Old 02-14-2013, 03:48 AM   #4471
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,641
Originally Posted by Royal Tiger View Post
Marc, should I use rescue tape under the Oxford heated grips as well or it just for the under grip heaters?
Thanks.
I've only used it under grip heaters. Honestly, I'm not sure if you would need them under Oxfords. I don't recall hearing people talk about having heat sink issues with Oxfords. I assume since the heating element is buried inside the grip itself it is better insulated from the bar and closer to the surface of the grip. It certainly wouldn't hurt, but it might be overkill.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 02-14-2013, 01:34 PM   #4472
john_aero
john_aero's Avatar
Oddometer: 1,173
Originally Posted by snooker View Post
One this is for sure, you MUST replace the cast aluminum one or a fall that impacts it can shear off your shift shaft. It is a major weak link in the design and replacing it with a BENDY steel lever should be your FIRST mod!
People have different opinions, I tried several of them and for me the Touratech one was the only one I liked on my XCountry. I collected this info on my Gear Shift Lever Web Page, hope it helps!
really must go get one. drilled few holes in mine but its some lump of metal why they make so big is beyond me
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 02-14-2013, 01:38 PM   #4473
john_aero
john_aero's Avatar
Oddometer: 1,173
would the left and right switch gear of a f650gs bike fit xchallenge
Old 02-14-2013, 01:57 PM   #4474
The Jester
The Jester's Avatar
Oddometer: 859
Thanks.
Oxford grips are fine without tape underneath.
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 02-14-2013, 02:30 PM   #4475
Royal Tiger
Sd Kfz 182
Royal Tiger's Avatar
Oddometer: 1,455
Thanks. They are sitting in the garage waiting for the time to install them.
Current- '13 Yamaha XT250 * '05 BMW R1200ST * {Searching for my next DS}
Past- 2x aprilia, 2x BMW, 1x Ducati, 5x Kawasaki, 2x Yamaha
Royal Tiger is offline   Reply With Quote
Old 02-15-2013, 12:23 PM   #4476
oothef
Grownup
Oddometer: 32
Rear spindle O/D 19.43mm I/D 11.85mm HTH
oothef is offline   Reply With Quote
Old 02-17-2013, 09:08 AM   #4477
mcgarrett
mcgarrett's Avatar
Oddometer: 164
Ohlins mounting
Dealer installed my Touratech subframe and pannier racks yesterday, but the Ohlins oil reservoir mounting hardware isn't compatible with that set-up. It's jury-rigged with zip ties for now, and I'll call Touratech tomorrow, but I was just wondering if anyone had encountered the same issue. Dealer tech said that a metal clamp (which they didn't have) should do the trick.
Michael
mcgarrett is offline   Reply With Quote
Old 02-17-2013, 09:18 AM   #4478
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,641
I think Tbarstow has the TT racks with an Ohlins shock. Hopefully he can throw out some ideas.
Marc
07 XChallenge
Old 02-17-2013, 02:53 PM   #4479
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,471
Michael
Yes, I have the TT rear end and an Ohlins shock.
You need a milling machine with a hole mover tool and it will fit like this:
tbarstow is offline   Reply With Quote
Old 02-17-2013, 04:44 PM   #4480
mcgarrett
mcgarrett's Avatar
Oddometer: 164
Thanks for the guidance, and it seems like a solid set-up. I'm hoping Touratech might suggest a slightly less machine-intensive solution, since I lack machines and skills.
Michael
Old 02-18-2013, 02:23 PM   #4481
BigHairyYorkshireman
Oddometer: 8
Rear spindle dimesnios: X-Challenge
Thanks oothef, but did you measure the length too please?
BigHairyYorkshireman is offline   Reply With Quote
Old 02-19-2013, 03:06 AM   #4482
oothef
Grownup
Oddometer: 32
Rear spindle overall length 300mm, small dia. length 295mm
I'm looking for a plain bush to replace the (collapsed) swinging arm needle roller bearing on the exhaust side, 25mm id, 32mm od, anyone know of a supplier, before I get one turned up?
Old 02-19-2013, 06:33 AM   #4483
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,471
Michael
The bracket is the one that Ohlins supplies with the shock. If all else fails, send the bracket to me and I can modify the holes.
Old 02-19-2013, 08:13 AM   #4484
mcgarrett
mcgarrett's Avatar
Oddometer: 164
Ohlins is sending a rubber block and hose clamp. We'll see how that works.
Old 02-19-2013, 03:41 PM   #4485
mcgarrett
mcgarrett's Avatar
Oddometer: 164
Mirrors
Any suggestions for replacement mirrors? PO traded the bike in without any, and the dealership put on some generic cheap ones that I don't really like.
Michael
Times are GMT -7.   It's 04:07 AM.
