02-16-2013, 05:09 PM
#6916 | |
Oddometer: 470
'87 XR600R, 17's and fully black |
02-16-2013, 06:28 PM
#6917 |
Oddometer: 470
Thanks for the PM Royal !
Anyone familiar with the baking process? Website sorta says that the heating of the engine will work as well...
02-16-2013, 10:32 PM
#6918 |
Oddometer: 3,956
they say the same for headers...but I think we all know how that ends
I did that the first time...painted them, after etching the headers clean as a baby butt...then sprayed 10 thin coats with time in between to set... put headers on and cycled the engine, 2 mins, then a bit more worked great for a month then all of a sudden all hell breaks loose one ride and I got crusty caked headers nice jajajja let us know how it works out good luck |
02-16-2013, 10:48 PM
#6919 | |
Oddometer: 96
Yeah I've used various heat resistant paints from a couple of different manufactuers: 3M, Duplicolour and VHT. I preferred 3M but can't seem to find it in my local auto store (Supercheap) but really they are all very similar. I sprayed my entire frame with some of this stuff actually and left it in the sun for 2 weeks (my only way of 'baking' it) and it seemed to work very well, doesn't chip, flake or rub off. ![]() I also have painted my entire engine with some of the duplicolour engine enamel (both the primer and the topcoat) and it has worked fantastically as you can see in the photos. Obviously I couldn't put the entire motor in the oven so I just ran it for a bit and seemed to bake on fine, as I can't scratch this with my fingernail or with with moderate force from a screwdriver. I was most impressed with the way it seems to be holding up on my magnesium sidecovers, although I did an extensive amount of prep: degrease, wash, sand, wipe down with acetone etc. Before: ![]() After: ![]() ![]() Probably doesn't help you but I have found the muffler paint to also work ell (on the muffler obviously). Finally I have also used some of the brake caliper paint, although I'm fairly sure it is all the same sort of stuff, and I bake all those parts and it seems to be fine against brake fluid etc if it is wiped off quickly. Following the instruction I preped like I normally do (see above), primed it using some left over engine enamel primer, and then hit it with two coats of the caliper paint. Waited about an hour till it was dry to the touch and chucked it all in the oven at 200 degrees (Centigrade, not Fahrenheit). Smelt funky but luckily I had waited till my housemates had left and I wacked the extraction fan on and an hour later pull them out. ![]() Long story short: I reckon this stuff is pretty good. As long as you cure it some way, such as in the oven or running the engine, it should turn out great. In Australia this paint is realllllly expensive though, but not sure if this applies over there. Hope this helps, John |
02-17-2013, 05:31 AM
#6920 | |
Oddometer: 470
Hey John, Thanks for the detailed reply, that worked out nicely ! How many coats did you use on the engine parts? Cheers !
'87 XR600R, 17's and fully black deejay_xr screwed with this post 02-17-2013 at 05:49 AM |
02-17-2013, 07:10 AM
#6921 |
Oddometer: 3,956
very very nice 88 engine captain...
we do not have duplicolor engine enamel down here...bummer x2... thats awesome the magnesium is holding up... now headers lets see succesful header paint pics! jajajaja |
02-17-2013, 02:59 PM
#6922 | ||
Oddometer: 96
For the engine parts I hit it with 4 coats of primer (1 realllly light, 2 fairly light and one medium) and then left it a couple of days in the sun, wet sanded it a little with between 800 and 1200 grit, wiped down with acetone and then shot the main coat (1 very light, 2 light, 2 medium). Each coat was left to dry got between 5 and 10 minutes before shooting the next one, I did it in my garage so there was no direct sunlight or wind etc. Quote:
Like presented in this thread. I remember hearing some saying about using clear muffler paint on the header to help avoid it rusting and so on? I reckon you should come back to the brotherhood of twin header XR's, it would make me feel less sad about not finding a pipe to fit them. Have you considered just getting a fabricator to make a little 2-into-1 connector? Though as my Dad keeps saying "it's just a dirt bike, ride it into the ground, sell it, and buy another. Continue to repeat this". Ohhhh PS: about the brake caliper problem with the pistons not retracting? I ordered new seals (not here yet because Australia Post is useless) but also lightly sanded the lips of the piston holes, just about the dust seals as this had some crap caked on, and suddenly it all works perfectly. Weird but I'm not complaining. Got new sintered pads as well which seem to work great. Thanks everyone for the ideas and suggestions and tips during the whole caliper brake system debacle. Cheers, John |
02-17-2013, 03:39 PM
#6923 | |
Oddometer: 641
We can find some super deals here in the states for FMF/Big Gun etc headers......I've seen Hi-Flo headers for 207 bucks shipped in the U.S., I paid 226 shipped for my powerbomb. I'm not sure how that would relate to your area, but if you can get a set it will make you a happy man...performance and looks/durability wise ![]() Money well spent imo ![]() Heck Spud bought a Hi-Flo header and stuck it on his stock bike, including stock muffler, JUST for the ease of maintainence and better looks/durability from rusting.....he didn't even care about any performance gains. The stock steel headers from honda were just a cost cutting measure......honestly they suck unless you never hit the dirt or ride in the wet.
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack |
02-18-2013, 05:38 AM
#6924 | |
Oddometer: 3,956
you know I was about to pm you with a specific question on your powerbomb header...I know you like them... the question was how close does the BOMB part sit to the oil pipe on the oil feed to the head? also my bike finally has some engine mods...still stock comp, the flatslide and HEADER might be a good pairing NOW... Im still a firm beleiver that HEADERS mean nothing on a stock bike...really its THE LAST thing to mod always... so, sierra can you go by your mod list again and detail performance gains with each? jejejejeje PS. CAPTAIN hell yeah...I need to go back to being an original 88 bike..that couple issue I justcant seem to find someone that can say really yes I can do it and not sell me a peice of crap turd steel... seriously I went to a pro muffler shop once and said hey I need a coupler...they came back with some GALVANIZED thick as hell pipe and said yeah we can do it.... I SLOWLY walked away...slowly....making sure my I never showed them my back as I felt the stare of DEATH....jajajaja |
02-18-2013, 05:42 AM
#6925 | |
Oddometer: 3,956
I use polish and a felt rag or something when doing the pistons...of most importance is to clean the grooves of the seals perfectly...this will allow correct pressure if the seals against the pistons... yes If you had crud that will most definetly cause havoc against the poor pistons...thats why I like to POLISH the pistons |
02-18-2013, 02:29 PM
#6926 |
Oddometer: 3,956
check this out guys!
what a day, not only did my little montero blow a head gasket and get water leaking in cylinder #4 I said well might as well PAINT my headers on the bike and shazaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaam! booooooooooooyah ![]() tis life ps save money for the baby, wtf indeed! |
02-18-2013, 02:31 PM
#6927 |
Oddometer: 470
What caused that?
02-18-2013, 02:37 PM
#6928 |
Oddometer: 470
Or did you just punch a hole in the thing to give yourself an excuse?
02-18-2013, 02:41 PM
#6929 |
Oddometer: 293
I bet Chris gets pleasure out of poking headers..
02-18-2013, 02:48 PM
#6930 |
Oddometer: 3,956
I think it got hit by the swingarm linkage causing it to smash into the rear engine triangle frame mount bolts...I could see the rubbing on the bolt head
deejay, yes this is an excuse too! beleive me Im actually happy that I know this header is done I almost feel like mounting the twin headers and old exhaust for shits and giggles |
