Old 02-17-2013, 07:39 PM   #16
Chuck35
Chuck35's Avatar
Oddometer: 36
Originally Posted by gspdbill View Post
New to me GS has the registration stickers on the forks, TN doesn't do stickers. What's the best way to remove those stickers? I've spent about 5 min. on them and gotten no where. What's the trick? Heat? Solvent?
Citric acid works wonders on adhesives. Perhaps some lemon or lime juice you may have handy?
Chuck35 is offline   Reply With Quote
Old 02-17-2013, 07:39 PM   #17
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,429
Eraser..takes about two minutes..
Buy one at a auto body supply shop..chucks in your die grinder..
Remove any sticker, any surface, no paint damage..
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 02-17-2013, 07:43 PM   #18
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,341
Originally Posted by Izzy3 View Post
My dealer did the "sticker tag" and I didn't even need to ask. Thank goodness for Morton's in Freddieburg.
That is where I got mine too!
Jim
Old 02-17-2013, 08:13 PM   #19
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,962
I've never used one of these, but I will!
I use WD40 and my thumbs. You have to let it soak and repeat and repeat and repeat..it takes a while. The WD must be left 10 minutes. On wheel weight goo I use WD and sometimes laquer thinner and my thunbs!
Never ever put a mettalic National Park sticker on your plastic windshield.....don't ask......
Gotta get an ERASER!
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is online now   Reply With Quote
Old 02-18-2013, 08:53 AM   #20
gspdbill OP
noobie allover again
Oddometer: 404
Originally Posted by Delta61 View Post
Best stuff i have ever used is aircraft decal and adheseve remover. Get it at autozone for sure but have seen it at other auto parts stores
I have some 3M Adhesive Remover I'll try, also try the heat gun (doubt it would hurt the forks where these are installed) and if those fail I'll resort to the plastic razor blade method (I'll put them on my next Amazon order).
Thanks guys.
Bill
'05 R1200GS for now......
gspdbill is offline   Reply With Quote
Old 02-19-2013, 07:39 AM   #21
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
Thanks guys.
You shouldn't have to go to Amazon for the plastic razor blades, I saw them at O'Reilly last time I was in the USAs. Dip them in cleaner and push against the decals after heating it up.
Cleaner for decals, depends on the adhesive used. Some come out with Alcohols such as Methyl Hydrate. If not there is always Naphta aka Coleman gas/lighter fluid.
Have tools, will travel!
Old 02-19-2013, 08:41 AM   #22
Beefeater Steve
Oddometer: 197
Goof Off might work, too.
Beefeater Steve is offline   Reply With Quote
Old 02-20-2013, 09:24 AM   #23
OHRider
BMWMOA, BMWRA, AMA (Life)
OHRider's Avatar
Oddometer: 149
+1 Great stuff
Al
Warren, OH
01 R1150GS
00 R1100RT
07 KLR650
84 RZ350
73 R75\5 LWB
BMWMOA. BMWRA, AirHead, AMA (Life)
OHRider is offline   Reply With Quote
Old 02-26-2013, 06:32 PM   #24
gspdbill OP
Oddometer: 404
Did not try all the methods suggested but of the ones I tried in order of effectiveness 1) heat gun 2) plastic razor 3) 3M adhesive remover.
Bill
Old 02-26-2013, 07:48 PM   #25
Stegerman
MotoOCD sufferer
Stegerman's Avatar
Oddometer: 592
I have expired military stickers on mine.. will the heat gun and adhesive remover work for them as well?
2000 R1150GS- ZenPig
2003 F650GS (sold)
formally trained to screw with people's minds..
Stegerman is offline   Reply With Quote
Old 02-26-2013, 08:00 PM   #26
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,262
This shit works.
I see folks recommending WD-40, but this works sooooo much better.
I wasn't born with enough middle fingers.
stevie88 screwed with this post 02-27-2013 at 09:54 AM
stevie88 is offline   Reply With Quote
Old 02-27-2013, 08:05 AM   #27
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Once you get the main part of the sticker off with heat or just patient gentle scrapping and peeling, I use WD40 to remove the glue residue. It is generally harmless to any coatings like chrome or anodizing but softens up glue residue so it can be cleaned.
I take a rag and spray the WD40 part diectly, then rub it with my fingers to rub it in, then I use the rag to try and collect the residue. Repeat multiple times with different spots on the rag so you are not just smearing it around.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 02-27-2013, 08:43 AM   #28
gspdbill OP
Oddometer: 404
Don't see why not, can't be much harder than the VA ones I just removed.
Have plenty of WD-40 around, I'll try that on the remaining stickers. Thanks.
Bill
Old 02-27-2013, 08:55 AM   #29
apexal
apexal's Avatar
Oddometer: 283
Heat gun or hair dryer to remove the decal/sticker, WD-40 to remove the residue.
Dover, NH
2014 R1200GS Racing Red
2014 KLR650 White & Black
apexal is offline   Reply With Quote
Old 02-27-2013, 01:04 PM   #30
dch
Rock Chalk
dch's Avatar
Oddometer: 369
These little tools work great. I've used them to remove all kinds of decals, vinyl lettering etc. Works in conjunction with goo gone, wd-40, alcohol, this is used instead of a credit card or plastic squeegee, and works much better.
Get them at any sign shop, or sign supply outlet.
http://www.speedysigns.com/little-ch...l-remover.html
dch is offline   Reply With Quote
Times are GMT -7.   It's 11:59 PM.
