02-18-2013, 07:52 AM
#6946 |
Oddometer: 641
My problem is with oil leaks is the smell. My head cover gasket leaked oil into the spark plug well and when you'd sit at intersections all you could smell was burning oil. To me it's a terrible smell because of certain memories it brings back. I used to work on cars as a kid and every whiff of that I get reminds me of all the leaky old shitboxes I had to deal with.
02-18-2013, 12:14 PM
#6947 | |
Oddometer: 175
I know that smell and hate it too. The previous owner of my XL had taken off the breather and installed a miniture K&N looking filter there instead. Whenever I would stop you would smell that burning oil/blowby smell. I hooked it back up to the air cleaner and all was well with the world again.
02-18-2013, 01:59 PM
#6948 |
SAND EATER!
Oddometer: 485
It leaks pretty good, I gotta top the oil off every couple days. I cannot stand oil leaks, it's more or less a pet peeve for me.
'83 Honda XL600R valve seat ![]() RIDE RED! |
02-19-2013, 03:58 AM
#6949 | |
Oddometer: 641
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack |
02-19-2013, 05:06 AM
#6950 |
Oddometer: 175
It is not so bad to do. Just get the engine washed and ready, get yourself psyched and ready and it really goes fairly quick if you have all the parts on hand. I recommend Honda genuine seals and gaskets and a light skin of Hondabond on the top cover gasket. ( I almost never replace that one since it is steel, just clean it up and reseal it).
If you are not pulling the head or cam, which it looks from the pictures that way, the whole job should take only about three hours without beer.
02-19-2013, 07:44 AM
#6951 |
Oddometer: 1,627
Would anyone like to see a Cycle World test of the "new" 1983 XL600R? I'll scan it and post it up if there's interest.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F |
02-19-2013, 09:44 AM
#6952 |
Oddometer: 196
One vote for YES
Current Bikes: 1986 Honda XL600R, 1988 Hondasuki KLNX250R, 1988 BMW R100GS (dead) Previous Bikes: Honda XL250 (2 of them), Honda XL600R, Kawasaki KLR600, BMW K1100LT, BMW R60/6, BMW K75, Husqvarna 430XC Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com |
02-19-2013, 10:34 AM
#6953 |
¯\_(ツ)_/¯
Oddometer: 1,246
Is that the one with the XL flying over a cop's head on the cover?
1995 XR628R -Lots of goodies...room for more. Drinking: Funky Cold Medina. |
02-19-2013, 01:54 PM
#6954 |
SAND EATER!
Oddometer: 485
02-19-2013, 02:56 PM
#6955 | |
Aspiring human
Oddometer: 2,135
1987 Yamaha XT600 2KF (German) STOLEN: RED XL600 in Portland I do heavy-duty textile repair, upholstery, and design/manufacture bags. |
02-19-2013, 05:56 PM
#6956 |
SAND EATER!
Oddometer: 485
The engine was rebuilt previously, about ~4,500 miles ago. It runs like new, and has excellent compression, real easy to start, mos of the time. It just leaks so much oil and its hard to keep the engine clean. I do a lot of trail riding so that just covers the motor in sand and it just cakes on after a few rides
Hard to keep the bike clean commuting on it and working full time. I usually just wash the engine
02-20-2013, 05:06 AM
#6957 | |
Oddometer: 175
I know how that is, my XL started leaking from the cylinder base gasket years ago and I was using it as a commuter too. It was hard to catch it with the wheels stopped long enough to fix it. I eventually did though, planned ahead and bought parts. One saturday i I just did it. I had put a Wiseco 102.4 overbore in about 8,000 mile before that and was not sure if I would need rings so I hadn't bought them, but as I suspected the end gap was still fine so no problem there. Soon it was back together and running without oil blowing back on my pant legs in little droplets.
02-20-2013, 05:59 AM
#6958 | |
Oddometer: 1,627
02-20-2013, 07:25 AM
#6959 |
Oddometer: 152
I just wanted to post a follow-up with the issue I was having. Upper RPM after the secondary carb kicked in, the engine would break up and bog, badly. I installed a Rick's XR600R CDI, and while the bike started and ran much better than before, the problem was still there. At this point, being at whits end, I took the carbs off again. As soon as I removed the bowl from the secondary carb, I found the problem, laying there, as if to laugh at me, the main jet! I swore up and down, that not only had I had the carbs off, rechecked everything, but maybe I didn't. Admittedly, I've taken many shots to the head over the years, and probably mixed up which bikes I was working on, and which carbs I had off. Too many projects. So anyhow, after re-tightening the secondary main jet, the bike fired right up!
Moral of the story is this, never be a fighter for a living, because you will loose your marbles...or main jets..... |
02-20-2013, 05:14 PM
#6960 |
Oddometer: 51
I hate to ask this question because for those that know what they are doing will know this answer. I omit that I don't know what I am doing but I am learning as I go.
Is 101.00mm the stock rings for the 83 600r? Thanks |
