Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 02-19-2013, 10:18 AM   #646
Dirtmonkey8
VA is for Riders
Dirtmonkey8's Avatar
Oddometer: 1,264
Uni pre filter group buy
We have another group buy going on for the UNI pre filter for extending the life of the stock air filter. We are closing the group buy and placing the order at the end of February next week. If anyone is interested in joining this group buy or is looking for more information here is a link to the page. http://advrider.com/forums/showthrea...818121&page=14
A little dirt don't hurt.
Dirtmonkey8 is offline   Reply With Quote
Old 02-19-2013, 10:21 AM   #647
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,644
Originally Posted by cug View Post
I got the plate from Revzilla and the Givi kit from AltRider. It's nearly a year ago though. They are both great to deal with. I had some trouble with the fitment first but AltRider send a new plate that then was absolutely perfect. Maybe their first "setup Tiger" had some unusual spacing there ...
Looks I can get it all from AltRider. That may be the way to go.
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is offline   Reply With Quote
Old 02-19-2013, 10:38 AM   #648
TekurRides
Oddometer: 73
Yes, you can. That's what I did. I even got the Givi V46 from them. The plates are solid and the top case can be mounted and unmounted within seconds. I would highly recommend this setup. One small thing I noted are some poke marks at the back end of the plate where the box seems to be poking the plate somehow. Still need to investigate this further.
TekurRides is offline   Reply With Quote
Old 02-19-2013, 11:00 AM   #649
Poweranger
Oddometer: 796
Originally Posted by fbj913 View Post
if your talking about taking out the threaded inserts just remember you will shorten the bars quite drastically. you will also need to move everything in towards the center/ cut your grips. or replace the bars... maybe I'm not reading that right?
I just checked the exploded view of the bars in my service manual and it appears that is exactly what you would have to do. This explains a lot as I thought the inner threaded part really looked to be machined or cast directly to the bar. But it appears the entire end spins off and would shorten the bars.
browneye Today 12:47 PM
I was looking for a way to avoid drilling and tapping. While I've had good success with that process I just thought removing those threaded inserts and using standard mounting expanders would be better. Then again, maybe not.
Yes the drilling and tapping was a little more time consuming than I wanted to spend but it's winter here in Michigan and I did not have anything else to do. But I do not think you should worry. Those stock ends seem very sturdy. I just wanted the larger bolt for more thread grip and the counter sunk head to fit properly in the guard.
Poweranger is offline   Reply With Quote
Old 02-19-2013, 11:14 AM   #650
Poweranger
Oddometer: 796
Originally Posted by blacktiger View Post
Pliers???? Those things are in there tight. I do know they come out because a friend of mine got them out of his TEX bars. Just need to use the correct size spanner on those flats.
I thought I might get chastised about the pliers comment a little. I just happened to have them in my hand and thought I would try. Not realizing the entire bar end is all one piece. Anyway I'm glad I didn't break it free it. I am guessing the grip would have to come off first anyway?
Old 02-19-2013, 11:17 AM   #651
Poweranger
Oddometer: 796
I am going with the AltRider also and noticed the same thing with Revzilla not having the stock. To bad because it would save me close to 20 bucks shipping getting it from Revzilla.
Old 02-19-2013, 11:25 AM   #652
backwoodsKLR
Oddometer: 9,644
Just placed my order for everything from AltRider. I will still get it. it will still work. Just cost more... had some Zilla points with Revzilla that I can't seem to find anything to use them on. Oh well... ride on!
2013 Tiger 800XC
Old 02-19-2013, 11:28 AM   #653
cug
Oddometer: 4,980
I've added a few more rubber bumpers on the bottom of the case to also prevent rattling a bit better. Works quite well now. Although I will buy a smaller top case in the near future as the V46 feels "like a small planet following you" (Quote from somebody here on ADV Rider, forgot who it was).
R1200R/RS LC Forum
cug is offline   Reply With Quote
Old 02-19-2013, 01:40 PM   #654
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,765
So what is the best way to mount a Givi Monokey case on a 800XC? ...
I want the rack to be black to match the Tiger and the SW Motech appears to only be available in Silver powdercoat on the TT site, but the pics show black.
There is a pretty big price difference in the difference plates and adapters.
Another option is the CJ Designs tail rack, which I've got on my Tiger (and which is made by an ADV inmate, cjracer).
http://www.advrider.com/forums/showthread.php?t=752050
Excellent piece of kit. Very sturdy and stable.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 29-31, 2015
markbvt is offline   Reply With Quote
Old 02-19-2013, 05:18 PM   #655
Oshiat
Oddometer: 157
+1 on the CJDesigns tail rack. I mounted my Pelican case by putting carriage bolts through the slotted as shown in the attached thread. Makes for a very secure lockable case.
Oshiat is offline   Reply With Quote
Old 02-19-2013, 11:08 PM   #656
BryanCO
CO Rider
Oddometer: 504
Just received my black AltRider rack from Revzilla. Very nice!
The free shipping and Zilla points/$ (essentially 5% store credit -- $5 for every $100 spent) is also nice...
BryanCO is offline   Reply With Quote
Old 02-19-2013, 11:14 PM   #657
BryanCO
CO Rider
Oddometer: 504
Anyone have the AltRider crash bars? Don't recall seeing any when reading through the various threads. Ya, need to search....
Old 02-20-2013, 02:52 AM   #658
JD
JD's Avatar
Oddometer: 400
You mean these?
JD is offline   Reply With Quote
Old 02-20-2013, 04:55 AM   #659
deptom
deptom's Avatar
Oddometer: 21
Originally Posted by Rob Dirt View Post
If you want to use the TT upper bars instead of returning them, then you need to install the rear bolt first. This bolt screws into the motor, so try not to mess anything up. I left it touching, but not tight. The next bolt is the other motor mount. This bolt uses a nut so you only have to worry about the threads on the bolt. It is possible, but it's your choice. After those two bolts are in, the rest is easy. Just make sure you don't have clearance issues after your finished. I had to adjust mine a bit. The forks hit & the triple tree hit. Now, everything fits & clears.
Followed your advise Rob Dirt. Had to ask a couple of mates to help me out with the install together with a few other TT farkles.
Life may begin at 30, but it doesn't get real interesting until about 150. ~ Unknown
deptom is offline   Reply With Quote
Old 02-20-2013, 06:05 AM   #660
DropinParts
Ducatista
DropinParts's Avatar
Oddometer: 94
Thumb Saddlemen Seat
I wanted to let you guys know about the Saddlemen one piece seat I just purchased from Revzilla.
I'm a big guy and the riders portion of the stock two piece seat is too short for me (front to back). My butt is partially on the passenger seat, which after 30 minutes feels like I'm leaning on a sawhorse.
Because the riders portion of the Saddlemen seat tapers back about 1 1/2", it is MUCH more comfortable.
Here's a shot of the seat.
Very well made, very comfortable. I've bought a lot of farkles and this is the one I am most happy with.
The only thing I thought might be a drawback was that it does not have the option to be placed in the higher position like the stock seat. It only mounts in the low position, but turned out not to be a problem at all.
The seat installed straight out of the box. No hardware to move over from the stock seat.
The weather has only allowed me to get out for an hour ride last week and that was the most comfortable ride I have taken on the Tiger.
There are two roads in life, the twisty one is vastly more fun.
DropinParts is offline   Reply With Quote
Times are GMT -7.   It's 03:40 AM.
