Old 02-18-2013, 05:57 AM   #16
Hikertrash
Oddometer: 2,773
Originally Posted by GB View Post
A more effective brake / running like would be the P3 lights, easy install, and much brighter than the bmw light:
www.skenedesign.com
+1
They're much brighter than the hyperlites and don't require soldering.
Hikertrash is offline   Reply With Quote
Old 02-18-2013, 07:54 AM   #17
Izzy3 OP
Freak of Unnature
Izzy3's Avatar
Oddometer: 165
Thanks for the input.
'12 R1200 GSA
Izzy3 is offline   Reply With Quote
Old 02-18-2013, 09:18 AM   #18
rgb2cmyk
rgb2cmyk's Avatar
Oddometer: 256
Originally Posted by Hikertrash View Post
+1
+2
I have the P3s on the back and photonblasters on the front (orange) an they are worth their weight in gold on I95 in NJ.
I know they work because my GSA has them and my S doesn't and I see the way traffic behaves around me.
And lest you think the difference is a two wheeled hummer baring down on them, I haven't had time to install them on my new GSA and I see the difference.
The oscillating is why my brother calls them 'annoying lights', because they always catch your eye.
_
14 R1200 GSA (Hopefully lasts longer than 2yrs)
12 R1200 GSA ("Sandy") (Hit by DUI)
09 R1200 GSA (Totaled by SS Sandy)
06 Husky TE450, 04 R1100s BCR, 03 F650CS
rgb2cmyk is offline   Reply With Quote
Old 02-18-2013, 09:18 AM   #19
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,139
Originally Posted by Izzy3 View Post
The catalog lists it as an additional tail lamp which fixes at the bottom of the the license plate frame. My current tail light (OEM) doesn't flash, is above the license plate and is smallish to say the least.
WTF?
You're talking about the "Supplemental Brake Light".
At $170 with the wire harness its pricey, but works great.
As for an additional "supplemental" brake light there are dozens of other options and you need not worry about the CANBUS as it's a load sensor withing the ZFE that triggers the LAMP Out error and that is already set to LED on 2008 and newer models.
Remove chocks and chains.
JetSpeed is online now   Reply With Quote
Old 02-18-2013, 09:41 AM   #20
gspdbill
noobie allover again
Oddometer: 404
Originally Posted by LaurelPerryOnLand View Post
1. No. Not for my money.
2. Hyperlites 16 LED version will provide PLENTY of reward visibility without CANBUS issues or a trip to the BMW dealer to have a "software change to LED". Just get the Hyperlites and be done with it.
3. Soldering isn't rocket science....learn it...you'll have a new capability that can/will serve you well.
http://www.hyperlites.com/moddf.html
Thanks for this info, just ordered the 16's last night, make sure they send you your commission check...
I've had various HyperLight setups on my bikes for the last 10+ yrs., never had an issue with them. This will be the first CANBus install though.
Bill
'05 R1200GS for now......
gspdbill is offline   Reply With Quote
Old 02-18-2013, 11:09 AM   #21
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,527
You said you didn't want soldering or canabus issues but I've been stuck behind the school bus in my neighborhood. They stop at every driveway and have super bright and noticeable red LEDs. Anyway I've been thinking about something like them on my 08 GSA some how.
http://www.slclighting.com/7-RED-LED...744-96-010.htm
scooteraug02 is offline   Reply With Quote
Old 02-18-2013, 11:28 AM   #22
LaurelPerryOnLand
Oddometer: 3,478
And then there are these...LOTS of choices.
http://www.whelen.com/_AUTOMOTIVE/lightheads.php
Used the 600-series light head for some additional visibility on the RT.
http://www.whelen.com/_AUTOMOTIVE/de...74&prod_id=126
Works like a charm...no CANBUS issues.
Want to ride up on my tail? Didn't think so!
LaurelPerryOnLand screwed with this post 02-18-2013 at 11:34 AM
LaurelPerryOnLand is offline   Reply With Quote
Old 02-19-2013, 04:56 AM   #23
TuefelHunden
TuefelHunden's Avatar
Oddometer: 591
Originally Posted by SR1 View Post
FYI, you are probably going to want to put other accessories on your GSA, and for that you'll need a fuse block anyway...which could power a different LED brake light...
I have a fuzeblock with relay built in and ability to use both switched and straight battery power. If you monkey with the electrics on these frickin' CAN-Bus bikes it sure makes things a lot easier. I have yet to see ANYTHING positive about CAN-Bus. Last comment on omelets, if you expect to have plug and play, then don't expect to get three things: 1. What you really want. 2. The best item for the job. 3. Something you don't have to worry about CAN-Bus compatibility.
Old, but not Dead
TuefelHunden is offline   Reply With Quote
Old 02-19-2013, 08:55 AM   #24
scooteraug02
Dog Rancher
Oddometer: 4,527
$2500
How did you trigger it to come on with the brakes. Relay?
One on each can and one in the middle. ONLY a texter would hit you.
scooteraug02 screwed with this post 02-19-2013 at 05:06 PM
Old 02-22-2013, 10:49 PM   #25
Poway
SHED (Shit Head)
Poway's Avatar
Oddometer: 486
I'm on my 3rd replacement BMW supplemental LED light. They suck. Although they do come with a 2 year warranty. Maybe it's the vibration from the off roading that kills them?
Poway is offline   Reply With Quote
Old 03-01-2013, 09:00 AM   #26
Monsignore
Plunger Boy
Monsignore's Avatar
Oddometer: 901
Originally Posted by def View Post
I'm thinking about making a red LED panel shaped like a octagonal stop sign with a fabric base and velcro that I can attach to the various jackets that I wear when riding that plugs into a yet-to-be installed connector in parallel with the tailight. LEDs are very easy work with and somewhat forgiving. The circuit is merely resistors, LEDs and wires that can be sewn or glued to a piece of heavy ballistic fabric.
Tap the brakes and a red stop sign lights up on your back leaving no doubt that your brakes are applied. Remember the Electric Horseman?
Then, amber turn signal arrows flanking the octagonal stop sign...now you've got some serious rear signaling going on, the current draw is very low and the wiring is simple.
Just run a double row of yellow LEDs down each arm, so when you signal you can point your flashing arm in the direction you intend to move.
And maybe a sheath of LEDs for each middle finger.
Ewig war ich.
IBA # 55612
Monsignore is offline   Reply With Quote
Times are GMT -7.   It's 04:17 PM.
