Old 02-18-2013, 11:38 AM   #3316
MJG2
Oddometer: 53
Seat info
Seems that seat concepts is most popular
I have used EE seats in past but leaning towards SC one this time
How is the carbon side and gripper top - which seems most popular? is the gripper top too grippy?
ANd on the standard height -how is the foam- is this overall a more comfortable seat?
Thanks for seat feedback, pictures and advice
I am getting a new 2013 500 EXC in a week or two-
Mark
MJG2 is offline   Reply With Quote
Old 02-18-2013, 11:40 AM   #3317
MJG2
Oddometer: 53
Headlight always on
Headlight on
Is the EXC headlight always on?
I ready some comments on a plug etc in harness
Anyway change anything so the headlamp can be swithed on and not always on when running during the day
tips- advice
PS- what a thread here -lots of great tips and advice
Mark
Old 02-18-2013, 01:37 PM   #3318
Per W
Per W's Avatar
Oddometer: 22
Originally Posted by MJG2 View Post
What are you doing
Manual says after 1st hour
then every 15 hours
The 500 is a race bike and the intervalls in the manual refer to that kind of use of the bike. I firmly believe you could give those timings a bit of a slack with good consiousness if you use the bike for dual sport purposes. They now have 1,5 liters of oil in the engine in comparison with the 1,3 liters of the 530 and 525. Ideally you should follow the manual, but I wouldn't worry if I went longer on an extended weekend trip.
Per W screwed with this post 02-18-2013 at 01:46 PM
Per W is offline   Reply With Quote
Old 02-18-2013, 03:12 PM   #3319
Stifdickerson2006
Stifdickerson2006's Avatar
Oddometer: 137
Mark
You will be very happy with the SC seat. The seat is top notch and just as durable as any other. The gripper seat cover is great and holds you in place but is not to sticky where it hampers your movement, As far as comfort, the SC seat IMO is light years more comfortable than an EE seat or any race type seat. Your Arse will thank you, I am 6'1" 175lbs (tall and skinny w/no ass) my stock seats and EE seats would kill me after a 40+ mile ride. With the SC seat no issues even after multi 150 mile days.Thanks to Seat Concepts I dont have to buy Anti Monkey Butt Powder
No Matter Where You Go, There You Are.
Stifdickerson2006 screwed with this post 02-18-2013 at 03:14 PM Reason: attach pic
Stifdickerson2006 is offline   Reply With Quote
Old 02-18-2013, 04:20 PM   #3320
trailjammer
trailjammer's Avatar
Oddometer: 366
Mark
Congrats on the upcoming new bike mark. I'd have to agree on the Seat Concepts. I've had one for a while now it's real comfy on those long rides. The standard height is fine for me and I'm 5'10". It's not 'too grippy' just right.
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Old 02-18-2013, 09:51 PM   #3321
boostracer
Oddometer: 32
Headlight on
tips- advice
Mark
I wired a switch in the wire to mine so I could leave it off in the daytime. Wired the small bulb in the headlight to the hot side of the switch so it's always on when bike is running, so I still have a light for the "daytime running light" deal. I replaced my stock bulb with a halogen so didn't want it on all the time.
boostracer is offline   Reply With Quote
Old 02-18-2013, 10:49 PM   #3322
avconnect
Oddometer: 108
What tank is installed in the pictures and how was the installation?
avconnect is offline   Reply With Quote
Old 02-19-2013, 06:32 AM   #3323
MJG2
Oddometer: 53
Plug for evap harness
I plan to de smog and remove canister /hoses and solenoid valve -anyone find a nice cap for the plug that goes to the evap solenoid- Id love a cap that snaps in for a nice weathertght seal -I bet there is something out there thats OEM harness plug
I see some guys put grease in there and then elec tape it up -I'd like something cleaner
13 KTM 500 EXC
09 KTM 250 SX
05 KTM 300 EXC
09 Kawasaki KLX250S
07 Ducati Multistrada 1100 S
Old 02-19-2013, 10:58 AM   #3324
Stifdickerson2006
Oddometer: 137
[QUOTE=avconnect;20758121]What tank is installed in the pictures and how was the installation?[/QUO
That is the Clockworks tank, alot of people have had issues with them. Install is a bit more involved than the others, you have to cut and splice wires that go in the tank, but just take your time plan out the work and make sure you use good quality shrink tubing around the splices and the system should be good to go. I have around 1500 miles on mine. One of the issues with the tank is that the heat shield at the head falls off and then the head burns thru the tank. I pulled off the heat shield as the adhesive was failing and used high temp silicone to reattach it about 350 miles ago and it is solid. another issue is that because of how low the tank holds the fuel you have to put an extra piece of hose around the fuel line to protect from rubbing issues. After those two issues where taken care of I really like the tank as it holds the fuel down low and back closer to the center of gravity(how the bike was designed) than the other tanks.
Old 02-20-2013, 12:02 AM   #3325
boostracer
Oddometer: 32
If you're talking about the small hose fitting off the intake I just unscrewed it, plugged it, put it back on with hose in place, looks stock.
Old 02-20-2013, 01:40 AM   #3326
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,374
Originally Posted by bill1960 View Post
http://www.youtube.com/watch?feature...&v=_Z5xrdXEXDg
http://bestdualsportbikes.com/
After 100 hrs of dualsport use, I'm looking at lowering my 500 for easier dabbing and more stability. I'm 52yo and the bike is sprung for my weight (75kg)
Interested in the concept setout in the vid
For dualsport use, they suggest the bikes are too high in the back.
Remedy is internal shock spacer to lower seat height ~1" and fine tune with fork height in clamps and rear sag.
Has anyone tried this mod. Are you happy with the results.
I'm mainly interested in the concept, not necessarily bestdualsportbikes doing the work
here's another option for you
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is offline   Reply With Quote
Old 02-20-2013, 05:07 AM   #3327
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
wolfman rolie bag system and SC seat have been ordered! pictures soon to follow.
2012 KTM 500 EXC
NON SEMPER ERIT AESTAS
www.motoex.net
Nomad is offline   Reply With Quote
Old 02-20-2013, 05:40 AM   #3328
MJG2
Oddometer: 53
Elect connector on the evap valve
No -I am talking about the electrical connector -when you take off the Evap valve -it would be great to have a dummy plug
13 KTM 500 EXC
09 KTM 250 SX
05 KTM 300 EXC
09 Kawasaki KLX250S
Old 02-20-2013, 06:31 AM   #3329
bill1960
Oddometer: 358
Originally Posted by jesusgatos View Post
Yeah, the x bushing. Its advertised as lowering the rear up to 7/8"/22mm
I did install it but only got around 14mm 5/8"inch lower.
bill1960 is offline   Reply With Quote
Old 02-20-2013, 08:40 AM   #3330
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,204
bummer, for nearly $100 bucks you were only able to get 5/8" lower......don't think that it worth the money....
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Times are GMT -7.   It's 12:53 PM.
