Old 01-26-2013, 08:08 AM   #31
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,667
Originally Posted by windmill View Post
Having done 2 weeks of commuting and test riding I have a better feel for how the new aircleaner works.
There has definitely been a modest but noticeable improvement in performance and mileage, but as I suspected, a fair amount of the significant gains I initially observed can be attributed to the the ideal cold, dry conditions of the previous week.
After 2 weeks, and 400+km of both dry and and very wet winter riding conditions, I can say the precleaner is working fantastically, the paper filter element has stayed perfectly clean and dry which anybody familiar with the OE aircleaner will know is a very significant improvement.
I am very pleased with the real world results.
And the MPG improvements are ?
Thanks,
Vince @ SWFL or WNC 2001 Kawasaki W650
2012 Dong Fang DF250RTB
2013 Sky Team ST125-8A 2013 Sky Team ST125-6B
2013 Ice Bear PBZ110-1P sidecar
2015 Ural cT
Bar None is offline   Reply With Quote
Old 01-26-2013, 09:55 AM   #32
windmill OP
windmill's Avatar
Oddometer: 4,084
Thanks,
After 3 tanks of gas, maybe 3 mpg?
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill is offline   Reply With Quote
Old 01-26-2013, 12:14 PM   #33
Heyload
Remastered Classic
Heyload's Avatar
Oddometer: 8,383
Allow me to add my compliments to some amazing fab work!
"Would you care for some left-over bacon?"...said no man, ever.
When life gives you melons, you might be dyslexic.
Heyload is offline   Reply With Quote
Old 02-13-2013, 08:02 AM   #34
jegarh
jegarh's Avatar
Location: Eagle Pass, Tx (the actual edge of the world)
Oddometer: 35
Trabant air filter
I have been looking for the filter you used. Is this the same one that is used for the Trabant 601?. That one looks like it has an opening only at one end. Did you open the other end? Or did the one you used have and opening at either end?
Intelligence is genetic, stupid is an acquired skill.
jegarh is offline   Reply With Quote
Old 02-13-2013, 08:12 AM   #35
jegarh
jegarh's Avatar
Oddometer: 35
another question
Sorry to keep pestering you, but where did you get the neat little rubber "gaskets" the plug inot the ends or the air filter?
Old 02-13-2013, 08:51 AM   #36
windmill OP
windmill's Avatar
Oddometer: 4,084
Its the only filter I have seen listed for a Trabant, and it is open at both ends. The gaskets came from a Euro spec Ural Wolf aircleaner, cutting some from closed cell foam would be just as good.
Almost 1000 km since I started running it, and have exposed it to the worst possible winter riding conditions, the filter still looks like new. The same km's and conditions would have required servicing the OE filter several times.
Old 02-13-2013, 09:04 AM   #37
jegarh
jegarh's Avatar
Oddometer: 35
Thanks,
I hope I can do your efforts justice. I have a high bar to clear.
Jerry
Times are GMT -7.   It's 04:00 AM.
