Old 02-18-2013, 07:09 PM   #1
rbm OP
Oddometer: 54
How to seal threads on emblem screws
Hi,
I'm going to be modifying my BMW K75 tank to accept /5 tank emblems using screws rather than adhesive. This means drilling and tapping the aluminum. Will I need to use a sealant (such as Locktite 242 or RTV) to seal the threads when installing the badges, so that there is no possibility of fuel leakage later? Or is the rubber gasket between the badge and tank sufficient to stop leakage?
I had also contemplated using slightly longer screws with flanged nuts on the inside of the tank. Bad idea?
BTW, posting in this forum since it's more likely to have someone in the know read this than in another forum, like Road Warriors.
- Robert
rbm is offline   Reply With Quote
Old 02-18-2013, 08:04 PM   #2
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,629
I have a hard time believing that this idea won't leak regardless of the sealant.
crazydrummerdude is offline   Reply With Quote
Old 02-19-2013, 12:34 AM   #3
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,506
Weld in an aluminum nutsert. You could also cut the heads off of the screws, JB Weld them in place and use 3M double sided tape to hold the emblems on.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 02-19-2013, 04:03 AM   #4
bikerfish
flyfishandride
Oddometer: 1,602
I second the "fake screw" idea. just glue the heads onto the emblems and use the tape to hold the emblem on, nobody gonna know!
bikerfish is offline   Reply With Quote
Old 02-19-2013, 05:45 AM   #5
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,511
I wouldn't penetrate the wall of the tank if I were you. That seems like a losing proposition no matter how you seal it up again. I'd have someone weld or braze a blind threaded insert into the wall of the tank and screw them into that.
EDIT: Considering the difficulty involved in doing the above, the 'fake screw' and adhesive method mentioned earlier is what I would do.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 02-19-2013 at 06:43 AM
Old 02-19-2013, 06:25 AM   #6
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,732
Originally Posted by AW
I'd have someone weld or braze a blind threaded insert into the wall of the tank.
That is how the /5 (and earlier) tanks do it.
That is how I would do it.
--Bill
'73 R60/5 Toaster
Old 02-19-2013, 07:25 AM   #7
kantuckid
Oddometer: 3,077
plus 1,000,000+!!!!!
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Old 02-19-2013, 08:05 AM   #8
Kai Ju
Kai Ju's Avatar
Oddometer: 1,868
Most folks here try and seal old tanks that have holes in them, here you want to go and make holes.............
Fake the screws, nobody will know, whereas if you drill the tank and it leaks it will show
Kai Ju is offline   Reply With Quote
Old 02-19-2013, 06:53 PM   #9
rbm OP
Oddometer: 54
Well, good I asked. I got consensus on faking the screws and using double-sided tape so that's the way I'll tackle this modification. Thanks to everyone who responded.
- Robert
Old 02-19-2013, 06:54 PM   #10
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,353
Go ahead admit it...you want a /5
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 02-19-2013, 10:36 PM   #11
wmax351
Oddometer: 743
If I recall, the K bikes have a double wall tanks. In any case, cut off the heads, and glue it on.
wmax351 is offline   Reply With Quote
Old 02-20-2013, 11:57 AM   #12
Boxer Metal
Mad Scientist
Oddometer: 3,506
Nope on the double walls.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 02-21-2013, 12:16 AM   #13
wmax351
Oddometer: 743
Good to know. I have a little dent from someone's handlebar I need to pop out.
Old 02-21-2013, 05:09 PM   #14
rbm OP
Oddometer: 54
Ya. Wouldn't mine in the least!!
- Robert
Times are GMT -7.   It's 04:26 AM.
