Old 02-17-2013, 08:40 AM   #61
doug s.
Oddometer: 1,348
Originally Posted by doug s. View Post
nice! congrats!
but, i don't understand why the rpms would not be exactly the same if you didn't change gearing. if you were at 4700rpms at 74mph before, changing the engine displacement alone shouldn't affect that... you should still be at 4700rpms at 74mph...
doug s.
Originally Posted by planemanx15 View Post
Even though the gearing is the same, the bigger engine works less to obtain that speed. At least that's my theory
regardless of how much the engine is working, (i suspect it is actually working more - making more hp at any given engine speed), it's still turning the same rpm's to get the wheels turning their rpm's... math is math...
now, because the engine is making more power at any given rpm, you could put a 41t sprocket on the rear (or a larger diameter tire) and lower your engine rpm's at any given mph, and the bike will still pull hard... you are already running 17-42; did i read that correctly?
doug s.
doug s. is offline   Reply With Quote
Old 02-17-2013, 04:19 PM   #62
planemanx15 OP
planemanx15's Avatar
Oddometer: 1,009
doug s.
Yes I have a 17-42 set up. I went to that because when I went to a lower profile tire, my rpms jumped up.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 02-17-2013, 04:21 PM   #63
planemanx15 OP
Oddometer: 1,009
Originally Posted by vicster View Post
Did you notice any increase in engine vibration with the 790 kit installed?
No increase noted at all..yet. it's only got 10 miles on it. Hopefully this week ill be able to ride more. I did notice it was quieter, but than I realized my skid plate is off. I never realized how much noise that reflects. Ill be doing some sort of sound damping next.
Old 02-18-2013, 07:12 AM   #64
barko1
barko1
barko1's Avatar
Oddometer: 3,405
I would guess that stock header pipe is really choking thing up with the bigger displacement. It seems small for the 650 so it must be quite restrictive on the big bore. Thanks for the write up
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 02-18-2013, 11:15 AM   #65
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 163
Mr. Planemanx,
Did you happen to measure the piston ring end gap before doing the final install? If so, was is spot on or did you have to open it up a little?
Thanks,
Trent
VooDooDaddy is offline   Reply With Quote
Old 02-18-2013, 01:29 PM   #66
planemanx15 OP
Oddometer: 1,009
Originally Posted by VooDooDaddy View Post
Mr. Planemanx,
Thanks,
Trent
Trent, Mr. Planemanx is my father, you can call me Joe. lol.
I did not measure the piston ring end gap. Procycle does supply the measurements with the kit.
Old 02-18-2013, 05:04 PM   #67
VooDooDaddy
Oddometer: 163
...call me Joe. lol.
Joe it is....
Old 02-19-2013, 11:08 AM   #68
Jimmy the Heater
Tilting the Horizon
Jimmy the Heater's Avatar
Oddometer: 2,111
Had no idea that this kit even existed. Watching with interest
Jimmy the Heater is offline   Reply With Quote
Old 02-19-2013, 11:16 AM   #69
planemanx15 OP
Oddometer: 1,009
Ran the bike for another 30 minutes today, got the oil hot, various RPM's. Its all good! Looks like its going to be above freezing and dry at the end of the week, so expect a report very soon.
Old 02-19-2013, 01:58 PM   #70
neo1piv014
ADV in training
Oddometer: 621
Can't wait to see how she runs. Seeing the whole process from step 1 like this actually makes everything look fairly accessible. When you talk about doing it all in one solid day's work, that's something that a lot of us could see ourselves doing.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 02-22-2013, 09:29 AM   #71
planemanx15 OP
Oddometer: 1,009
Got to go out today. Did about 60 miles and it felt great. Engine pulls from way down low, it has loads of power, and maybe a slight increase in vibrations.
Then came a problem....
On the highway coming back home, i was holding a steady 80 mph for about a minute. Just then, I heard a loud metal sound coming from below me, and the engine felt like it lost a bunch of power. I pulled over and it died. Before getting off the bike, I tried to restart it, and it started, but wouldn't idle. I got off the bike, and listened. It sounds like its coming from the right side, maybe the valves. Since the bike was running, i decided to just go home. It was about 15 miles at 45-60 mph. The metal noise continued to chime but much lower. If I revved the engine, it got louder. I got home and the bike was able to idle. The noise was still there.
I hope that its just a valve came loose and the nut is siting on top of the engine. I haven't opened it, as its way too hot to get in there. Any suggestions if its not the valve? It could be anything, I think the noise is on the right side, but it might not be. Also the engine oil temps during the whole ride ranged from 150*-190*F. I have a plate over my oil cooler, since its in the 30's today. The temps did not increase after this incident.
Old 02-22-2013, 09:40 AM   #72
VooDooDaddy
Oddometer: 163
To help pin-point the exact location of this "sound", get a long-handled screwdriver, place the handle against your ear hole and the business end resting firmly on several different places on the engine while its running.
This may help you pin-point the location of the sound. The vibrations/noise will travel through the screwdriver directly into your ear, thus mechanically amplifying the sound through the screwdriver.
Based on your descriptions, it 'sounds' like its either coming from the cylinder head or the clutch area?
Old 02-22-2013, 09:49 AM   #73
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,213
I'd also consider calling ProCycle and talk to Jeff about it... see what he thinks. He may have encountered this problem before.
Edit: I wonder if it's related to the cam chain tensioner? They sell a manual one that may work better than the stock automatic tensioner.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G screwed with this post 02-22-2013 at 10:12 AM
Rob.G is offline   Reply With Quote
Old 02-22-2013, 10:19 AM   #74
planemanx15 OP
Oddometer: 1,009
Adjusting valves did not work, here is a video of the sound::
Old 02-22-2013, 10:24 AM   #75
planemanx15 OP
Oddometer: 1,009
Rob
Thanks for the suggestion, Maybe the cam chain skipped a tooth? would the bike still run?
Times are GMT -7.   It's 08:11 PM.
