Old 02-12-2013, 11:14 AM   #1
HardWorkingDog OP
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,775
Best solution for gouged swingarm at pivot
During a long, multi-week Baja trip I got complacent with checking my chain and managed to grind the lower leading edge of the swingarm pivot head with the chain on my WR250R.
It took about 3mm of the existing weld bead, and then about 2mm into the swingarm head itself. It's not all the way through into the bearing area, but I have no idea how much material is remaining.
I'd appreciate hearing from knowledgeable welders/metallurgists/swingarm hackers on how best to recover from this. Options I see are:
1. Replace the swingarm--I see used swingarms on eBay for $125-175. Could just be getting another set of problems from a most likely wrecked bike.
2. Get it welded. Don't know if this will do more harm than good, considering the to-me unknowns of the swingarm composition, heat treatment, potential for deformation around the bearing surfaces, etc.
3. Fill with quicksteel-type epoxy.
4. Leave as is.
All of the options include replacing the chain slider ("seal guard") and chain/sprockets.
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 02-12-2013, 11:58 AM   #2
dmn0507
dmn0507's Avatar
Oddometer: 353
The pic was taken a bit too close go get the idea of the entity of the damage but here are my 2cents anyways:
I'd go either for #1 or #2 (pick the cheapest solution) if u don't feel comfortable to leave it as it is
3 and 4 are pretty much the same, except for the cosmetic difference
Epoxy might be worth applying to the new (or welded) swingarm, in case the chain will try to grind it again it should take some more time before digging into the metal.
dmn0507 is online now   Reply With Quote
Old 02-12-2013, 05:31 PM   #3
Saltydog86
village idiot
Saltydog86's Avatar
Oddometer: 1,046
4. Leave it as is.
Then replace the slider and but a 14t front sprocket on.
That's what I did when I had the same issue as this.
12 KTM 350 EXC-F
09 KLR 650
12 Genuine Stella w/Cozy Sidecar
05 Yamaha XT225
03 Honda Goldwing GL1800
Saltydog86 is offline   Reply With Quote
Old 02-12-2013, 06:44 PM   #4
Beezer
Oddometer: 5,934
plenty of metal there still... I'd leave it alone other than file off the ridges. then maybe build a slider or add on to one so that it extends a bit farther to cover the tube. another option would be to get a piece of steel & stick it with RTV so if the chain gets loose again it won't keep cutting into the swingarm. either that or ignore it & keep the chain tensioned
Beezer is offline   Reply With Quote
Old 02-12-2013, 06:55 PM   #5
KustomizingKid
Oddometer: 678
Leave it... If it starts cracking, weld it. The worst thing to do is to fill it in with some epoxy crap that does nothing structurally and keeps you from seeing cracks propagating.
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 02-17-2013, 05:03 AM   #6
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,430
Leave it as is. 35 years fabricating experience. It's just fine.
Old 02-17-2013, 07:22 AM   #7
HardWorkingDog OP
Harvey Mushman
Oddometer: 1,775
Thank you concours, KustomizingKid, Beezer, Saltydog86 and dmn0507. My compulsive side would like nothing more than to replace the swingarm but I think I'm just going to leave it as is. And keep a close eye on it.
Really appreciate the replies
"Coffee first..."
Times are GMT -7.   It's 06:35 AM.
