02-18-2013, 10:29 PM
#74026 |
Grumpy Young Man
Oddometer: 3,764
02-18-2013, 11:02 PM
#74027 | |
Grumpy Young Man
Oddometer: 3,764
I currently use just the flushmount tail/brake light from the Procycle kit, with an LED 1157 bulb that flashes 3x then goes solid. I also use the stock black lower fender piece, the stock license illuminator with a 194 LED bulb from www.superbrightLEDs.com, and a Procycle license-mount stashbox bolted to where the stock tag bracket and lower rub-nubby used to be. The black lower fender piece protects better from mud flinging up on my back. Mine is trimmed up a little though. It only protrudes beneath the tag by about .5". I also have some BRIGHT red 8" LED strips on either side of my fender. I like the look and functionality of my current setup. My tail/brake light looks nice and neat, and it isn't likely to bust apart like the stocker did. I have a locking compartment for registration and my pressure gauge. I have side and rear red reflectors. My back doesn't get slathered in mud. My tail is seen better and uses less wattage than stock. My tag is fastened at all 4 corners. I'd get just the light and a stashbox. Put a 3x flash LED 1157 bulb in the light. Put an LED 194 bulb in the tag-illumination housing. Add red LED strips on either side of the fender, either upper or lower piece. |
02-18-2013, 11:29 PM
#74028 | |
Grumpy Young Man
Oddometer: 3,764
02-19-2013, 03:40 AM
#74029 | |
Oddometer: 111
As noted elsewhere in the thread, the DR350S/SE (street legal version) wheel will work, the DR350 off-road model does not have a cush hub and _might_ work with the right spacers but I think the S model wheel is a better choice for the 650. It just drops right in using your existing sprocket carrier. The bearings are the same in the two. The brake rotor is not. You'll need a DR650 rotor for the DR350 wheel. Also, the 18" 350 rim is more narrow and I'm running a 120/90 on mine. Jim Randall thump! screwed with this post 02-19-2013 at 05:58 AM |
02-19-2013, 03:44 AM
#74030 |
Oddometer: 641
Thats what I use on my foam uni.....works great for me as well
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack |
02-19-2013, 03:49 AM
#74031 |
Oddometer: 111
I too have owned both. I really like my DR and it fits my needs better (it's more off-pavement oriented) but I think the KLR is a better choice as a street bike. The 2007 and newer KLRs have a pretty nice faring, are smoother and have better suspension then the earlier models.
thump! screwed with this post 02-19-2013 at 06:01 AM |
02-19-2013, 03:52 AM
#74032 |
Mindless Savage
Oddometer: 869
Its the re-oiling part that I have problems with. Do you saturate the filter with oil or just give it a light film?
2008 DR 650 We can handle it....We're Canadian |
02-19-2013, 06:03 AM
#74033 | |
Life behind "Bars"
Oddometer: 6,266
I have both also. The 650 has a 2.50 rim and the 350 has a 2.15. (width) and the 350 has a rimlock if memory serves me. I'll have to go out in the garage and look. I put a rimlock on the 650 wheel as well. I run knobbies most of the time, but I have a Bridgestone Trailwing that came off a new DRZ 400 on the 18" right now, from a trip I took in Sept. I do recall having fittment issues with the 650 rotor on the 350 hub but can;t remember what I did. The bolts aren't the same and I ended up doing something different. Like flipping the rotor over or something. really can't remeber, but it was solveable maybe someone can remember what they did. I was lucky to get my 350 wheel with an axle, chain adjusters, sprocket hub and cushions and a new 41 tooth sprocket for $75.
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
02-19-2013, 06:17 AM
#74034 |
ADV in training
Oddometer: 610
Simple Green is what I used to clean my K&N. It worked better than the actual cleaner they sell. As for oiling it, I went with a fairly light spray.
_________________________ Ride videos '01 DR650 "The impossible often has a kind of integrity which the merely improbable lacks." |
02-19-2013, 06:22 AM
#74035 | |
Oddometer: 75
Matt
http://midcoaststudio.com/news/harle...e-photography/ |
02-19-2013, 06:54 AM
#74036 | |
Dual Sport Addict
Oddometer: 988
Let me help confuse things
This is the same thought I had. I have a DR350 and am useing an RMX swingarm with the stock DR350 (dirt model) wheel. The spacers are just cut down a hair as the RMX swinger is narrower. I think that if the stock DR350 rim can be made to work with the RMX arm then the RMX wheel should be able to work on the DR650. Also, I think that if you are using the DR350 wheel as your dirt wheel and always run a knobby on it the cush drive wont be needed, the knobs will buffer the trans on road. My DR350 is a plated dirt model with no cush and it seems fine on the street but it doesn't spend much time there. It has the same forks as the RMX as well, as it is a '98. They are great forks and are fully adjustable, they seem like a no brainer mod to me as they fit the stock DR650 triple.
2011 DirtRoad650 http://i838.photobucket.com/albums/z...mping12182.jpg '98 DR 350 http://i838.photobucket.com/albums/z...t/Photo280.jpg '99 DR 650. Sold. |
02-19-2013, 07:34 AM
#74037 | |
Oddometer: 75
Thanks Matt
02-19-2013, 07:46 AM
#74038 |
Motersykle Advntyers
Oddometer: 439
Hey guys, my DR is having a hard time cranking when its cold. 5 or 6 times of holding down the starter for 2-3 seconds before it turns over. Time for a new battery or will a few days on a tender fix this? Its happening every cold morning.
I haven't been everywhere, but it's on my list. 2007 BMW R1200 GSA, 2009 DL1000, 2005 DR650 |
02-19-2013, 07:58 AM
#74039 | |
Oddometer: 144
(just kidding) Every 3-4 months I take the 5 gallon jug to my nearest service station to be recycled. Once the filter is cleaned really well with Diesel (literally takes 30 seconds), then I give it a quick wash with a solution of dish washing liquid and H20. Then I let it dry overnight, and re-oil and re-install. And no, the Diesel does not harm the filter media. |
02-19-2013, 08:34 AM
#74040 | |
Mostly Harmless
Oddometer: 1,713
BTW, I do NOT recommend the fancy new lithium-ion jobs. I have one on my FZ1 and it won't start in super cold weather without using a tender just to keep the damn thing warm. Rob
'96 Suzuki DR650, '10 Kawasaki KLX250S, '01 Yamaha FZ1 The Lane Sharing Works Blog | My SPOT Page |
