Old 02-19-2013, 04:25 AM   #31
EasyJet_RC
Joyrider
Oddometer: 53
No probs,
I attached the filter to the factory line going to the injectors, added a new piece of 6mm fuel line to the tank (about 40 cm length). This was threaded between the shock & the tank, cable tied to the rigid lines (brake??? Oil return??... Not sure & will have to check) and turned up towards the" nose of the tank... The filter is nestled on top of the nose of the tank just under the injectors....
Apart from a bit of black fuel line that is visible if you know where to look you won't even know its there... & all newly components were routed and secure away from heat sources... For obvious reasons...
Ill try to get some pics as soon as I have a minute...
EasyJet_RC is offline   Reply With Quote
Old 08-23-2013, 03:46 PM   #32
JRWooden
Oddometer: 4,249
Originally Posted by EasyJet_RC View Post
... Went on the Holley no probs, install same as guzzimike except that I placed the filter on top of the tank in front of the shock, hidden be design- not on purpose, pipe work and filter shape made that just easy....
Where'd you put that filter?
I'm not quite with you ... but I think @ 40K miles it's time I switched out
Old 08-25-2013, 06:20 PM   #33
EasyJet_RC
Joyrider
Oddometer: 53
JRWoden,
I'm sorry I didnt spot your query earlier - I kinda forgot that I promissed some pictures of this... needless to say the mod is working perfectly - so much so that I forgot about it.
The filter sits behind the injectors (high up) with the fuel pipe routed to the right int othe filter and the filter connected to the injecter pipe (stock) - you cannot see the filter from the sides but have to take the little black panels of to expose the throttle bodies and see the unit.
I'll try to get a pic on the site in the next day or so.
Regards
Pete
Old 08-25-2013, 06:26 PM   #34
EasyJet_RC
Joyrider
Oddometer: 53
Location of Filter
Terry, I triend to contat your PM but no succe4ss so I thought I'll post here...
The silver filter in my pictures is located under the “lid” of the fuel tank – The part that the pump assembly is attached to.
It’s between the pump and the outlet spigot that connect the line that goes to the injectors – if you follow the line from the pump to the “lid” you cant miss it, it sits directly under the lid.
I replaced the pump, removed the filter and connect the pump outlet pipe directly to the outlet spigot – then used an inline filer in the line to the injectors – outside the tank…
Hope this helps.
Pete
Old 08-25-2013, 09:47 PM   #35
JRWooden
Oddometer: 4,249
... I'll try to get a pic on the site in the next day or so.
Regards
Pete
Thanks Pete!
No panic ... sometime after thanksgiving I'll be doing some statigic upgrades, and this will be one of them!
Old 10-05-2013, 12:29 PM   #36
Full Power
Oddometer: 1,472
Maybe if we get multiple threads simultaneously current, some body somewhere will help me find a 6mm or 1/4 " hose size INLINE one piece, metal cased 5 micron fuel filter, rated for 50 PSI fuel injection system.
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Times are GMT -7.   It's 09:44 AM.
