Old 07-23-2011, 06:36 AM   #16
Lepapehermann
Oddometer: 1
Originally Posted by D0N View Post
I will try that thanks
Hi Don,
Did it worked??? I have a similar problem with my Honda Élite 150 1985.
Lepapehermann is offline   Reply With Quote
Old 02-16-2013, 03:28 PM   #17
ride4321
ride4321's Avatar
Oddometer: 1,863
Originally Posted by btcn View Post
Yea that is good advice bbishoppcm gave you. I think that'll fix the problem.
8K miles is about average. Some get about 15K out of theirs.
BTW its a good idea to have a backup belt with you on longer rides once the belt starts getting to higher miles. The belt can be changed out on the side of the road if you do it this way:
[IMG][/IMG]
It worked for me. If you do it the regular way taking off the CVT plates you'll need a good impact wrench to do it right. Also make sure you tighten that front drive plate's nut good, it can fly off if you don't tighten it down.
Crap, that's fantastic. I just spent over an hour trying to get my belt back on. I'm going out to see if that works on my 125. I hope it does. I'll also clean off any glazing on the clutch and flywheel as I also have a squeal I can't seem to fix.
Thanks for that great tip.
Don't you know there ain't no devil, it's just God when he's drunk.
Tom Waits
ride4321 is online now   Reply With Quote
Old 07-24-2013, 11:29 PM   #18
wintonio
last of the Dum Dum Daze
wintonio's Avatar
Oddometer: 1,654
So, I changed the belt, it squealed, and today I took it back apart, pulled the belt off, sanded the front / drive pulley, no problem. The rear pulley didn't really take to sanding, even with 320 grit. Took it out on a test spin, maybe 8 miles. First 4 miles were fine, but it stayed squealing again.
So, do I really need to take it back apart and sand the rear pulley, or will it burn in after more miles and stop squealing?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
wintonio is offline   Reply With Quote
Old 07-25-2013, 09:01 PM   #19
fullmetalscooter
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 2,859
At this point you offer up a 6 pack of beer and see if any scooter gods whom live around can help out .
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Times are GMT -7.   It's 02:12 PM.
