02-16-2013, 09:13 PM
#46 | |
Mostly Harmless
Oddometer: 1,714
My first big bore will be the 351 kit on my KLX250S... hoping to do that in another month or two. BUT, sadly, there are no cams for it yet, so all I can do is the big bore. There IS a big-valve option which I will do, though.. it's $400 extra. They're supposed to be working on cams for it (it takes two) but nothing out yet. Rob
'96 Suzuki DR650, '10 Kawasaki KLX250S, '01 Yamaha FZ1 The Lane Sharing Works Blog | My SPOT Page |
02-16-2013, 09:31 PM
#47 |
Oddometer: 9
Man this is an exciting build, I don't even own a dr650 haha (klx250sf) I love the idea of big bores on bikes, its so simple and easy power!!! I come from working on big block trucks and such, you want a bigger bore? tear down and send to machine shop, what a pain...this is so simple I love it!!!
02-16-2013, 09:40 PM
#48 | |
Oddometer: 143
Congrats on a great project and way to wrap it up with the 650 count
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course ![]() http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
02-16-2013, 09:51 PM
#49 |
Oddometer: 1,169
02-16-2013, 09:54 PM
#50 | |
Mostly Harmless
Oddometer: 1,714
Rob
02-16-2013, 10:02 PM
#51 | |
Oddometer: 1,169
doug s. |
02-16-2013, 10:05 PM
#52 |
Mostly Harmless
Oddometer: 1,714
Dunno... for what they're charging it sure as hell better. :)
Rob
02-16-2013, 10:12 PM
#53 |
Oddometer: 144
Any idea of how much power the $1200 ported head with big valves would give vs. the stock head? Assuming you went the full-boogie with the 790 kit, stage 2 cam and so on...?
If it's only 5-8hp...? That's a lot of dough for little gain. I don't know how much hp it would end of giving over the stock head, but it had better be a bunch otherwise that's some expensive HP..... |
02-16-2013, 10:15 PM
#54 | |
Mostly Harmless
Oddometer: 1,714
Rob
02-17-2013, 03:46 AM
#55 |
SE Asia adventure tours
Oddometer: 589
Thanks for the write up! That makes this 650 seem like a exciting road biased dual sport! I'm wondering if it rides at all similar to the DR800? I used to ride one of those a bunch as a mechanic I used for my KTM LC4 had it as a loaner bike when he worked on the KTM.... which was all the time!
![]() I preferred the DR800 on the road - much smoother! Sorry to hear all that stuff on your 1st post re: the trails being closed! To be honest I'd rather have a crappy bike and amazing places to ride than the reverse... |
02-17-2013, 05:57 AM
#56 | ||
Oddometer: 739
That's also my plan for the cam, probably next winter. I'll probably do the stage 2 as well. I just want to ride and this snow is killin me!!!!!!! We just got another inch last night. As for the carb: When I did the Hayabusa muffler I had to change my set up to accommodate it. My first ride at 50mph+ I couldn't go full throttle without a major bog. I went with one step up on both the main jet and the pilot jet. I left the needle in the 2nd notch down. Went riding, and it worked well, all around better acceleration and nice sound. I felt good till I got to the pump. 42 mpg. This was a 6 mpg drop. Could be the colder weather, winter gas, or riding harder, never-the-less, I never see mileage that low. So I did some research and read that If I raise the clip a notch, I can get better mileage. I also changed the pilot jet back to the stock setup from procycle. I did that but I noticed on some rides I would have a surging at 30-40 mph. I also adjusted the fuel screw on the lean side, and starting was pretty hard. (one of the reasons it wouldn't start right away) When I got this kit all together and started it, I let it idle for a while at a higher rpm, and I noticed my header was glowing red. I read that this was a symptom of being too lean. So I put the clip back to its original position and left the jets alone. I adjusted the fuel screw as well to 2 turns out. Now is seems fine, and only time and some riding will tell if it's okay... and that brings us back to the original problem.. this snow needs to melt!!!!!!! I'm really interested to see the mileage I get with this kit now…
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb. 1985 Yamaha CA50 - My Hot Rod 2009 Piaggio BV-250 - Escusi, Babba be bo-bee |
02-17-2013, 05:59 AM
#57 |
Oddometer: 739
Forgot to mention: I have the stock header. I would like to find a dyno now and see what I'm running, but I never got a base line.
02-17-2013, 06:30 AM
#58 |
Oddometer: 1,485
Hp
What's a stock 650 DR have for HP?
KTM 450 EXC Suzuki DR650 Kawasaki KLX250 "Single Trac is like Scotch, you have to aquire a taste for it!" |
02-17-2013, 06:49 AM
#59 |
Oddometer: 739
02-17-2013, 07:15 AM
#60 |
Oddometer: 550
Did you notice any increase in engine vibration with the 790 kit installed?
