02-18-2013, 07:02 PM
#16 |
mike
Oddometer: 75
I want one
02-18-2013, 08:59 PM
#17 | ||
Oddometer: 1,604
I say we take off and nuke the entire site from orbit. It's the only way to be sure
02-19-2013, 06:31 AM
#18 | |
Oddometer: 100
Tubeliss??
Tell me more!
02-19-2013, 07:04 AM
#19 | ||
Oddometer: 1,604
Just follow the installation directions to a T and dump in about half a cup of Stan's sealant into the tire and about a 1/4 cup into the bladder and you'll be in like flynn. As of now I only run it in the rear, but I'll probably be doing both ends soon enough. I got a puncture flat which put about a 3/8" hole in my tire and I didn't even notice it was flat until I got back to the truck. To fix is all I did was stuff in two plugs and another 1/4 cup of Stan's and it was good to go.
02-24-2013, 09:05 AM
#20 |
Oddometer: 100
Oil and filter help!
Ok, managed to get 1/2 hour of riding in (in the snow), now time for an oil change; my dealer is having trouble getting filters, the reccomended oil I can't find in New York! Of course I still don't have a manual from Husqvarna yet but internet tells me use Castrol Power 1 10w-50 which doesn't seem to exist in USA. Who's using what oil out there and where are you getting filters?
02-25-2013, 12:14 PM
#21 |
Oddometer: 70
Oil filter
The TE310 uses the same oil filter as does the Honda CRF250x, HiFlo HF116, I believe is the right number. Those filters are readily available.
02-26-2013, 06:05 AM
#22 |
Oddometer: 100
Thank's
BMAH thank's, have you been able to locate the 10w-50 castrol? I've checked all my local auto stores I guess I will try bike shops next then net.
02-26-2013, 01:46 PM
#23 |
Oddometer: 954
2012 te310 with 168 miles on it. is IT WORTH THE $6800 the guy is asking?
02-26-2013, 04:59 PM
#24 | |
Oddometer: 1,604
Seems high to me, but I don't know what your regional market is like. There is a 2012 TE250 for sale locally with 75 miles for a grand less. I'll bet it is worth it on grins alone, but you can probably do better price wise.
03-02-2013, 09:02 AM
#25 |
Oddometer: 100
TE310r oil change, is there a screen??
I was able to find Spectrol 10w-50 so thats what went in, rather pricy at $16 qt. The bike has a drain plug with magnet which had a little black on it. I'm guessing typical breakin no metal shavings. I wasn't able to get the oil sump hose fitting off it's a 12mm I think and my wrench seemed to want to strip it so I'll pick up a new 12mm for the task. I wanted to look to see if there is a pickup screen behind the fitting that needs cleaning!
Does anyone knows on the 2013 model if this screen exists?? (still haven't recieved owners manual) I'm also trying to purchase the shop manual but Husqvarna isn't replying to my dealer, maybe lag due to new ownership. Pretty quick easy job maybe took one glass of wine (too cold for beer still snow on ground). |
03-02-2013, 11:58 AM
#26 |
Oddometer: 100
Next question/ airfilter removal?
Ok removed seat, the electrical wire were tight across the air filter. after an hour of removing panels plugs ect.. made enough slack so that wires could be moved aside without having to unplug 3 plugs. While I was there I also taped up some battery connection that were close to the frame.
Ok now onto air filter removal, removed battery and platic bracket for battery and regardless of what I tried the filter seems larger than the hole I should be removing it through! Along with the correct manual maybe they forgot to send my the magical pixy dust to shrink the filter? Anyone have advice?
03-07-2013, 08:20 AM
#27 |
Oddometer: 487
Just picked up a new 2012 a few weeks ago.
I've only had it out for a few miles on road but so far so good. Light, nimble, and responsive. It is a very different bike from my DR 350.
03-07-2013, 09:47 AM
#28 | ||
Oddometer: 1,604
03-07-2013, 10:34 AM
#29 | |
Oddometer: 43
^^ i bought his. ![]() ![]() had 50 miles of fun on it last weekend. ![]()
USNF Trail Ambassador, Sandia NM ranger district. |
03-07-2013, 10:50 AM
#30 | |
Oddometer: 1,604
Damn what a Husky crew!
![]() What octane did you end up running? Please keep this thread updated! Either is is the camera angle or it looks like you fixed the subframe.
