Old 02-19-2013, 11:41 PM   #1
Samy OP
Samy
Oddometer: 49
heated Grips Switch Mounting to GS
Hi All,
Bought a switch for my bike (R80 GS Basic 1996) to connect heated grips.
Switch and heated grips are BMW made.
The problem is there is no place to mount the switch on the dashboard.
I have to mount the switch on the handlebar.
When we look at the handlebar, it is barely seen that I need a bracket or similar thing to mount/connect this switch.
Could Anybody help me with this bracket thing ?
Thank you
Samy is offline   Reply With Quote
Old 02-19-2013, 11:55 PM   #2
Prutser
Prutser's Avatar
Oddometer: 994
You might need something like this :
http://www.realoem.com/bmw/showparts...03&hg=32&fg=71
But i'm not sure it fits on the GS. Its made for the F650
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 02-20-2013, 12:44 AM   #3
Errhead
Low Miles!
Oddometer: 71
switch
That's the switch that drops into the dash of the 1990-on GSPD version. There is another BMW switch for the non-PD that is integrated into a handlebar mount. That nacelle is very cramped as you have noticed. I managed to fit a toggle switch into mine in about the only spot it would fit. Problem is that the location sucks and it is very hard to use with gloves.
Chrome won't get you home.
Errhead is online now   Reply With Quote
Old 02-20-2013, 03:27 AM   #4
chasbmw
Oddometer: 2,204
If you lost one of the warning lights could that be the right size for the switch?
Otherwise symtec make a very neat round 3 way rocker switch. On my 90/6 it has been squeezed in between the main binnacle and the LH instrument pod (the same that you have). It's fairly neat but a bit ark ward to use with heavy gloves.
The Symtec heated grip pads seem to work very well and put out a good amount of heat. Easy enough to fit and reliable to date.
That's a very neat tacho, is that a BMW part?
Charles
1971 Commando Fastback
Old 02-20-2013, 04:17 AM   #5
Samy OP
Samy
Oddometer: 49
yes it is an original BMW part
Old 02-20-2013, 08:13 AM   #6
Mugwest
Mugwest's Avatar
Oddometer: 6,223
Samy, in that picture the BMW heated grip switch is already mounted on the bars:
this is the factory heated grip switch for all round-headlight G/S and GS (85?-up)
It is Item # 2 in the fiche for the retrofit kit:
part # 61 31 1 244 494
The flat rocker connector you have is for the roo-bar fairing GS's, both GS-PD models and the 100GS with the same fairing dashboard. I think that switch also fits 11xxGS (looks identical)
I like the solution that Prutser shows with that F650 mini-panel between the bar risers
The Symtec kits are very good quality, but if you ride in rain/mud/sand/dust very much the switches crap out quickly as they are not sealed
Mugwest is offline   Reply With Quote
Old 02-20-2013, 09:55 AM   #7
BeardThrone
...in bat country.
Oddometer: 120
What he said.
BeardThrone is offline   Reply With Quote
Old 02-20-2013, 01:23 PM   #8
BeardThrone
...in bat country.
Oddometer: 120
Samy,
Here are all the parts you need. I assume that you have the grips and what looks to be the correct switch but what you might be missing is the harness for the grips(part #3 in the diagram above). I took a picture of all the parts you need and the numbers correspond to the part numbers in the diagram:
Part 3(the grip harness) is from a R100GS here is a picture of the part tag:
I hope this helps.
BT
Old 11-15-2014, 09:32 AM   #9
Global Rider
Alps Adventurer
Global Rider's Avatar
Location: Canada & the Alps - N 46 31.714' E 010 27.212'
Oddometer: 3,803
It is the switch pad I'd like to use but I need to get dimensions L1 and L2 before ordering one to see if it matches up with the handlebar mounting locations used on my R100 GS.
Incredibly with all the various BMWs in my local club, they were unable to help.
All the best,
Alex
Euro & North American Travel & Technical Stuff for the R1150 GS & Adventure
Euro & Alps Motorcycle Tours - Priced Right, How to go about
Great spirits have always encountered violent opposition from mediocre minds.....A. Einstein
Global Rider is offline   Reply With Quote
Old 11-15-2014, 01:40 PM   #10
Prutser
Prutser's Avatar
Oddometer: 994
I mounted one on a R100GS. It doesn't fit perfect but it works.
If you file the holes a little bit you can get it mounted. Only when someone takes a real good look they will see the bolts are not centered.
Ride Report 2012
Prutser screwed with this post 11-16-2014 at 09:32 AM
Old 11-15-2014, 03:22 PM   #11
Global Rider
Alps Adventurer
Oddometer: 3,803
I stopped by my dealer for an oil filter and while there, I came across a used F650 with a switch pad installed, so I took some measurements. Measurements were taken from the center of one fastener to the center of the other.
F650: L1 = 84.5 mm 0.5mm, L2 = 35.0 mm 0.5 mm
R100 GS: L1 = 81.0 mm 0.5mm, L2 = 33.0 mm 0.5 mm
All the best,
Alex
Old 11-15-2014, 03:33 PM   #12
ianboydsnr
Oddometer: 104
Just put a waterproof mini toggle switch, with on off on connection on the back,
Wiring is easy, power to the centre, then full power to the grips then to earth, Just fit and connect a 6 ohm resistor for the half heat, then connect to the grips
ianboydsnr is offline   Reply With Quote
Old 11-15-2014, 03:39 PM   #13
Global Rider
Alps Adventurer
Oddometer: 3,803
I might just use a PWM module.
All the best,
Alex
Times are GMT -7.   It's 08:11 PM.
