Old 02-14-2013, 08:25 AM   #3121
Ned Kelly
Oddometer: 27
Originally Posted by tallguy-09 View Post
Picture of 2x M64 mounted to a bike, anybody?
I'm curious to see the size in relation to the motorcycle.
In the meantime, go get an empty full size kleenex box. It has nearly the same frontal dimensions as the light. Cut the box down to 3.5" length and you'll have two mockup lights (from one kleenex box) to stick on your bike and experiment.
To get you started, dimensions are:
4.25" (108mm) x 4.25" (108mm) square frontal area, depth: 3.5" (89mm), 4.75" (121mm) from mount to top of light.
Ned Kelly is offline   Reply With Quote
Old 02-14-2013, 08:37 AM   #3122
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Please do that 4me
tallguy-09 is offline   Reply With Quote
Old 02-14-2013, 09:00 AM   #3123
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Here ya go. BMW F650. You won't care how big or small or color when you turn them on, OMG!
Old 02-14-2013, 12:58 PM   #3124
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
OK great, I'd definitely need 2 of those for adequate illumination
Old 02-14-2013, 01:08 PM   #3125
cug
Oddometer: 4,858
I'm certain you can do better illumination with a set of these:
cug is offline   Reply With Quote
Old 02-15-2013, 10:55 AM   #3126
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Those look a bit dim
Old 02-15-2013, 11:06 AM   #3127
guavadude
de-composer
guavadude's Avatar
Oddometer: 771
When comparing the new square models with the round ones, what are the main differences?
From the specs it looks like they use the same LED and have the same current draw. Is it just a better reflector design?
guavadude is offline   Reply With Quote
Old 02-15-2013, 12:15 PM   #3128
ewagman
Oddometer: 28
Could be SuperBowl lights
Perhaps you should talk to them, sell them some low current draw lights that work.
ewagman is offline   Reply With Quote
Old 02-15-2013, 03:30 PM   #3129
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Reflector design and physical size.
Old 02-18-2013, 10:04 PM   #3130
Landro
Slippery when wet
Landro's Avatar
Oddometer: 29
Thumb Holy Snap!
Ordered Feb. 8 (late in day). Received today (Feb. 18)... on the west coast of Canada. An entire continent and one international border in 5 business days. Unbelievable. Thanks John!
I still have no idea how I'm gonna mount them on the NG KLR, but at least I have them to play with. Great service!
I reject your reality and substitute my own. - Adam Savage
Landro is offline   Reply With Quote
Old 02-19-2013, 01:40 PM   #3131
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Thanks for your business.
Anyone with the lastest gen KLR post up up some mounting pics for this man
Here's what I have.
Old 02-19-2013, 03:05 PM   #3132
WindSailor
WindSailor's Avatar
Oddometer: 648
Just ordered 2 of your M64's heading for the west side of the states.I'll see what I can do in mounting them
WindSailor is offline   Reply With Quote
Old 02-21-2013, 06:15 AM   #3133
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Thanks for your business. Perhaps Tallguy will get his wish after all
Pictures would be much appreciated.
Old 02-21-2013, 06:31 AM   #3134
scooterGdawg
Oddometer: 531
here are my pics of the ADV 60's
http://myscootlife.blogspot.com
scooterGdawg is offline   Reply With Quote
Old 02-21-2013, 09:54 AM   #3135
dvgonzo
dvgonzo's Avatar
Oddometer: 329
About 3-4 years back I built one of the kit lights from ledsupply and was so impressed with it I machined new housings and built a few more redesigned/finned housings using larger LED drivers that up the output by about a third. Amazing how much light can come out of that small of a unit! My whole light is two inches in diameter but the actual led is about 1/8 inch diameter with a .8 of on an inch diameter lens!
A couple months back a buddy and I did a side by side comparing my light to these Monster lights. Although they both put out about the same amount of light the Monster's have a lot more focused beam where mine are more of a flood type. Hating to be out done I immediately orderd a couple of the Monster's as well.
Two of these on the front of a scooter is WAY overkill! I only added one!
I was coming home the other night after finally taking the time to aim it correctly and was on a secondary highway. As I crested a hill that is about 3 miles distant from the next hill a car came over that distant hill and even at three miles he flashed his brights for me to dim mine! YEAH, they are THAT bright!
Use caution if using them in any non off road application though, as I am positive they would get you a ticket.
dvgonzo is offline   Reply With Quote
Times are GMT -7.   It's 07:50 AM.
