Old 02-12-2013, 11:47 AM   #73696
procycle
procycle's Avatar
Oddometer: 2,367
Originally Posted by TinkerinWstuff View Post
Thanks Procycle for the manual cam chain tensioner. Fixed the noise I was getting after installing the high compression piston.
Sweet!
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 02-12-2013, 12:25 PM   #73697
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,992
Recently picked up a pair of Manracks trailer tie-down clamp loops for my DR.
My handlebars are packed with stuff so it's always a challenge to strap down while the bike is up on the trailer and i'm holding on to it.
These bolt to the lower triple clamp and make things much easier.
http://advrider.com/forums/showpost....&postcount=768
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 02-12-2013 at 12:36 PM
Old 02-12-2013, 01:29 PM   #73698
biosci
Tumbleweed54473
Oddometer: 192
Manracks tie down loops
Seems to me that they might work better attached "up side down" to the way shown in the picture.
I think strap tension and normal vibration while trailering would create forces acting to create in a "scizzors-like" rotation.
By flipping them the forces would be more "in line" .
Probably a non-issue. Just thinking...
Getting older & slower, but the passion still exists.
biosci is offline   Reply With Quote
Old 02-12-2013, 02:23 PM   #73699
dickensheets
smprparatus
Oddometer: 280
This is true from a physics standpoint, but if he flipped them it may cut the rubber tubing and let dirt in there. Just thinking also.
dickensheets is offline   Reply With Quote
Old 02-12-2013, 02:37 PM   #73700
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,292
not sure about that but any forward or backward load could cause them to fold over.
I'm loving the idea though.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 02-12-2013, 05:42 PM   #73701
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,255
Originally Posted by Rusty Rocket View Post
Geesh, and I though my tip about writing my phone # on the inside of my side plates was the bomb.
I like it, if I am ride where you ride, I can get free plastic, and then mock the guy with his number on the panels.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 02-12-2013, 05:53 PM   #73702
Jeathrow Bowdean
Oddometer: 418
Easy now. I'm all DR. 200/ 400/ 650. It is easier to keep this thread as 650, and let each class sit in thier own world to prevent mix up of to much going on !!!
From Jeathrow Bowdean in Western Canada PS: I have a few bikes, so it's easy to drift around to visit !!!
Jeathrow Bowdean is offline   Reply With Quote
Old 02-12-2013, 06:26 PM   #73703
Jeathrow Bowdean
Oddometer: 418
And I'd have to say that I was very suprized to see that the DR is gaining more ground up here in Western Canada then the KLR which was the number one selling unit for many years up here. The DR 650 is $6499 in Alberta and the KLR 650 is $6899
Suzuki is becomimg the new dual sport rocket ship of Western Canada.
Old 02-12-2013, 07:34 PM   #73704
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,992
yep i'm gonna swap the reflector brackets and then you can mount em low.
i'll update the pic when i do.
Alaska
Old 02-12-2013, 08:25 PM   #73705
TrophyHunter
Oddometer: 2,240
Manrack tiedowns. I have 'em mounted with the hole at the bottom. Work great but I did bend one just a little by pulling the strap tight instead of pulling down on the handlebars while taking up the slack. I hope that made sense. It sure avoids the problem with finding a place on the bars.
With all the talk about chains, it might be a time to mention again that just because the snail adjusters are on the same number that your chain is straight. Put a string down it or get a http://www.bikebandit.com/motion-pro...FQThQgodM3kAuw
or watch a video on it http://www.youtube.com/watch?v=u7f9y0MFIPY
I didn't do this step and was told by a rider behind me that he could see my rear tire and front tire at the same time. I was "crabbing" to the right. Mine are now marked for the stock 15 & 14 CS sprocket for a quick change over.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 02-12-2013, 08:29 PM   #73706
wavygravy87
wavygravy87's Avatar
Oddometer: 163
Wolfman Gen 2 racks
Hey gents I was wondering if any of you had any comments on the new DR650 "Gen 2" side racks from Wolfman? I'm about to order my first set of racks and I have a choice between the old and new style. Which would you recommend? Some considerations from my personal observations:
1) The Gen 2 seems to mount about 4" more towards the rear of the bike and maybe a fuzz higher than the originals.
2) I have no desire to mount hard cases to the bike, so the added brackets and option of cross brace are of no benefit to me.
3) I will be using Large Rolies and Expedition Dry bags on these.
4) The Gen 2 uses two mounting legs on the rear portion which may interfere with my Kientech exhaust bracket and homemade rack.
Any input? I know either will be the tits, but help me make an informed decision here
You'll never make it out of this life alive...try and enjoy yourself while you can
2009 Suzuki DR650
2013 Yamaha Super Tenere
wavygravy87 is online now   Reply With Quote
Old 02-12-2013, 08:35 PM   #73707
ER70S-2
ER70S-2's Avatar
Oddometer: 6,659
Cool2
Originally Posted by procycle View Post
Actually, ProCycle made it happen...
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 02-13-2013, 01:31 AM   #73708
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,605
Originally Posted by Spirtwolf15x View Post
110km now, running good just a question, as this is my first DR650 and my first "new" bike ever, I can hear my timing chain, it's not "loud", in fact I only hear it if I try to listen to it. I'm wondering what "normal" engine noise is for a DR.
Thanks.
Wait until you put a bash plate on it and you wo'n't hear the timing chain anymore for the typical DR knock that is bounced back off the bash plate. In standard form the DR is almost too quiet...
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 02-13-2013, 02:10 AM   #73709
TrophyHunter
Oddometer: 2,240
Wolfman Gen II
I have the Gen II and no problems mounting with the Kientech bracket (assuming the GSXR can one?). I don't know what your rack is set up like but I have the ProMotoBillet. I ordered the adapter kit from WM.
Interesting point about the front to rear orientation. I didn't notice that when comparing....maybe it's a camera angle thing? I've had great response when emailing or calling WM so a quick contact with them might answer that. It seems odd they'd move the Gen II back but if they did, the reason would be interesting.
I got the Gen II for the flexibility of hard bags if I go that way but I'm currently using the Expedition bags. As you mentioned, no plans for that so Gen I would work fine.
If you get an answer, I'm interested in it.
Old 02-13-2013, 02:24 AM   #73710
Sierra Thumper
Oddometer: 641
Originally Posted by acesandeights View Post
Probably one of the easiest fixes in the interwebs. You need to wear earplugs when you ride.
So true .......that applies to almost every air (and oil) cooled engine
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Times are GMT -7.   It's 12:08 PM.
