02-11-2013, 07:52 PM
#3301 |
Zoob
Oddometer: 984
Rekluse recommends that you turn the adjustment screw in 1 1/4 turns, I like 3/4 of a turn. The bike will just 'twitch' at idle and is fully engaged by 3000 rpm. No slip, it releases just before idle.
Great clutch. You can run higher gearing. Very fast in tight woods. No down side yet. I may hook the clutch master to the rear brake since I never touch it now.
"Dad, can I get a motorcycle when I grow up?" "Son, you can't do both" |
02-15-2013, 02:57 AM
#3302 |
Grip and rip since 1983
Oddometer: 609
Chain?
[QUOTE=Chris6_85;20695171]i did not stall the bike once. with about 25 miles of single track locking up the rear all the time and never stalled it. it just creeps a little. i can start the bike no problem in gear and it does not stall when i put it in gear. engine breaking is different, it will take me and you a little bit to get use to. i found just blip the throttle a little and it will kick in.
also i noticed on the highway 25-45mph with a steady hand on the throttle there was a ever so slight bit of lunging or something around that. i am trying to find the right word to describe what i am talking about. forward and back feeling." I installed mine and kinda had the same issue. I carefully followed the instructions (did you watch the online video?) went through recommended settings for setting free play gain at the slave cylinder and then carefully adjusted it two hash marks at a time until it was just right at the lever. The bike chatters the chain at idle but does not creep. I called about the chain chatter (my DRZ didn't do that) and the Rekluse dude said that on these bikes they chain needs to be on the loose side (good advice for ANY bike) and that sometimes a slightly higher than normal idle will cause this minimal creep. I run my chains loose, so I dialed back the idle a C hair and it is perfect. As far as the surging at 45, maybe check your chain. This clutch makes this bike a complete fucking animal. Rear brake kit going on soon as well as about $1000 worth of goodies from Slavens Racing in CO. DO NOT VISIT THAT SITE UNLESS YOU WANT YOUR BANK ACCT TO GO INTO ZERLOAND. Hope that helps a little.
I coulda been an actor, but I wound up here. |
02-15-2013, 07:54 AM
#3303 | |
Oddometer: 67
[QUOTE=YAHBO;20730205]
![]() Yes it is very easy to drop some serious coin on these bikes I sold 4 bikes just to set this bike up the way i want it.I love this bike and it always seems to surprise me at what it does very well. with the rekluse installed this thing is unstoppable. ![]()
No Matter Where You Go, There You Are. |
02-15-2013, 08:58 AM
#3304 |
King of all manfu
Oddometer: 2,685
Stiffy - I love the Jager graphics. Too bad you can't rig up a dispenser like this trike
Guns keep society safe. |
02-15-2013, 09:50 AM
#3305 |
Oddometer: 67
I do have one. Its just under the seat. Gotta keep warm on those cold mornings, I think I am having Deja Vue, or its the Jager?
02-15-2013, 08:11 PM
#3306 | |
Oddometer: 987
02-16-2013, 01:27 PM
#3307 |
Oddometer: 58
Safari 4 Gallon Tank
Has anyone tried installing the Safari 4 gallon tank yet? I just got mine and either they sent me a tank from another model or there are significant fitment issues.
The thickness of the flange material in the area of the fuel pump and fuel line is significantly thinner than stock. As a result the O-rings do not seat / compress. The seat doesn't seem to fit either. Anyone have any good or bad experience with this application. I sure hope they sent the wrong tank and all will be corrected with the right one. I have a 2013 KTM 500 XCW Thanks for the feedback Dave |
02-16-2013, 09:49 PM
#3308 |
Oddometer: 272
KTM Shock Shortening to Improve Handling and Stability
http://www.youtube.com/watch?feature...&v=_Z5xrdXEXDg
http://bestdualsportbikes.com/ After 100 hrs of dualsport use, I'm looking at lowering my 500 for easier dabbing and more stability. I'm 52yo and the bike is sprung for my weight (75kg) Interested in the concept setout in the vid For dualsport use, they suggest the bikes are too high in the back. Remedy is internal shock spacer to lower seat height ~1" and fine tune with fork height in clamps and rear sag. Has anyone tried this mod. Are you happy with the results. I'm mainly interested in the concept, not necessarily bestdualsportbikes doing the work |
02-17-2013, 09:47 PM
#3309 | |
Migration to offroad
Oddometer: 36
Oil screen question
Just about to do the first oil change on 2013 500 EXC. The manual refers to using a "pin wrench" when you insert the long screen into the engine on the side. My dealer said they just use a screwdriver to guide the screen in. I don't see how a pin wrench (the ones I am familiar with) could be replaced by a screw driver, and I'm not thrilled about potentially inserting a pointed steel object into an oil journal.
So, the question for the experienced is: how do you safely insert the long oil screen into the motor? Thanks. Quote:
02-17-2013, 09:51 PM
#3310 |
Adrenaline Junkie
Oddometer: 76
I just push it in and if it needs a little guidance I use my fingertips to lift it up, you feel it seat when does and it stays seated. Not a real issue.
02-17-2013, 09:54 PM
#3311 |
Oddometer: 36
02-17-2013, 10:03 PM
#3312 |
Huh???
Oddometer: 979
A pair of needle-nose pliers makes grabbing the plastic end real easy as well
.................................................. .................................... NMOHVA.ORG - Help to keep your trails open! Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
02-18-2013, 01:32 AM
#3313 |
Oddometer: 609
Oil screen insert
A 1/4" socket extension works perfectly. If you look into the motor where the screen goes, you can see how the screen needs to sit. Easy stuff.
02-18-2013, 09:22 AM
#3314 |
Oddometer: 7
Joining in the community
Well, after spending the weekend reading ALL pages in this very informative thread I had to order a Sixdays as soon as the dealers opened this morning. Thanks for all the valuable information regarding this bike. It will save me lots of time when it comes to future modifications.
![]() My present favorite bike is a 690 R with rally fairing and tanks from Rally Raid in UK, but it suffers from some extra kilos - just like me. Since I don't have any plans of loosing weight it has to be the bike who stand for this metamorphoses. Welcome 500! Per W screwed with this post 02-18-2013 at 09:35 AM |
02-18-2013, 10:36 AM
#3315 |
Oddometer: 48
Oil intervals
What are you doing
Manual says after 1st hour then every 15 hours |
