Old 02-12-2013, 08:52 PM   #1606
Saget
Not quite a full house
Saget's Avatar
Oddometer: 388
A friend of mine is really into these R/C paragliders. He has several of them, most powered by O.S. 40's, one electric. The chutes are about a 6' span and are hand made by a guy in Florida. I can get the info if anyone is interested. Very slow, gentle flyers, using just throttle and rudder.
_______________________________
http://gbergimages.smugmug.com
Saget's Rides:
2008 Kaw Connie14
2005 Kaw KLR650
2003 Hon CRF450R
Saget is offline   Reply With Quote
Old 02-12-2013, 09:59 PM   #1607
Tindjin
Old No. 7
Tindjin's Avatar
Oddometer: 587
Send a message via AIM to Tindjin
Yea what is the company?
-Joey
Do not seek death. Death will find you. But seek the road which makes death a fulfillment.
--Dag Hammerskjöld
Tindjin is offline   Reply With Quote
Old 02-13-2013, 10:47 AM   #1608
dodgerdodger
Acountabilabuddy
dodgerdodger's Avatar
Oddometer: 1,112
Originally Posted by Tilt2turn View Post
It's time to learn a Collective Pitch heli!
So far with 5 flights there has not been any damage and only a minor crash. I am using a DX7S transmitter and have some negative pitch dialed out. My previous heli is an mCX2, so the new one is crazy fast comparatively. I was debating getting a flybarless fixed pitch or the CP. I like my choice so far.
Ah yes, the MCPx. Just got one over the holidays and am having a fricken blast learning how to fly this heli. I actually just went out and bought a fixed pitch MSRx to help learning banked turns. These things are super fun......
2000 XR650R
2001 WR426
2003 WR250F (Wifeys...)
2005 YZ250F
2007 GASGAS 300TXT PRO
2009 KTM 300XC-W
dodgerdodger is offline   Reply With Quote
Old 02-13-2013, 11:28 AM   #1609
CousinLarry
Ridin Dirty
CousinLarry's Avatar
Oddometer: 335
I'm going to go pick up the new double brushless MCPX this weekend... Yesterday was my burfday and wifey is bringing me on an RC shopping spree on Saturday
2000 KTM 200 EXC
CousinLarry is offline   Reply With Quote
Old 02-13-2013, 12:24 PM   #1610
02TAC OP
02TAC's Avatar
Oddometer: 4,669
Hobbyking has them
http://hobbyking.com/hobbyking/store...dProduct=30801
http://hobbyking.com/hobbyking/store...dProduct=30790
Yea, whatever.
02TAC is offline   Reply With Quote
Old 02-13-2013, 01:11 PM   #1611
CousinLarry
Ridin Dirty
Oddometer: 335
I threw up a FS add for my Mikado Logo 400 helicopter if anyone is looking for a sick electric!!!
http://www.advrider.com/forums/showthread.php?t=862917
2000 KTM 200 EXC
Old 02-13-2013, 01:49 PM   #1612
02TAC OP
02TAC's Avatar
Oddometer: 4,669
and on the third full throttle launch in heavy sand the right rear drive shaft failed. The rears needed replacement anyway.
Yea, whatever.
Old 02-13-2013, 04:10 PM   #1613
Pottz
Oddometer: 62
Heng Long Tiger Tank
I am hoping one of you RC 'nutters' can help me as I have zilch experience with anything RC. I just bought the 1/16 scale Heng Long Tiger Tank via on-line (awesome model) - but it won't work....yes, batteries are fine on the control box and indicates power, I recharged the battery for the tank itself....connections all good....but nothing....I noticed that the antenna is missing from the box and there is just a brass/metal stub at the back of the tank where it is supposed to go....would this be the issue????? Hope someone can help....
Current: 2011 DR650SE; 2001 XT250 'Gentle Annie'
Past: 2010 DR650SE; 1979 Yamaha XT500; 1981 Yamaha XT500; 1978 Honda Elsinore 250
Pottz is offline   Reply With Quote
Old 02-13-2013, 05:07 PM   #1614
02TAC OP
02TAC's Avatar
Oddometer: 4,669
Odds are the antenna is the issue.
Yea, whatever.
Old 02-13-2013, 05:16 PM   #1615
Saget
Saget's Avatar
Oddometer: 388
My friend says his all came from http://www.seabreezeparachutes.com/. He's very happy with the product and service.
Saget's Rides:
2008 Kaw Connie14
2005 Kaw KLR650
2003 Hon CRF450R
Old 02-14-2013, 06:24 AM   #1616
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 5,514
EDIT! I re-read that and noticed you said the antenna is missing completely. When I bought mine the antenna was lying in the carboard box loose. Check there first as it may not be in the styrofoam box!
Is it the FM (crystal) version of the 2.4Ghz version?
If it's the FM, check that the crystals are both seated in their sockets. Also, if you unscrew the seven, if I recall correctly, screws on the underside and disconnect the smoke tubes the top of the tank will separate from the base. Be careful not to pull on any wires.
Then you can access the turret and make sure the wire going to the antenna is terminated and not loose or broken. Trace it back to the control box inside the tank.
06 KTM 950 Adventure S
08 Dodge 2500, QC Shortbed, Cummins 6-speed auto, Big Horn
DakarNick is offline   Reply With Quote
Old 02-14-2013, 12:41 PM   #1617
gots_a_sol
Oddometer: 252
Selling my Blade 120 SR and my Traxxas mini Slash
http://advrider.com/forums/showthread.php?t=863160
02 drz 400s/m
09 Husky wr150
gots_a_sol is online now   Reply With Quote
Old 02-14-2013, 12:53 PM   #1618
FPGT72
Oddometer: 3,958
I have one of their PzIII models, and I do enjoy it quite a bit......however they are built to a price point.
Does the tank even power up, the lights should blink when you turn on the power switch on the tank. If you don't that is your first problem. If you do get your lights blinking you have to push the engine button to actually start the tank...after that it should go.
I run mine without the antenna on the tank all the time....while the range is not great it should go about 30-40 feet away from you.
If you still have no luck and can't send it back check out the tank forums on rcgroups.com and they might be able to help you...you might have to dig into it, I have read about loose connections inside the tank itself....I have had mine apart while is it not something I would want to do every day, you can do it if you are carefull.....they are quite fun.
[FONT='Arial','sans-serif']Calling an illegal alien an 'undocumented immigrant'
is like calling a drug dealer an 'unlicensed pharmacist
[/FONT]
FPGT72 is offline   Reply With Quote
Old 02-14-2013, 02:42 PM   #1619
Pottz
Oddometer: 62
Thanks everyone for your help - no I checked that box fifty times re the antenna - and no lights blinking at all...so must be a power issue somewhere - job for tomorrow!!!!
Old 02-14-2013, 04:22 PM   #1620
Saget
Saget's Avatar
Oddometer: 388
As if I needed more airplanes... I just picked up these little treats from a friend who was downsizing his collection.
It's an F4U Corsair, 65" span, an ARF by Hangar 9. And, an Extra 300 built from a kit, although I haven't figured out which one yet. 58" span. Whoever built it did a nice job, but I want to make a few mods before I cover it. Primarily bigger control surfaces.
Both are supposedly sized for a .60 2-stroke. I want to go electric, and I think I want to go a little bigger. Perhaps something like this for both: http://www.graysonhobby.com/catalog/...esc-p-328.html
Hangar 9 says the Corsair flies well with an E-Flite Power 60, but that's because Horizon Hobby owns them. I've become rather anti-E-Flite lately. Any other suggestions for a powerplant?
Saget's Rides:
2008 Kaw Connie14
2005 Kaw KLR650
2003 Hon CRF450R
Thread Tools
Times are GMT -7.   It's 10:58 AM.
