02-11-2013, 08:11 AM
#2716 |
Oddometer: 6
RD02 Carburetor replacement
Hello there,
I am the owner of a 1991 NX650 Dominator (RD02). For the longest of time, my carburetor has been giving me an average mileage of 18KM/Litre (now it is 17KM/Litre). A few months back I loaned a carburetor from a friend of mine and saw my mileage jump to 22KM/Litre, with an occasional spike to 24KM/Litre. I had to return the carburetor after a month but with my existing carburetor getting worse and worse with each week, I am now trying to do 1 of 3 things: 1.) Locate a replacement carburetor on eBay (which I have had no luck on) 2.) Ask if anyone knows where to get a brand new RD02 carburetor 3.) Ask if there is a drop-in replacement carburetor I would really any assistance/guidance on all 3 options, thanks! |
02-11-2013, 09:10 AM
#2717 |
Oddometer: 127
I had a hard time finding a replacement carburetor for my NX650 so I bought a carburetor from a 2012 XR650L and put it on. Works like a charm!
02-11-2013, 10:05 AM
#2718 |
Oddometer: 127
Actually I do have the original carburetor if you want it. I replaced it because the pervious owner had put some type of rubber cement or epoxy on the bottom of it. It might still be useable as a whole, or at least the parts would be good.
02-11-2013, 01:46 PM
#2719 | |
Oddometer: 134
1975 Honda CB550 Four 1980 Honda CX500 dual sport conversion 1983 Honda XLV750R 1983 Honda XL600R 1983 Honda CB985FII Bol d'Or 1983 MZ ETZ250 sidecar 1985 Honda XL600LM 1988 Honda NX650 1989 Honda XL600V Transalp 1992 Honda XRV750 SW-Motec 1995 Husqvarna TE610 |
02-11-2013, 04:44 PM
#2720 | |
Oddometer: 400
A common place for the carb to wear is the needle screw holder Which is the brass tube with holes drilled in it to allow fuel atomisation that the needle sits in. The needle wears an oval hole over time. Is the diaphragm still OK and not punctured or torn? What are the main and pilot jets? On the side of the carb will be stamped the model of VE40 you have, you may be able to change some jets and do the carb modifications to make it run better. |
02-11-2013, 06:24 PM
#2721 |
Oddometer: 32
I no longer have my NX, but
thewxman screwed with this post 02-12-2013 at 04:18 PM |
02-12-2013, 12:17 AM
#2722 | |
Oddometer: 400
02-13-2013, 08:15 AM
#2723 |
Oddometer: 127
I just got around to attempting to mount handguards. I have the bolts from the new XR650L, which should be long enough. I compared them to my stock bolts and they are definitely longer. But the bolt that the front brake lever pivots on still is not long enough to go all the way through the handguard. Are the front brake master cylinders THAT different from the NX to the XR? Has anyone else mounted stock XR handguards to their bike? I would have gone with aftermarket, but I have the larger windscreen on and anything else looks like it will hit.
02-13-2013, 07:09 PM
#2724 |
Oddometer: 818
Ok getting ready to pull the trigger on a new carb, which is the best to go with? Sudco or XRonly?
02-14-2013, 01:37 AM
#2725 | |
Oddometer: 11
Same part for many Hondas. Nice "new" fairings by the way! :-) |
02-14-2013, 05:48 AM
#2726 |
Oddometer: 127
The fairings were really nice, other fairings I've bought have been pretty beat up but Henning's could be mistaken for new. Thanks again for your help!
02-15-2013, 09:37 AM
#2727 |
Oddometer: 127
I think I can forget about the handguards for a little while. Today while riding on the highway the bike completely died on me. I assume its an electrical problem, because the bike didn't sputter and die, it just DIED. Like someone pulled the plug. The repair manual says possible faulty CDI, and I've read on this thread about people having problems with their CDI. I haven't taken it apart yet, but I wanted to put this out there maybe anyone had any ideas before I started into it.
02-15-2013, 10:38 AM
#2728 |
Oddometer: 127
I pulled the plug....no spark
02-15-2013, 11:28 AM
#2729 |
Oddometer: 400
02-15-2013, 12:45 PM
#2730 | |
Oddometer: 127
I was tapping it, smacking it, and cursing at it but it doesn't want to work. I thought they used to be really expensive, but I found one at partzilla for $96. I've had dozens of bikes and never had one fail on me. Do they fail often? |
