Old 02-23-2013, 01:01 AM   #11
DerrickWade
Oddometer: 10
Originally Posted by mcma111 View Post
Very nice. You should get that kink out of the dryer hose though.
I have since replaced the flexi hose, with 4" conduit.
[QUOTE=Tech23;20790137]
Originally Posted by DerrickWade View Post
Before:
After:
Looks real nice. Race Deck makes good stuff. My garage floor is epoxy coated so I just got a 6' x 10' Race Deck" pad to put under my lift table. The movement of the lift was starting to wear on the epoxy finish.
What are the details on the garage door insulation? Who makes it, where did you get it, how thick is it and is it secure...does it stay put?
Tech23
Thanks, Details on the insulation are:
I cut the pieces to fit inside each panel of the garage door. I then went around the edge of each panel with aluminum tape.
Name: Reflectix Insulation
Bought it at Menards
Thickness: Not sure, 1/4 inch maybe. Its just shiney bubble wrap.
Stays put? Yes, I have it taped to the framework with aluminum tape.
Check out post #12 of my single car garage revamp on garage journal.
http://garagejournal.com/forum/showthread.php?t=155324
DerrickWade is offline   Reply With Quote
Times are GMT -7.   It's 05:14 AM.
