02-13-2013, 03:53 PM
#661 | |
Amusing Myself Again
Oddometer: 578
My girl's getting white turn signals for Valentines. If only the damn mailman would cooperate! To hell with $80/doz roses, I want something that will last longer than a week.
Life is a rollercoaster........and I'm not strapped in!
02-13-2013, 04:17 PM
#662 | |
Procrastinators
Oddometer: 5,772
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
02-13-2013, 05:24 PM
#663 | |
Oddometer: 3,430
![]() I was thinking in terms of thermal conductivity ... not electrical ... I know some epoxy resins are designed with thermal conductivity in mind, but for most formulations nobody cares. I wish I had asked more questions about the potting compound Westinghouse used .... but that was a long time ago ... |
02-13-2013, 05:29 PM
#664 | |
Oddometer: 2,752
Erling |
02-13-2013, 05:30 PM
#665 | |
Procrastinators
Oddometer: 5,772
02-13-2013, 05:33 PM
#666 |
Oddometer: 3,430
02-13-2013, 05:36 PM
#667 |
shut up and RIDE!
Oddometer: 703
What a good idea. Flowers are a waste of money!
Stephanie '08 BMW F650GStwin (Jutta), '01 Suzuki DR650 (Patsy Q), '11 VW Golf TDI Wagon "It's a jet-pack, Michael. What could possibly go wrong?" Gob Bluth in Arrested Development, season 3, episode 7. |
02-13-2013, 05:50 PM
#668 |
Oddometer: 781
Re the F650 stator mentioned earlier in the thread, there are differences between the F650 and F650GS
The F650 is only 280 watts and the GS is 400 watts, some of the Co's offering stators get confused and lump them together On the GS we have seen stators cook and epoxy break up and go through oil ways so I would not expect using one from the GS would be a good idea |
02-14-2013, 01:49 PM
#669 |
wanderer
Oddometer: 417
It is almost up to 40F here today so I opened up my f650 to look at the stator.
Yep it is pretty toast..black. Pretty much like Emmmbeedee's wife's. Mine has not failed but I order a Electrosport today..mainly because they ship with connectors on. when looking at the black stuff on the stator...I could not help but think of cabonized oil....not just the stator epoxy failing. The carbonization is clearly worst on just some of the poles. A wild an no way substantiated though that oil carbonizes on overly hot stator, build up the oil based carbon crud which act as insulation and accelerates the over heating process till hard failure occurs. could this mean that using more temperature resistant full syn oil would delay stator failure? is this a case for only running full syn oil in the f800 engine? |
02-14-2013, 02:10 PM
#670 | |
Oddometer: 578
I had heard that the early 650 singles were lower wattage(ie. carbureted versions). Both my 650CS and GS manuals for the later injected bikes rate the alt at 400W/14V. I'm no expert but I believe a lower W stator would have less windings or like on Honda XR R's, some poles aren't wound where the XR L's are fully. It was a trick to rewind the whole stator for more output on thr R's. In any case, when the time comes I'll compare side by side. In an emergency, I'll take those lower watts over pushing.
02-14-2013, 02:23 PM
#671 | |
Oddometer: 2,752
Erling |
02-15-2013, 03:51 AM
#672 |
Oddometer: 3,430
I agree, looks like only the "bottom" coils have the caking
(if I'm looking at it correctly ... the wires come out the top/back of the side cover IIRC?) Which would make those coils hotter making them cake more ... etc.... How high up in the side cover does the oil level come when the bike is running and on level ground... Compared to the height of the stator ... I would think the oil level would not come up high enough to even partly submerge the stator ... but would have to hold the dip stick up to the side of the bike and "draw" the level lnie around the crankcase to be sure .... Anybody know off hand? Before he shoved off to work for the competition Joel had made a "stator detunning" modification that he guessed would shave ~100W off the output of the stator ... which would still leave adequate output for use w/o heated clothing and would sure keep stator cooler ... but I don't think we'll ever find out how well that worked out ![]() Maybe as a maint. item we need to clean the gunk off the stator every 12K miles or so? Sheezzzzzzzzzz |
02-15-2013, 12:03 PM
#673 |
Where we riding to?
Oddometer: 3,497
I don't own an F800 but had a Honda CBF1000, which are known to fry stators on a regular basis, mine fried at 22,000kms. I always run Amsoil full synthetic and that's what was in the bike from it's first service so I don't think synth is going to save the stator. My solution on the CBF was to install a CompuFire R/R along with the new stator and that setup ran to 38,000kms when I traded in the bike so not sure if that second stator is still running or not.
02-15-2013, 12:11 PM
#674 |
Oddometer: 1,120
Yeah I bit the bullet and went Compufire on the new stator and redesigned flywheel! $1,000 later I better not see that stator burn up for at least another 60,000 miles.
Current Stable: 2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS 2007 Husqvarna TE610 , 2003 KTM 525 MXC |
02-15-2013, 12:18 PM
#675 | ||
Oddometer: 578
So any oil would be flung centrifugally (today's word) all over the hot stator, which just screams as anyone would in that situation. The only time the oil level would possibly submerge it is when the bike is hot, upright and off. Further theorizing necessary on your part. I'm more of a criticizer. Quote:
