Old 02-16-2013, 07:43 PM   #46
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,300
Just read your central and South America thread. Really an interesting read.
Did you check that your vent and neck drain lines are clear?
The pinched hose in the tank is very likely to become a problem at some point. Mouthfullofflake found a corrugated plastic hose that can me bent. If you search it was sometime in the last 6 months.
roger 04 rt is online now   Reply With Quote
Old 02-16-2013, 09:21 PM   #47
Flys Lo OP
cool hand fluke
Flys Lo's Avatar
Oddometer: 321
Thanks - it itsn't ideal, although its not kinked. I will see if I can find the thread you are referring to.
The noisy fuel pump and the splutter at half a tank has gone
Thanks for all your help.
Adrian, Central & South America, 2011/2012
02 GS & 08 WR250
I know violence isn't the answer. I got it wrong on purpose.
Flys Lo is offline   Reply With Quote
Old 02-16-2013, 10:07 PM   #48
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,803
the corrugated hose was from either beemer boneyard, or euromotive electric.
I used steel hard brake line and bent a U, flared the ends , because it was available locally, and was cheap.
edit-
found it
http://www.euromotoelectrics.com/BMW...fp-hosekit.htm
from this thread
http://www.advrider.com/forums/showthread.php?t=782226
notice the large O ring for the pump flang to tank seal is a #348
Viton ( reusable) from mcmaster carr ( the 6.30 price is for 2 of them, which is more than a lifetime supply)
Viton® Fluoroelastomer
Fractional
Size
Actual
Inch Size
AS568A
Dash No. ID OD ID OD Pkg.
Qty. Per
Pkg.
Width: 3/16" Fractional (0.210" Actual)
348 4 3/8" 4 3/4" 4.350" 4.770" 2 9464K611 $6.30
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake screwed with this post 02-16-2013 at 10:13 PM
mouthfulloflake is online now   Reply With Quote
Old 02-17-2013, 08:15 AM   #49
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,880
Flys Lo I have the same bike and have not, as yet knock on wood, had any problems. When and if I do ever need it I will refer to this post. Thanks for sharing and everyones reply.
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 02-17-2013, 07:03 PM   #50
Flys Lo OP
cool hand fluke
Flys Lo's Avatar
Oddometer: 321
Originally Posted by mouthfulloflake View Post
I'll order that, and replace it next oil change.
02 GS & 08 WR250
Old 02-24-2013, 07:10 PM   #51
Mugwest
Mugwest's Avatar
Oddometer: 6,764
Just found this thread, fellas, and there are some need to know details when using the EME (John Rayske) submersible fuel line kit on an 11xx model bike:
I'd bought the EME kit way back in 2011 for the full-boat inner-tank refurb that Vintagerider is always harping on. Well i finally got around to it right after New Years 2013.
Here are the crucial details w/ the EME submersible kit:
You will get the following pieces in the EME kit:
You'll use 1 hose section to make the 'U'. You will cut off a lot of the straights, think it was 20mm or more (leaving just enough to cover the filter's/hardline's barbs). I went conservative at first so i wouldn't cut off too much. Conservative made the 'U' hoop too wide, fouling the level arm's float travel. Cut off 10mm more and it was fine
You'll then cut off the straight sections of the 2nd corrugated piece to make the 2 small sections between pump/hardline and filter/hardline.
And here's where the kit bites you.
You'll find yourself lacking 2 of the small FI clamps to finish the job. The kit comes w/ 4 clamps, and you need 6 to replace all 3 sections ('U' takes 2 clamps, and both small sections takes 2 clamps)
So no big, right? Run to local A-Zone etc for more clamps, right? Nope. The hard plastic submersible line is thin gauge, needing a small 7mm-ish clamp. If you had FI clamps on the old rubber hose (from prev. filter replacement), they're too big and can't close enough for the new submersible line to seal
I ended up having to refit my old 133k miles short hose sections b/c i had to get the bike back to good that same day (a Sunday). No possibility to run around locally looking for oddball tiny FI hose clamps.
I emailed John Rayske and the gang at EME the next morning letting them know that their kit needs 2 more clamps for 11xx bikes. They said they'd update the kit, but i see tonight the website listing hasn't been updated
Hope this helps, folks. The submersible EME kit hose looks like good, solid stuff. Just order more small clamps until they get their web listing updated
Mugwest is online now   Reply With Quote
Times are GMT -7.   It's 09:44 AM.
