Old 02-22-2013, 08:44 PM   #1
grumpybear OP
grumpybear's Avatar
Oddometer: 312
1996 Scorpa Easy Clutch lubication
Bought a 96 Scorpa 250 Easy for fun but I'm doing some work on it before I get to the fun part.
In the process of replacing the 2 o rings on the clutch slave cylinder, I drained out about 2 oz's what appears to be ATF from the clutch compartment.
Any ideas what should the lube oil be for the clutch basket and the volume?
** edit: figured it out. Used ATF for clutch bath lube and ATF in the clutch master cylinder. If the Orings leak, no big deal. Filled the clutch side up through the bolt hole on the side of the clutch cover till it ran out. Played with it for a25 minute ride up and down the driveway, everything seems to be working good**
Thanks,
grump
grumpybear screwed with this post 02-23-2013 at 04:18 PM
grumpybear is offline   Reply With Quote
Times are GMT -7.   It's 12:54 AM.
