Old 02-18-2013, 07:44 PM   #1
kougan OP
Oddometer: 114
Airhead Gearbox Woes
I had written a very long-winded story of what happened with my /5 and my process of diagnosing it, but unfortunately this site logged me out as I submitted. So I'll save you time and give you the short version:
Riding at highway speeds for an hour and a half. Stopped for a pitstop, started the bike up again and heard a very loud, disheartening grinding sound. It stopped when I pulled the clutch in, then resumed as I let it out. Towed it back home and thought it was either the clutch or gearbox. Took the gearbox out (a 5-speed installed by the P.O., not 4-speed) and found:
1. Water mixed with the gear oil
2. No felt on the pushrod, pushrod a bit rusty. Perhaps water and oil leaked into the clutch, causing a mess?
Bearings look a bit "burnt" on the sides, as do their insets in the casing cover. They roll fine though. Got the input shaft out fine, but cannot, for the life of me, get the other two out. Any suggestions on getting these out? Don't know if there is a circlip involved or not. The input shaft has an "X" scratched into it. Should the other two shafts have Xs also?
Does this grinding situation sound familiar to anyone?
Next will be checking the clutch out.
BlackenedBearings
InsetsClean
kougan is offline   Reply With Quote
Old 02-18-2013, 08:19 PM   #2
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,358
It appears you have a kick start 5 speed. So this would be a 1974 5 speed maybe? Do you know?
You say there is an X on the input shaft? Where? I mean where is this X. If you are thinking these might be X gears, they might but the X is on the angle cut gear only, not on the shaft.
To get the other shafts out heat the case with propane torches. Usually use two torches because it takes a lot of heat. I use Mapp gas in my propane torch it burns hotter. If you have Acetylene you have to be careful to not get the flame too hot and melt a hole in the case. Heat the case with the opening down and the shafts will fall out.
The blackening on the bearings is not a problem. Check bearings for lateral movement, looseness. And roughness.
You should be prepared to reshim this box but did you catch the shims that were in it so you know where they were?
The noise you describe sounds like it's from the clutch. Was it louder when driving or just at idle?
---Albert Einstein
Old 02-18-2013, 08:38 PM   #3
kougan OP
Oddometer: 114
Thanks, Disston. It is a kickstart, though I'm not sure on the year. I'll have to check for a serial number.
And yes, the X is on the shaft. I haven't spotted any on the gears. So if it's on the shaft, then its not the revised gear angle? Wow, confusing.
I tried heating with a torch, although with a page full of warnings against it in Clymer's I just went for *light* heat. I'll give it a little more and see if that does the trick.
The bearings aren't really loose at all, and I did mark all the shims, so all in all, the gearbox might be fine. There was a little oil seal piece sitting on one of the bearings that I misplaced thought, so hopefully that's not an issue.
The grinding was louder when driving than at idle, though i only took it a few feet for fear of decimating some internals.
Thanks for your help, I'll have to get into the clutch.
Old 02-18-2013, 09:01 PM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,358
I don't know what to tell you about the box. The front bearing on the out put shaft is usually the first to go so you want to check that one and it's still in the case. Don't know about Clymer's warning about heating the case. I wonder how they think you are going to get the bearings out? It's not just Clymer's manuals that have weirdness tho, it's all manuals. I've found weird stuff in Ford Shop manuals.
Yep sounds like oil or grease on the clutch? Rear engine seal been leaking? Have you recently lubed the splines just before this happened? Take the clutch out. You can clean them and they usually work pretty good but the last time I over greased my trans splines and did this it was a ten year old clutch so I replaced it.
Oil seal? You found part of an oil seal? Would this be the trans front oil seal? A source of oil on the clutch if it is.
---Albert Einstein
Old 02-19-2013, 05:11 AM   #5
bikerfish
flyfishandride
Oddometer: 1,576
if it were mine, I'd replace the bearings, you already did most of the work! new bearings , reshim, new seals, and you'll have a box that you KNOW is good to go for a long time.
the problem may be in the clutch, worth checking out since the tranny is out of the way, might as well check the main seal and oil pump o-ring as well since your there, replace if needed.
from the symptons you describe, it sounds like a bad input shaft bearing. I don't trust the old "hand" check method, you just cant duplicate the forces on a bearing by spinning it in your hand. I've had noisy ones that felt fine when I took them out, but after replacing them, the noise was gone.
oil on the clutch is gonna make the clutch slip, but I've never heard any grinding noises from that. worn rivets will make some noise though, but from the ones I've heard, it's more of a rattle, not grinding.
bikerfish screwed with this post 02-19-2013 at 05:19 AM
bikerfish is offline   Reply With Quote
Old 02-19-2013, 07:49 AM   #6
Fast Idle
Since the Sixties
Fast Idle's Avatar
Oddometer: 310
The warnings on heating the case and cover are about NOT using a torch as it can warp or otherwise cause damage. Do yourself a favor and buy a heat gun and a laser point thermometer. Both are relatively cheap these days. These are a mechanics best friend, well besides the BFH. Anyway you can easily and evenly heat the case with the heat gun and check the temps with the the thermometer. I find everything comes apart fairly easy around 180 degrees but I believe BMW calls for 212. It works great for changing the bearings too. Heat them and they come off easy. Heat the new ones and they go on easy. You'll also need to heat the cover for reassembly and the end play measurement game as well. Seriously buy a heat gun and you won't believe how you ever got by without one, a must have tool for this kind of work!
2002 R1150 GS
74 R90/6- Restored
69 Triumph Daytona 500- Survivor
1970 Honda SL100
- Survivor
Riding as much as my old frame will allow!
Fast Idle is offline   Reply With Quote
Old 02-19-2013, 08:07 AM   #7
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,493
Make sure you get one with the little stand that allows you to set it up to heat something without you having to hold it. That way you can let something heat for a few minutes while you're doing something else.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 02-19-2013, 11:51 AM   #8
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,597
Did the clutch work ok or did it grab a little?
I had the spot welds on my clutch come adrift a few years ago made the clutch grabby and also made some very strange noises but appeared to work fine apart from those issues. When It finally got to the point that it wasn't adjusting properly I pulled the gearbox and found the pushrod snapped and the pop rivets all adrift. I'd check the clutch while your in there. You can see the chatter marks on the clutch plate.
Rob Farmer is offline   Reply With Quote
Old 02-20-2013, 12:09 AM   #9
Padmei
enamoured
Oddometer: 3,653
It took a LOT of heat to get my bearings out - much more than my mechanic friends were happy with. My gas torch wasn't grunty enough. I ended up having to use a slide hammer around the bearing to get one off & the other fell out at the same time. I'm not advising you to do this but pointing out they can be buggers to get out.
Padmei is offline   Reply With Quote
Old 02-20-2013, 01:04 AM   #10
ME 109
ME 109's Avatar
Oddometer: 2,718
I'm a heat gun supporter as well.
Not so sure I like the blackened bearings. Would it not show that the bearings have been spinning in the cover?
I wouldn't put it back together without changing the bearings. They are reasonably cheap.
A thorough rinse of all shafts and selector mechanism in a tub of petrol (or proper safe fluid ) to remove any crud.........there will be crud.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 02-20-2013, 03:16 AM   #11
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,632
[IMG]http://i242.photobucket.com/albums/ff38/R_Farmer/WEG/Pushrod.jpg[/snip]
Very good, Rob. I have a high-mileage /5 clutch (188K over 40 years on the clutch plates) that has been through three clutch friction discs (and diaphragm springs). The pressure pieces, being worn, were to be remachined by Southland Clutch, but I was having concerns about the pressure plate and those spot welds to the sheet-metal pan a that mileage. I'm not hard on a clutch, but it seems that the pressure plate might be the weak point here. I'll evaluate it, but I'm inclined to replace with new rather than patch the old part.
--Bill
'73 R60/5 Toaster
Old 02-20-2013, 10:43 AM   #12
kougan OP
Oddometer: 114
I agree with you on the bearings possibly spinning in the cover. May as well replace them while I've got the box open, along with the springs, which I've heard tend to fail in time. Everything else looks to be fine though. I'll take the advice and try a heat gun on the other two shafts. The torch isn't cutting it.
--Bill
The clutch did seem a bit grabby, but again, I really didn't test it's rideability, for fear of making symptoms worse.
Looking at your pic of the chatter marks on the clutch plate, I'm thinking something similar happened in my case. Hopefully I can find the time to get to that clutch this week.
Old 02-20-2013, 01:30 PM   #13
ME 109
ME 109's Avatar
Oddometer: 2,718
It will take a few minutes to heat up enough with the heat gun.
Once in the vicinity of the necessary temp, use one hand to pull/rattle the two shafts while continuing to heat the front of the tranny.
Don't use loctite or similar to retain the bearings in the cover!
If the bearings are spinning in the cover (and it looks to be the case) they will be grinding away at the shims as well.
The cover may be toast??
Old 03-05-2013, 12:29 PM   #14
kougan OP
Oddometer: 114
I'm wondering where any of you have found cheap bearings...or bearings at all for that matter. There's no shop locally in my area that carries what I need and I haven't found any online besides ebay, and those don't seem exactly cheap to me.
I tried a heat gun, then back to the torch again, then heat gun again, and still no luck getting the remaining two shafts out. So I think it's safe to say the bearings on that end aren't going to be spinning around in there, unlike the other ones. I'll just leave them alone and replace the three. Those, along with the springs on the selector mechanism.
Got the engine out of the frame and will be examining the clutch this week.
Old 03-05-2013, 12:56 PM   #15
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,806
Call any BMW dealer, or commerical bearing supplier.
Anton lists the bearing specs here: link
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Times are GMT -7.   It's 05:21 AM.
