Old 02-19-2013, 08:26 AM   #1
S H I F T Y OP
S H I F T Y's Avatar
Oddometer: 721
Power Supply for Tablet?
I have my Google N7 in my tank bag, using it for a GPS, etc.
I just bought this from Tusk Racing / Rocky Mountain so I can charge the tablet, phone, etc.
Is there any trick to wiring this up, or does it just connect directly to the battery?
S H I F T Y is offline   Reply With Quote
Old 02-19-2013, 08:30 AM   #2
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,663
No trick. You can connect it directly to the battery.
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman is offline   Reply With Quote
Old 02-19-2013, 08:52 AM   #3
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,759
If you connect to battery it will always remain on. If you want the outlet to turn off when bike is off, a relay would be a better option.
Personally I like the gps to remain on so it doesn't cycle every time you turn bike on and off. Also make sure your usb has enough amps to run a tablet, I was unaware there was a difference but noticed some of my droids wouldn't charge for beans with a random plug. Also having a live outlet allows you to quickly attach a battery tender through the 12v plug
But you need to remember it's always on or you can have a dead battery especially with something that draws a lot like a tablet.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 02-19-2013, 09:05 AM   #4
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,663
Good point on the USB charger. Many are 1 amp, but tablets need 1.5 to 2 amps to charge effectively. I believe the ones sold for Ipads are 2 amp.
The Rock 2013 RR
Old 02-19-2013, 09:38 AM   #5
victor441
victor441's Avatar
Oddometer: 993
dual USB converters are also available, 2 amps for a tablet and 1 for a phone, this one is made by iflash....
victor441 is offline   Reply With Quote
Old 02-19-2013, 09:48 AM   #6
S H I F T Y OP
Oddometer: 721
I was just going to use the car charger that came with it not a usb. So if it is hooked to the battery, is it always on, or just on if the key is on?
Old 02-19-2013, 10:14 AM   #7
victor441
victor441's Avatar
Oddometer: 993
always on wired that way, though it would be easy to add a relay if you wanted it only on w/ the key on
Old 02-19-2013, 10:16 AM   #8
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,663
Always on. It's not much of a battery drain risk unless you leave it plugged in for an extended period with the key off. As noted above, it's really handy to be able to leave things plugged in while the bike isn't running. I've run my GPS for years this way, and haven't had any issues.
Be very careful with the charger in damp conditions. The plug that goes into your tablet is likely a micro USB. They are not noted for their robust nature, and there are numerous reports of folks frying stuff by plugging in a wet cable.
The Rock 2013 RR
Old 02-19-2013, 10:40 AM   #9
S H I F T Y OP
Oddometer: 721
Thanks for the tip. It is a micro USB, but I'm gonna run the cable up through the bottom of the tankbag and plug it into the tablet; which is under the waterproof plastic. So in theory, I should be alright.
I will probably just run it to the battery directly. If I am understanding you guys, as long as nothing is plugged into the power supply it is just sitting there dormant not draining the battery. Well, the only time something will be plugged in is if I'm riding it, so I will just keep it simple and hook it directly to the juicebox.
Old 02-19-2013, 04:57 PM   #10
Aaen
Aaen's Avatar
Oddometer: 88
Make sure to use di-electric grease on the connectors, it will provide some weatherproofing. I basically packed the cigarette lighter output with this grease prior to plugging in the usb adapter, worked like a charm. I built my own cable that connects directly to the battery tender plugin, stuck a fuse on it. I left a switch off as it draws very little from the battery when left plugged in. If i want it off i just unplug it from the battery tender cable and voila.
Think everything cost me 15 bucks from radio shack, give or take.
Steve
Sent from my iPad using Tapatalk HD
Aaen is offline   Reply With Quote
Old 02-19-2013, 06:21 PM   #11
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,663
There's a product on the shelves called "silicone repair tape." It sticks to itself, and provides a bomber moisture seal. If you are going to plug the car charger into a standard cigarette-style outlet, a few inches of this stuff will insure a good connection.
I've recently found a waterproof case for my 7" tablet. It's not without issues, but I think I can make it work. While designed for the Samsung Galaxy, it fits my Lenovo tab nicely. It's an Aryca case, which appear to be just coming onto the market. I have one in hand, but sourcing is sketchy. I'll be field-testing soon.
I've been fiddling with the Dualsportmaps app, and think it will be very useful. I see that's what you're navigating with. I'm not yet ready to give up my dedicated GPS, but I'm going to give Craftycoder's product the college try. While I'm doing that, I'll have my primary GPS, the tablet, and likely a spare. I hate being in the boonies without reliable navigational information.
The Rock 2013 RR
Canuman screwed with this post 02-19-2013 at 07:32 PM
Old 02-19-2013, 07:16 PM   #12
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,811
I think I will just go this route.
http://www.ebay.com/itm/waterproof-D...item460c85b24e
or this
http://www.ebay.com/itm/waterproof-D...item3ccadb431a
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is online now   Reply With Quote
Old 04-18-2013, 12:01 AM   #13
TipsyMcStagger
TipsyMcStagger's Avatar
Oddometer: 1,025
How's that tablet been working out for you?
Tipsy
2008 Buell XB12X Ulysses
"There's a plane! Where there's a plane there's probably a pilot! Where there's a pilot there must be a bar! I can finally get a drink!" - Brian from Family Guy
TipsyMcStagger is offline   Reply With Quote
Old 04-18-2013, 03:30 AM   #14
Laconic
Anodyne
Laconic's Avatar
Oddometer: 18,112
Tipsy
+1 I'd like to hear how it's working as a GPS.
Laconic is online now   Reply With Quote
Times are GMT -7.   It's 08:05 AM.
