02-22-2013, 05:22 PM
#46 | |
I.Hopp.
Oddometer: 3,076
Your tank mounts should be generic to all the LC 4 models, even the Adventure tank will mount up to your SXC, the only real difference is the Adventure has an extra brace that fits into an additional bushing slot that the A tank comes equipped with.... This brace also help protect the rads from getting crushed from a side hit... What tank are you looking to get?
640 A x 2 gunnerbuck screwed with this post 02-22-2013 at 08:48 PM |
02-22-2013, 06:18 PM
#47 |
out riding...
Oddometer: 1,215
got it, thats one for the list i hadn't read about
02-22-2013, 06:23 PM
#48 | |
out riding...
Oddometer: 1,215
![]() i'm not to bothered if i have to relocate any mounts on the frame, i had a motorcycle shop and built motorcycles for 17 years so none of that stuff intimidates me, if anything its fun and i am a welder as well... i think the issue according to just gas tanks is the height of the carb, and if i can utilize any mounts on the frame that are not used they will be when i'm finished if they are useful, otherwise they will be gone |
02-22-2013, 07:21 PM
#49 | |
I.Hopp.
Oddometer: 3,076
That Safari tank looks to be the only big fuel option left on the market for the LC4... I guess the KTM 28 liter Rally tank isn't listed or available anymore ... I do know of an Adventure tank that was up for grabs but it may be sold now, I can inquire ... I also have a spare 640 A tank but they are not easy to find so it is a keeper... You could always heat mold a depression in the Safari tank to fit the BST's Vacuum cap, it probably wouldn't take much...
640 A x 2 |
02-22-2013, 07:44 PM
#50 | |
out riding...
Oddometer: 1,215
02-22-2013, 07:55 PM
#51 |
I.Hopp.
Oddometer: 3,076
I'll check on the status...
640 A x 2 |
02-23-2013, 02:47 AM
#52 |
Vtwin madness
Oddometer: 282
I have a couple of Talon cush drive rear wheels but probably wouldnt use one on a ride like yours as the rubber inserts are a smallish O ring (maybe RAD use something better) The factory Rally bikes of Despres/Coma/Sala etc used a Talon front hub but a KTM OEM rear hub which uses the same rubbers as on a 640A or 950A. That to me says the OEM is much better for lots of abuse or lots of miles.
02-23-2013, 03:11 AM
#53 |
Oddometer: 833
Hey Gunner, if you are thinking of the Adventure tank from Ted in the Okanagan, I bought that the other day!
Sorry Paul, it's not available! Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat |
02-23-2013, 04:52 AM
#54 |
MMMMM Bundy!
Oddometer: 658
the Safari tank works with the original seat and doesnt need a fuel pump, so is a good option. The KTM Adventure tank needs a fuel pump, but the Genuine KTM 18 lt tank needs the 'comfort' seat (std adventure seat) and mine holds 20.5 litres. I dont think they are available new anymore, but you can still buy the Safari tanks.
http://www.safaritanks.com.au/home/9...ypage.tpl.html http://justgastanks.com/index.php?cPath=4_78_111 as mentioned the Australian 625's came with the oil in the frame holding 1.9 lt total. the 2007 model came std with cush drive rear hub. cheers David |
02-23-2013, 05:40 AM
#55 |
Oddometer: 299
best place to get KTM parts...
http://www.ktmpartshouse.com/ cheapest i've found on the net, and there supposed to get shipments from KTM every 2 days.... i think it may even be dealers price, i dunno, but it's pretty cheap, and the parts fiche's answer pretty much all questions.... |
02-23-2013, 07:04 AM
#56 |
I.Hopp.
Oddometer: 3,076
Is that a spare for you? I have another potential 640 A tank that I am waiting for a reply on, but it may also be sold...
640 A x 2 |
02-23-2013, 09:25 AM
#57 | |
out riding...
Oddometer: 1,215
![]() ![]() now IMHO as a motorcycle builder and also a machinist i look at it like this, i will take a cush drive over none if one is required, and take billet over cast (stock hub) tensile strength is way better, Dakar bikes have the option of a wheel change if there is an issue, no support crew with me now on the rubbers, with this type above they will loose some action by getting worn over time but a very simple and cheap on the side of the road fix is inner tube rubber, cutting small strips and inserting them between the rubbers, doing this on my XT i got 50,000 miles out of a set, expected life is 5-15,000 miles so if someone from RAD is reading let me know if you are ready for some RTW testing? |
02-23-2013, 09:28 AM
#58 | |
out riding...
Oddometer: 1,215
definitely no oil in frame but i am going to look at a 640A for oil routing this week to determine a reservoir location but if you have photos of your version that would be a great help as its a direct model for model comparison, put them up on here if you have them
02-23-2013, 09:40 AM
#59 | |
Oddometer: 833
Good idea on the bicycle inner tube fix! Cheers
#60 | |
Oddometer: 833
Cheers
