Old 02-04-2013, 06:31 PM   #2761
AdvRich
Parallel Reality
AdvRich's Avatar
Oddometer: 1,758
Originally Posted by SlipChip View Post
Any love left over for the 3vd?
Excluding the Gondwanalanders, , what are you doing with your bike this winter?
I am going to pull the swingarm, clean off swarf, check/grease bearings, replace chain, sprockets, tire, etc...
No centerstand sux... portable swingarm stand doesn't help.
Gonna build a stand that bolts into peg mounts.
Yeah, I do miss the convenience of a proper centerstand too. I've just hung the front or rear from two long ratchet straps attached in a vee spread up to some rafters. I break the axle loose first before the hoist as the bike moves a bit or just air ratchet what ever needs removing.
For winter work, I've got fork seals, RT valves, and springs on the list to do by spring. A swing arm bearing check and lube sounds good too. The fuel tank can use some attention as well. The tank has some surface rust spots inside and I'd like to Por-15 line it for the long haul. Also, the fuel cap just started leaking at the end of last season if I fill it and then put the bike on the side stand. Not sure about the quality of the knock off caps on eBay from China, but there's not much else coming up for replacements.
"If you do not change direction, you may end up where you are heading." Lao Tzu
AdvRich is offline   Reply With Quote
Old 02-04-2013, 06:54 PM   #2762
Harvey Krumpet
Oddometer: 905
Originally Posted by Backonthebike View Post
That's easy to answer Chip.
It's 34 degrees C here today (About 95 F).
I'm gonna ride the tits off it.
Sucks eh? I'm sick of cleaning the dust off my chain.
We have had a bit of rain over here. Just a skerrick.
Part of a recent ride.
Harvey Krumpet is offline   Reply With Quote
Old 02-04-2013, 07:00 PM   #2763
Backonthebike
Giddy up
Backonthebike's Avatar
Oddometer: 675
G'day Harvey
Talk about dusty! The crows are flying backwards here just to keep the dust out of their eyes.
The XO and I came back from a ride to Bathurst after Christmas on the 900, and hit 45 degrees C coming across the Hay Plain into Mildura.
I have to say that was stretching the friendship a bit, but better than freezing your ass off.
If you don't like the weather in Aotearoa, wait around for five minutes!
Cheers
Tim
PS: Congratulations on your cornering lines. I taught pursuit riding to Speed Cops 35 years ago: You pass!
(NSFW) http://timothydunn.com.au/
I have come to accept that my role in life is simply to serve as a warning to others.
Backonthebike is offline   Reply With Quote
Old 02-04-2013, 09:30 PM   #2764
Harvey Krumpet
Oddometer: 905
45c Madness. 30c kills me. Your right about the weather up here. Benign, mainly warm with just enough rain to keep the farmers happy.
Thanks for your comment. I'm more interested in being a good rider than a fast one. I do like to get home safe & sound.
Old 02-05-2013, 06:03 AM   #2765
AdvRich
Parallel Reality
AdvRich's Avatar
Oddometer: 1,758
Nice vid and lush vegetation. Get's me dreaming of carving turns for this season. For a moment I thought you were on a V-twin, then I remembered that's what a 270 crank sound like. I like it!
Old 02-05-2013, 11:06 PM   #2766
shadowjack
Oddometer: 110
Nice vid, HK. And that sound track
45C? - yeah, man, but it's a dry heat.
If I'm not here, I'll be somewhere else...
shadowjack is offline   Reply With Quote
Old 02-17-2013, 04:33 AM   #2767
rackam_le_rouge
rackam_le_rouge's Avatar
Oddometer: 32
Another pic of my TDM 900 / 2007 with the Boxer kit !!
rackam_le_rouge screwed with this post 03-05-2013 at 09:27 PM
rackam_le_rouge is offline   Reply With Quote
Old 02-17-2013, 06:13 AM   #2768
nav18tor
nav18tor's Avatar
Oddometer: 141
Can you post some more views from the front please, can't figure out why and what is different from standard
Are the engine bars the genuine Yamaha ones?
nav18tor is offline   Reply With Quote
Old 02-18-2013, 10:06 PM   #2769
rackam_le_rouge
Oddometer: 32
A link for buying the engine bars genuine YAMAHA in France
http://www.gn-moto.com/protection-mo...ne-yamaha.html
rackam_le_rouge screwed with this post 02-18-2013 at 10:12 PM
Old 02-19-2013, 02:01 AM   #2770
masterbrewer
TDMster
masterbrewer's Avatar
Oddometer: 2,651
Thought you guys may be interested in seeing the typical, enjoyable, free flowing country tracks, north east of Adelaide, South Australia (max temp 34c for the day)
http://www.advrider.com/forums/showthread.php?t=863720
Other South Australian ride reports can be found here: http://masterbrewer-adventureriderep...rer-specs.html
masterbrewer screwed with this post 02-19-2013 at 02:08 AM
masterbrewer is offline   Reply With Quote
Old 02-19-2013, 03:45 AM   #2771
Harvey Krumpet
Oddometer: 905
Kia Ora MB. How's it hangin?
Old 02-24-2013, 07:00 AM   #2772
Cavaleru
Cavaleru's Avatar
Oddometer: 43
my beast on my summer trip to Corfu, Greece. 2400km
Cavaleru is offline   Reply With Quote
Old 02-24-2013, 09:27 AM   #2773
AdvRich
Parallel Reality
AdvRich's Avatar
Oddometer: 1,758
Good stuff! Haven't checked in on your RR's since your dirt nap late last year... glad you and the TDM are out in typical good form.
Old 02-24-2013, 09:29 AM   #2774
AdvRich
Parallel Reality
AdvRich's Avatar
Oddometer: 1,758
Looking good! Post more if you got 'em.
I like the body/engine guards you got there. Bags look beefy too.
Old 02-24-2013, 10:11 AM   #2775
Cavaleru
Cavaleru's Avatar
Oddometer: 43
everthing it's hand made, crash bars, center stand, cases and brackets, windshield brackets.
loobman with a little modification
sidecase , the straps are made by me
windshield
backview
Times are GMT -7.   It's 09:27 PM.
