02-22-2013, 04:20 AM
#31 |
Oddometer: 828
Put a grease nipple on the suspension linkage bearings that are in the frame.
Have a good trip!!
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat |
02-22-2013, 04:35 AM
#32 |
Oddometer: 3,812
I'm in too.
:Sent from my DROID RAZR using Tapatalk 2
"Deeply flawed people make deeply flawed decisions." Kawidad screwed with this post 02-23-2013 at 08:32 AM |
02-22-2013, 07:31 AM
#33 | |
out riding...
Oddometer: 1,277
02-22-2013, 07:38 AM
#34 | |
out riding...
Oddometer: 1,277
) is a must, original spec shows the bike is set up for rider of around 160 lbs, well he won't be riding it i will and i top the scales at about 240 with geari was toild about this company for suspension needs http://www.stillwellperformance.com/main/ I met CJ at Dust to Dawson a few years back when i was riding back from Prudhoe Bay, he said if i ever need anything made for any bike let him know.... |
02-22-2013, 07:39 AM
#35 |
out riding...
Oddometer: 1,277
do you have a photo of where you put yours? good to have you along
02-22-2013, 07:40 AM
#36 |
out riding...
Oddometer: 1,277
02-22-2013, 08:52 AM
#37 | |
Oddometer: 1,433
Re-spring/ re-sprung
Slavens racing is another option for springs http://www.slavensracing.com/shop/fo...tm-husaberg-wpQuote:
2008 KTM 990 Adv & 2007 KTM 640 Adv |
02-22-2013, 09:27 AM
#38 | |
out riding...
Oddometer: 1,277
02-22-2013, 09:43 AM
#39 |
Still gettin faster
Oddometer: 943
[QUOTE=huzar;20782159]Really enjoyed your ride report, so I think I'll lurk here and watch the prep
[/QUOTE+1, As usual, I'm lurking on all things Lc4. Nice snag on the SXC. It is one beautiful bike! |
02-22-2013, 09:49 AM
#40 | |
on the road o'dreams
Oddometer: 5,381
Good group of KTM experts here. Have fun with the build! Does your BST Mikuni have an extended Fuel/Air screw? Very handy, easy adjust at altitude for better starting, idle and low speed running. Helps with MPG too. (The DR650 has the same carb ... so I've messed around with them a bit) You can try different needle tapers too. Put some sort of decent (but NOT restrictive) fuel filter as BST pilots clog easily. (carry a spare pilot jet) If tuned properly you should get decent performance ... and good MPG. (open air box top helps on the DR) Adv Grifter screwed with this post 02-22-2013 at 10:10 AM |
02-22-2013, 01:07 PM
#41 | |
BITD/Rallye
Oddometer: 5,307
He may actually have a frame with oil... In the US they only imported 03-04 SXC's which I have and they lack the quart in the frame reservoir some European and Australian bikes do. He mentioned the word Carnet so Im assuming he is not from North America I have used both the 18 ltr and 28 ltr (actually I use the 2001 adv tank which has a 30 ltr) and for what you plan I would go with (if you can find it) the 28 liter hardpart acerbis tank. Skip the faring but if you have to then you will have to get the carrier parts and weld a bracket on the head tube then use a oem 28 tank and adventure faring. as far as wheels Just buy the 02 LC4 OEM cush wheel complete (and carrier)with the wider DID Dirtstar 2.50 rim . Keep your front .. respring both front and rear.
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle |
02-22-2013, 01:55 PM
#42 | |
out riding...
Oddometer: 1,277
once i pull the carb off i can note what i have and get spares from there onwards |
02-22-2013, 02:01 PM
#43 | |
out riding...
Oddometer: 1,277
yep i'm here in the US not far from you actually, i'm in Vegas, so the bike is a US model and no oil in frame
i do know a guy locally who has a 640A so i will look at his and see the oil line routing and create an auxiliary tank to up the capacitythe 28 liter was the option i was going to go with, but may have to relocate and reweld the mounts or use spaces as it is made for the FCR carb not the BST...once i get it i will know for sure, i'll also be adding a 1 gallon (3.78liter) rotopax to the rear opposite the exhaust can and use the mounting structure to additionally add strength and structure to the sub frame do you know if the cush drive hub is still available from any vendors? as for changing rims and relacing i can do that myself Quote:
02-22-2013, 02:15 PM
#44 |
Oddometer: 828
Add the grease nipple on the left to grease the bearings in the frame as these bearings take a beating and will wear out quickly. They can also be hard to get out......................
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat Droptarotter screwed with this post 02-22-2013 at 03:13 PM |
02-22-2013, 03:45 PM
#45 |
Oddometer: 298
i put a big bike cush rear, 4.25" on my 450 SMR, and i also got a cush hub used from Woody's that i strung up w/a 2.50" rim for a dirt conversion... you gotta look around for a used one, they don't come up much.... the used one i got from Woody's was a RAD one, i think.... nice piece, it's a billet copy of the cast KTM hub.... both are nice, and they really transform the bike if you don't have one, real snatchy w/out it..... i'm suprised that that bike doesn't have a cush hub now, i thought they were stock on the big bikes?....
