Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 02-20-2013, 06:19 AM   #661
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Originally Posted by Poweranger View Post
I thought I might get chastised about the pliers comment a little. I just happened to have them in my hand and thought I would try. Not realizing the entire bar end is all one piece. Anyway I'm glad I didn't break it free it. I am guessing the grip would have to come off first anyway?
remove the grip to do what?
fbj913 is offline   Reply With Quote
Old 02-20-2013, 08:32 AM   #662
Poweranger
Oddometer: 761
To remove the bar end that has the threaded insert.
Poweranger is online now   Reply With Quote
Old 02-20-2013, 08:50 AM   #663
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,778
Yes. The flats for a spanner are right next to the end of the bar.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 02-20-2013, 09:05 AM   #664
BryanCO
CO Rider
Oddometer: 500
Originally Posted by JD View Post
You mean these?
Yes. They dont seem to be a common choice. ?? Thoughts? Protection, appearance, etc. Trying the decide between the AltRider and SW-Motech. Already have the AltRider rack and bash plate.
BryanCO is offline   Reply With Quote
Old 02-20-2013, 10:00 AM   #665
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
No you don't need to. Take the bar ends/outer pieces of the hand guards off and get a standard crescent wrench. The threaded inserts have two flat sides on the very outside edge so you can screw them out.
Old 02-20-2013, 07:56 PM   #666
JD
JD's Avatar
Oddometer: 393
G'day
Before buying the bike I looked at all the different crash bars available and for me it was a toss up between the SW Motech and Altriders.
When I picked up the bike from a dealer 3hrs from home there just happened to be a guy a few suburbs away from the dealer who had all the Altrider gear in stock, so that's what I went with.
The Altrider bars, although pricey, seemed really solid in their construction and the way they mounted, and turned out to be easy to fit.
They seem to offer similar protection to the SW Motech bars if your tiger decides to have a lie down for a while.
Having said that, there is no reason I wouldn't have bought the SW Motech's apart from the inconvenience of having to order them from a supplier on the other side of the country. There are a couple of guys over here currently riding their tigers around OZ that swear by them.
Cheers,
John
JD is offline   Reply With Quote
Old 02-21-2013, 06:49 AM   #667
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
G'day
Cheers,
John
You better buy a new shift lever ahead of time with this set up... I destroyed mine when I went down in some grass. I carry two!
Old 02-21-2013, 07:12 AM   #668
bluesman
Oddometer: 3,344
I disagree! This is perfectly serviceable gear lever! Just need some work with back side of axe on roadside stone!
Good it is not aluminium!
bluesman is offline   Reply With Quote
Old 02-21-2013, 07:46 AM   #669
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
oh i bent it back, i had to get home somehow. rode it "fixed" for a few weeks. much more bending though and I'm afraid she would snap. its not so much the steel but the lever from the motor... that area isn't as thick as the rest... the one in the pic is now my back up.
Old 02-21-2013, 08:13 AM   #670
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,778
[/url]
You didn't take the necessary precautions. A simple "Brake Snake" may have prevented your lever from bending double.
And/or buy a Touratech folding lever which is thicker to start with.
Old 02-21-2013, 11:43 AM   #671
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
you mean like this?
Old 02-21-2013, 12:58 PM   #672
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,778
you mean like this?
Bingo!!
But....the reason I do mine like I do is that it helps prevent branches going in and getting wedged behind the lever. I learnt that the hard way. It sent me over the bars.
Old 02-21-2013, 01:48 PM   #673
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,232
Well now know I will need to brake snake the T800 when I get it. Should probably hook up the Girlie now. I went through three gear shift levers on my XR before I wised up and safety wired the shifter and brake pedal.
"I refuse to tiptoe through life only to arrive safely at death" '13 Tiger 800XC, '14 Street Triple, '00 KLR 650(finished project), and 2010 Honda NT700V wife's.
Drunk_Uncle is offline   Reply With Quote
Old 02-21-2013, 01:50 PM   #674
mint julep
mint julep's Avatar
Oddometer: 185
hey guys, here's a noob question.
I like/want to change for the folding Touratech shift lever.
Is it as easy as bolt off/on?
Thanks,
Dave.
mint julep is offline   Reply With Quote
Old 02-21-2013, 02:10 PM   #675
BryanCO
CO Rider
Oddometer: 500
You better buy a new shift lever ahead of time with this set up... I destroyed mine when I went down in some grass. I carry two.]
Do you have the AltRider bars? I see the lever in the pic...
Times are GMT -7.   It's 01:42 AM.
