02-17-2013, 09:48 AM
#151 |
Oddometer: 2
12v cigarette adapter to switched power
Sorry to sound like a complete idiot - but how would I go about connecting into the unused switched power outlet behind the headlight?
I bought a 3m auxiliary power outlet adapter at Walmart the other day for this purpose, and it just has 2 wires, the positive and the ground wire. Do I need to connect this to a male plug that fits into what looks like the female switched power outlet? I have absolutely zero electrical experience, and thought this would be better/easier than connecting directly to the battery. Thanks in advance! For reference, this is basically what I have: http://www.amazon.com/Bell-22-1-3904...y+power+outlet and I'm trying to connect it to:
02-17-2013, 02:04 PM
#152 | |
Oddometer: 145
Easy, peazy, Japanezzy. |
02-17-2013, 02:14 PM
#153 | |
Oddometer: 145
I had been wanting to install some type of switch that would allow me to turn the headlight off, and the DDM kit kills two birds with one stone. Simple installation (when you order the correct bulb)...
02-17-2013, 02:39 PM
#154 | |
Oddometer: 2
02-17-2013, 04:03 PM
#155 | |
on the road o'dreams
Oddometer: 5,510
I had already wired in an ON/OFF switch before installing my HID. The HID made my switch redundant. Just switch to HI beam to switch off headlight. Good to have for starting ... or when running accessories in daylight. Amazing thing about the HID is no one flashes me ... yet I can see three times further on a dark road. Win Win Win. |
02-17-2013, 06:22 PM
#156 | |
Grumpy Young Man
Oddometer: 3,940
I'd check the amperage rating for that plug's circuit before wiring in a bunch of stuff though. |
03-01-2013, 10:10 AM
#157 |
Butler Maps
Oddometer: 14,583
Start squeal noise and fixes
http://www.fy-yff.com/2011/08/squeak...-easy-fix.html http://webpages.charter.net/jrandall...tarter_fix.htm http://www.advrider.com/forums/showthread.php?t=832297
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
04-12-2013, 03:03 PM
#158 |
Oddometer: 1,031
Turn signal Help Please
I installed LED turn signals front and rear. Also installed an electronic turn signal flasher from CustomeLED, Lights come on fine no issues, however all four light up at once when you select one side or the other.....
with out going overboard on technical mumbo jumbo can someone give me some troubleshooting ideas please? |
04-12-2013, 03:05 PM
#159 |
Oddometer: 1,031
[/QUOTE]ah ha......that's whats that's for.....cig lighter....worked good for power for GPS RAM mount........ |
04-12-2013, 07:22 PM
#160 | |
Oddometer: 2,612
^^^^^ That might be the most famous DR650 photo on the internet.
2004 DR650: 47,033 miles of The last 314 miles were done with my super, hot rod, whiz-bang, blue KLIM Dakar gloves. Good thing I lost one of my 10 year old Joe Rocket gloves; I didn't know I could ride so fast. |
04-13-2013, 05:38 AM
#161 |
Oddometer: 1,031
[QUOTE=
Try unplugging the turn signal indicator light (up by the key). If that works, you probably need to do the diode kit. (I'm happy with incandescent flashers, they aren't on long enough to matter.)[/QUOTE] Well that worked......what is the diode kit? of course though one issue leads to another, the right rear light isn't work screw it for today....don't need turn signals for the woods.....ride and fix it later.thanks!!! |
04-13-2013, 10:49 PM
#162 |
Oddometer: 2,612
DIY: Here ya go, 4th post:
http://drriders.com/viewtopic.php?f=...=unread#unread
04-16-2013, 07:14 AM
#163 |
Grandpa Adventurer
Oddometer: 1,178
DR died
My 2006 DR650se (52K miles) died several times in the last month, requiring the bike be hauled home. Just riding along, it died, like turning the key off. I read, talked and begged for input from friends. Last evening I found the problem.
The number plate was off, providing access to the wires at the headlight. When the engine would die, the nuetral light would get very dim. I happened to brush my hand over the plug coming from the kill switch. The wire was VERY hot, with the insulation starting to sag... just about a melt down. I killed the key power and traced the wire to the left side of the bike under the side plate, just below the rectifier. The wire was worn 1/2 way thru and shorting to the frame. Fixed it by stripping insulation off enough to solder the frayed wire, taped it up and put on some plastic wire sheath as protection from future problems. Rode it to work today with no problems. Dave
Smilin Jack Western Oregon USA 2006 DR650SE CB250 1991 Adventure bike "dual-sport" http://www.advrider.com/forums/showthread.php?t=441736 http://www.advrider.com/forums/showthread.php?t=469125 http://www.advrider.com/forums/showt...e#post11612867 http://www.facebook.com/album.php?ai...8&l=3d8dcb2743 |
04-16-2013, 09:17 AM
#164 |
Oddometer: 5,510
Wow! Good work Dave! Those are the kind of mystery failures that can be very hard to pin down! Too few of us check our wiring looms for abrading against metal. I also see some wear on my loom up around the central frame tube around the steering head. In places I've wrapped a bit of bicycle tube in critical areas. Not noticed any abrading near the rectifier/regulator ... but will FOR SURE look in that area now.
This kind of thing could cause a fire ... and really ruin your whole day. So glad you got to it before any damage was done! ![]() ![]() ![]() ![]() Plus One for good maintenance!
04-17-2013, 05:46 PM
#165 |
Awesometown
Oddometer: 402
aux connectors
I posted on DRRIDERS to no avail. I swear I've seen this posted before, but googling hasn't helped me.
Can anyone help me with the type, or preferably source to purchase, the male connector for the 2 Auxiliary switched power plugs: 1 in headlight bundle, the other somewhere under seat/ near shock? i thought I found it on Eastern Beaver (where else?) but wasn't 100%. TIA!
'76 Xl250 '04 XR250R '09 DR650 '10 TR450 |
