Old 05-08-2012, 03:39 AM   #76
Thumper Dan
Oddometer: 325
Originally Posted by bouldertag View Post
Ok I have really no problems except ones I created myself __user Error_.
Only complaint with this great bike is my balls are glowing blue cold after a ride in temps under 45 degrees F.
I mean really,.. I could chill a pineapple with my balls after a ride. All other body parts are just fine...
Bike just keeps going. Did the NSU screws and the chain roller only. The head gasket shows black stuff from by the sparkplugs but besides that my bike is the shit.
Ball freezing boulder..
One cold pineapple, but how many people would be actually eating it?
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 05-12-2012, 10:51 PM   #77
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,228
Pick-up Coil went bad and replaced it
See post #64401 on page 4294.
http://advrider.com/forums/showthrea...5295&page=4294
I wrote up a step by step with a few photos of how I did it. I learned from reading other's posts of how they replaced the pick-up coil.
Dave
smilin jack is offline   Reply With Quote
Old 09-27-2012, 08:15 PM   #78
BergDonk
BergDonk's Avatar
Oddometer: 3,719
Countershaft Seal
Its not unknown for these to pop out. It happened to me, and I posted about it on #197 here where I developed a fix:
http://www.advrider.com/forums/showt...646076&page=14
I subsequently came up with a MkII version that amost anyone can make themselves if they'd like the insurance. Scroll down to #252 here and 'roll' your own:
http://www.advrider.com/forums/showt...646076&page=17
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 09-28-2012, 12:14 PM   #79
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,001
Just curious Steve, why not make one out of steel, similar to this one?
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 09-29-2012, 01:54 AM   #80
BergDonk
BergDonk's Avatar
Oddometer: 3,719
It just seemed easier on the day with what I had to hand. Ultimately, numerous ways to do this, and its the end result thats important. For me right now, my seal won't fall out again.
Old 10-01-2012, 09:02 AM   #81
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,001
Originally Posted by BergDonk
It just seemed easier on the day with what I had to hand. Ultimately, numerous ways to do this, and its the end result that's important.
Sounds like I have another thing to add to my winter Project list.
Old 10-28-2012, 12:33 PM   #82
smilin jack
Grandpa Adventurer
Oddometer: 1,228
DR backfired and died
Here's the link to more info.
Post #70712 http://advrider.com/forums/showpost....ostcount=70712
Still trying to figure what caused the problem. Will report back later.
Dave
Old 10-28-2012, 01:41 PM   #83
rhino_adv
rhino_adv's Avatar
Oddometer: 629
Originally Posted by 71tr View Post
I have a 2003 with about 5k miles complete with leaky base gasket. Recall Suzuki switched from a paper to a metal gasket in approximately '03. The leak acts like a pinhole spitting tiny droplets of oil as the motor revs. A nice bead of high temp silicone has effectively taken care of the problem. I'm planning to take this bike through South America next year and have no plans to replace the leaking gasket.
I had the same problem with a 2003 DR650 I purchased with 4400 miles. At around 5200 miles the cylinder base gasket started leaking. I power washed the engine and then cleaned the site with contact cleaner and dried it with a heat lamp. I applied a layer of hi temp silicon and allowed it to cure for a week. A year later the bike has 13300 miles and not leaking any oil from the base gasket.
I recomend this quick fix to anyone with a similar problem!
Brad
Old Bridges Thread
Riding the TWAT
475+ Bridges in Illinois,
985+ Old Bridges in Missouri
PAVED ROADS...... ANOTHER PERFECT EXAMPLE OF NEEDLESS, SPENDING BY THE GOVERNMENT"
rhino_adv is offline   Reply With Quote
Old 10-28-2012, 10:01 PM   #84
Chillis
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,037
My 1997 had a few issues but it was rode hard but maintained well.
Over 80,000 miles before parting her out.
Blew out rear shock
Starter motor went due to cleaning the bike and not leaning it over to let the puddled water drain from the rubber o-rings of starter motor. It was corroded inside.
One can chain tensioner after replacing a gasket and stripping out the threads for the bolt in the end.
Rear brake caliper bracket broke while I was doing a set of rear brakes.
A few Teflon chain guides.
One speedometer.
I had a chain come off a knock a hole in my case.
Base gasket leaked eventually.
I think that was about it. Considering I rode a lot of high speed wheelies, topped it out often, rode desert, street, toured across the country a few timed, it acquitted itself very well.
Should I get another I could make it last indefinitely. I don't care to go as fast and the wheelie hormone seems to be in check.
Excellent machine.
Chillis is offline   Reply With Quote
Old 02-20-2013, 07:35 AM   #85
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,109
Originally Posted by Rob.G View Post
A lot of people strip those screws... they're actually not philips. They're a Japanese "standard" (I forget the exact term)... but if you look closely, they aren't tapered like a true philips.. the slots go all the way down completely. There's a special tool you can get to remove them, but it sounds like you already solved the problem. :)
Rob
JIS screwdrivers - http://www.webbikeworld.com/motorcyc...-screwdrivers/
http://www.amazon.com/Hozan-JIS-4-JI.../dp/B005NIY3PM
the special tool for most is using a hand-hammer impact tool.
http://www.harborfreight.com/impact-...ase-37530.html
http://www.sears.com/craftsman-impac...p-00947641000P
http://www.harborfreight.com/7-piece...set-93481.html - light duty one for smaller fasteners.
i've used a dremel tool in the past with a thin cutoff wheel and made a slot for a flathead screwdriver to work.
later found out the trick, if you only have Philips screwdrivers, is to use the next size smaller one (so it gets the tip down in deeper in the JIS screw) and tap it from the top with a hammer. this helps drive the tool head deeper into the screw and also shocks the screw some to loosen it. if the screw is somewhat buggered up, from previous attempts, tapping the screwdriver in harder can work. often the steel screw, alum. cap & brake res. main body somewhat fuse together if the fluid has never been serviced.
here is a way to modify Philips bits/screwdrivers to fit better in JIS:
http://www.kzrider.com/forum/21-tool...rewdriver-tips
when dealing with the JIS screws on the floatbowl, the same technique can be used but often those hand-hammered tools is key. that is 1 essential tool that every home mechanic should have! once you have those screws out replace with allen bolts from PC, Jesse or the hardware store.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 02-20-2013 at 10:09 AM
eakins is online now   Reply With Quote
Old 03-01-2013, 10:10 AM   #86
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,109
Start squeal noise and fixes
http://www.fy-yff.com/2011/08/squeak...-easy-fix.html
http://webpages.charter.net/jrandall...tarter_fix.htm
http://www.advrider.com/forums/showthread.php?t=832297
Alaska
Old 04-23-2013, 02:44 PM   #87
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 914
NS switch
Is there any down side to completely removing the nuteral switch? I have ridden dirt bikes my whole life and dont need a switch to tell me its in gear or not.
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is online now   Reply With Quote
Old 06-01-2013, 05:06 PM   #88
Toscana1
Younger by the ride.
Toscana1's Avatar
Oddometer: 30
Torque limiter replacement.
Any guidance to a good tutorial on replacing the problematic '98-'99 torque limiter. One that shows from start to finish hopefully? I've read tons of posts, stories, etc. on ADV, ThumperTalk and DRRiders but haven't been able to find a step-by-step on how to do the upgrade. Any links would be appreciated, thanks.
"Never be afraid to try something new. Remember it was a lone amateur that built the Ark and a large team of professionals that built the Titanic." Dave Barry. '98 DR650SE, '71 Vespa 150 Sprint, '00 TTR225, '05 CRF250X
Toscana1 is offline   Reply With Quote
Old 06-01-2013, 07:20 PM   #89
ER70S-2
ER70S-2's Avatar
Oddometer: 6,776
Meaning no disrespect. Your signature:
I've never done the project, you've done your homework, jump in, take photos. Remove cover: I'd do this with the bike on the sidestand, there are one or two washers inside the cover and you want them falling to the left if they don't stick to the cover (oil friction). Once you find 3 & 5, you can straighten the bike to vertical, making access easier. Scrape gasket, be patient, gaskets can be a PITA to remove, you don't want to nick the gasket surface with a scraper. Remove old, install new torque limiter. Grease gasket, install cover. Use a light coat of grease when re-installing the gasket, not RTV or similar.
I'm assuming this isn't your primary transportation, that you already have the basic tools needed and this isn't the first time you've used tools. Regardless, don't be in a hurry when you start and have a new gasket on hand, just in case the old one breaks.
Make sure to account for parts 3 and 5. There's a pair of each, one inside, another outside. It seems most likely that #5 will stay in their bosses due to oil suction.
You've probably already seen this pic. There isn't much involved.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 06-01-2013, 09:10 PM   #90
Toscana1
Toscana1's Avatar
Oddometer: 30
Thanks much. The photo helps, I had not seen it before. I have the tools, fairly competent with them, and have a loaner lift. I figured I'd do the NSU fix (mine were barely finger tight) while it was drained and on the lift.
My biggest question was exactly where the torque limiter was. The photo helped identify the culprit, thanks. Now to check it and get the proper one ordered.
Times are GMT -7.   It's 05:14 PM.
