Old 02-13-2013, 03:20 AM   #16021
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Originally Posted by medisyn View Post
Should I use/order new gaskets for the clutch cover and between the engine and cover? Or are they reusable?
New gaskets, always & everywhere. If the old ones come off fine keep them but use for emergencies only. Mind, o-rings may be used quite a few times, but you may want to have a spare one or two.
JM2008 is on the button with water in the floatbowl. Clearly this man is experienced in this, and now don't go ask him how he knows it
BuRPsa is offline   Reply With Quote
Old 02-13-2013, 09:28 AM   #16022
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,064
Originally Posted by atravlr View Post
I do have a small in line filter.
Change it for a new one or throw it away and don't put one back on.
larryboy is online now   Reply With Quote
Old 02-13-2013, 10:32 AM   #16023
crypto666
Oddometer: 1,391
I pulled a cheatgrass seed out of my recently purchased CRF float bowl the other day. How that could work its way inside I have no idea, but I like running a filter, and carry an extra bec ause sometimes they break.
Maybe the PO installed the grass seed as some performance mod???
crypto666 is offline   Reply With Quote
Old 02-13-2013, 02:44 PM   #16024
ride4fun562
ride4fun562's Avatar
Oddometer: 210
woohooooo Cleaned my bike good for once, got rid of two pesky oil leaks, andddddddddd did a valve adjustment by using the method where you let one side go down and do the other, seems to be spot on so I wont be going back to the hassle of finding tdc, happy day.
ride4fun562 is offline   Reply With Quote
Old 02-13-2013, 03:15 PM   #16025
kjazz
Oddometer: 204
My bike stuttered and stalled, .......
Sure sounds a lot like what happened to a buddy of mine recently. His ran like a champ then stuttered and stalled. kick, kick, kick, kick, kick, start........ then same. Fuel system, carb, hmmmmm......? Hey why not throw a new plug in...? It worked !!! Looking closely at his old plug, it appeared to have a few small cracks in the insulator. Cheap fix if it works.
kjazz is offline   Reply With Quote
Old 02-13-2013, 03:41 PM   #16026
Shibby!
Oddometer: 1,666
I've never been able to get that to work.. I fully understand it, but it seems to never get my valves right.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 02-13-2013, 07:31 PM   #16027
ride4fun562
Oddometer: 210
Originally Posted by BuRPsa View Post
"Valve adjustment for noobies"
'Ere ya are mate, and note this is a com-ple-te-ly different procedure than Honda prints in their manual - however a lot more easy:
Make sure the engine is cold.
Take off tank, and wash the engine's top & framebits as the bare minimum.
Take off the valve covers first, then take out plug (so the small bolts cannot fall into the cylinder - duh).
Put bike on a stand (jack, not sidestand), and put it in 5th gear.
Rotate the rear wheel forward - on this, do not EVER rotate it backwards or allow it to turn back (block it with a piece of wood through the spokes or whatever) as even a little of this will mess with the auto-decomp system on this bike which will lift an exhaust valve!! So no 'back', nothing!
Turn rearwheel fwd until you've convinced yourself that first the intakes go down, then up, and next the exhaust valves do ditto (hey, you said 'noobies' )
Turn even more forward, but maybe slower this time, until you actually notice that at a certain point, just when the intakes come up again, the exhaust valves ALSO start to move - which is correct, any 4stroke does this, not to worry.
Now rotate the wheel slow, very slow, until the exhaust valves are just about at their deepest point... then stop rotating, and block the wheel if necessary.
Now adjust the intake valves as per below.
To adjust the exhaust valves you turn (again, always forward only) the wheel until the intake valves are somewhere at their deepest point. As a sidenote, the exhaust valves are more difficult to reach on this bike, less handspace available.
Adjusting valves.
Valveplay is to be: Intake: 0.15mm (0.006"), Exhaust 0.20mm (0.008").
The valves to adjust will have some play, they are loose, which can be felt, so check this, move the rocker up & down - see? If no play make sure (by rotating rear wheel forward, see above) that the other valves are quite a bit down if not fully down. If this is the case but you still feel no play then know you did postpone adjusting for too long, the play's gone... which is a bad thing.
However, there normally is a bit of play.
Take the correct-thickness feeler gauge and make sure it is spotlessly clean - then try to slide it inbetween rocker & valve. They slide-in best sideways, but find your own best way.
If it goes in - just - and feels not too tight but also not too loose (this is experience which noobies do not have, sorry, however they can learn this by doing all this often) then that valve is set perfect.
If either too loose or when the feeler gauge won't go in, undo the locking-nut with a ringspanner (10mm, spotlessly clean - and only morons use open ended spanners) whilst holding the actual adjuster with a well-fitting screwdriver (which also is spotlessly clean). The idea is to loose the nut whilst the adjuster stays where it is. Once loose wind the nut a half turn up (more loose).
Now turn the adjuster with the screwdriver-only (yes, the nut will also turn) until the feeler gauge just goes in & and can be slid to & fro - just, tot too loose, not too tight.
Now hold the adjuster into position with the screwdriver whilst you turn the nut tight - of course by sliding the screwdriver through the ringspanner. Watchitnow, this only sounds easy, but in practise the adjuster wants to turn with the nut when tightening it - and it may not turn!
Try, fiddle & try again, but get the nut locked whilst the feeler gauge still just slides inbetween the adjuster & rocker. If this is the case then the valve is set correctly... so proceed with the other one(s).
How much torque for those nuts? Never mind the manual, they must be tight whilst not over-tightened (refer remark above regarding experience), but basic gutfeel will get you there. MIND though, it is less than the force you needed to loosen them in the first place! There is oil now inbetween you see, so this lubes the lot now. Apply a bit less for tightening than for taking them loose.
If this all reads daunting then relax, there's a way to check yourself.
Say you 'think' you set the In's to 0.15 - because this size feeler goes in.
Good - does the 0.20 also go in?
It should not, so if it does re-adjust that valve, but a notch tighter this time.
Got a 0.18 feeler in the set? This one should not go in either, however with enough force one can do anything... or cut your fingers
Once you get handier with this, here's an idea. Next time, before you loosen the nuts, you first measure what the actual play is! You may want to write this down for later, may come in handy. Valves 'move' you see, they normally become tighter over time (due to wear), and at a certain point in life this goes quick to fast even... and this point you want to notice, before it get really expensive. This is the time where you take the top off, however, with your new bike this is a loooong way to go still.
Have fun doing this. If you really will be doing this for the first time I'd advise to, after having adjusted all, rotate the wheel again a bit, and then check your own settings. If done correct it all will be fine, but this will give you piece of mind. Also check all nuts before you close her up - and if you turn one then you must re-adjust that valve again.
Old post but great for people like me , if you're still around can you go on to the next part of taking the top off and replacing the usual parts (for dummies) because I'm pretty sure my right intake valve has seen better days. It is almost all the way backed up on the adjustment so much that I'm running out of adjustment which can only be bad right?.
Old 02-13-2013, 08:34 PM   #16028
Mur
Wheee!
Mur's Avatar
Oddometer: 21
The grass seed mod is one of the best performance mods i've done to my old CRF..
Mur is offline   Reply With Quote
Old 02-13-2013, 09:10 PM   #16029
Shibby!
Oddometer: 1,666
I've seen that happen on quite a few bikes.
Flies in when filling gas. Not sure how it gets past the petcock filter but those things aren't very dependable.
Actually, the last time that happened was in Guatemala when a guy I was traveling with had his KLR start acting up, sure enough a little seed of some sort stuck in his pilot jet.
Hence the reason I run filters. Cheap insurance and never had an issue with the filter itself. I'm sure you guys are stick of me quoting mileage, but I've never had an issue of this sort running a filter, or had to service the filter itself.
Old 02-13-2013, 09:16 PM   #16030
mdlak
Oddometer: 201
Fork service
Couldn't help myself. Doing the Borynack fork mods. Hopefully it works. Waiting for seals and shims.
mdlak is offline   Reply With Quote
Old 02-13-2013, 09:37 PM   #16031
sintax
Oddometer: 495
Trust me, you'll be insanely happy...
sintax is offline   Reply With Quote
Old 02-14-2013, 09:26 AM   #16032
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,064
I'm not against running a fuel filter, but when I do it's a big one that will pass fuel even if it's fuel of junk. I don't like those tiny metal mesh ones that people use, you can't see when it's clogged and it doesn't take much to clog it, just a few drops of water can clog it and you'll never see it.
Big filters for me if I run them:
Old 02-14-2013, 10:17 AM   #16033
crypto666
Oddometer: 1,391
When the happiness wears off from the fork tuning, do the shock and it will all come back again. I had to wait a couple years between doing the front and rear so that I could fully exploit my happiness.
Old 02-14-2013, 10:19 AM   #16034
crypto666
Oddometer: 1,391
I think rebuilding the head is for the advanced students. I sent mine to XRSonly. Might as well make the valves bigger while you are at it.
Old 02-14-2013, 10:21 AM   #16035
sintax
Oddometer: 495
Yea, i never considered that they would not be done at the same time...
Thats like a chick getting only one tit enlarged... certain things are meant to be done in pairs!
Times are GMT -7.   It's 05:55 PM.
