of no interest to me. |
02-12-2013, 08:09 AM
#33101 | |
oneandahalfassed
Oddometer: 9,806
Chain adjust tech
For those interested.
I dug it up from back there in the thread... Quote:
02-12-2013, 08:19 AM
#33102 |
Oddometer: 4,572
I am digging your trailer setup Fisherman
02-12-2013, 08:26 AM
#33103 | |
Harvey Mushman
Oddometer: 1,326
But... "The TSB says to do this with the bike on the side stand. I did mine with the rear tire in the air." That is a HUGE difference. I suppose there could be a strange coincidence where the relation of the chain/swingarm pivot/sprockets is the same in both cases, but I'm not willing to gamble on that one. Have you checked the slack with the bike on the side stand, in neutral? How does it compare to your slack with the bike on a center stand, rear wheel fully lowered?
"Coffee first..." Next Trip: didn't get enough...Death Valley "it's a dog's life.............and I love it" |
02-12-2013, 09:50 AM
#33104 | |
oneandahalfassed
Oddometer: 9,806
30bones, I really like the trailer for commuting and for long trips.
02-12-2013, 11:13 AM
#33105 |
Oddometer: 4,572
I love the idea of not spending all this $$ on bike specific racks/luggage. All that would need changing is the mount for whatever bike (I assume). Price it kind of high, but not too bad if you consider what a full line of wolfman or giant loop gear would run.
