02-19-2013, 02:13 PM
#1 |
Oddometer: 211
05 950, when to change fuel pump?
My bike has about 20,000 miles on it and I am planning on doing the TAT this summer.
Should I change out the fuel pump now? I have had no problems with it and I already own a fuel pump for the just in case. |
02-19-2013, 02:34 PM
#2 |
Agnostic Adventurer
Oddometer: 2,108
Order a Dr. Bean kit and keep the stock pump
http://www.advrider.com/forums/showthread.php?t=807414 FYI... I had over 40k miles on the stock pump before the original points died. Now over 30k more miles on the same pump with Dr. Bean mod. Have fun on the TAT! -M
'05 950ADV '04 525EXC D/S '07 Tiger1050 Will herd cats for beer (... but I rescue puppies for free SmugMug (coupon: bLfv2vBXZicd6) |
02-19-2013, 02:37 PM
#3 |
Ride more, BS less!
Oddometer: 8,399
Replace the points with stock points or Dr Bean solid state kit.
No need to replace the whole pump.
08 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150 Hi/low beam conversions for: Trail Tech, Baja Designs |
02-19-2013, 09:35 PM
#4 |
Sand seeker
Oddometer: 1,104
Original points on pump went at 21K. Have about 4K on the Dr. Bean kit.
Everybody's on the run |
02-19-2013, 11:13 PM
#5 |
Life is a trip
Oddometer: 3,125
Maybe some grease at the shaft could lengthen the pump's life.
Since some inmates have reported seized rod, some grease could help with that.
Cheers.
There is always a reason!! |
02-20-2013, 01:18 AM
#6 |
Semi-Adventurer
Oddometer: 9,841
My original points lasted about 25000 miles. The replacement points now have over 20000 miles, and are showing wear. I will be replacing them soon.
Whatever solution you choose, you should take care of it before leaving. The only symptom I got that the points were failing was that the engine quit running, period, one moment running fine, next moment dead.
I miss round headlights. "When I was a young man, I liked to race my horse...." - G.H.W.S. 1878-1962 |
02-20-2013, 07:23 AM
#7 |
Oddometer: 211
Awesome guys, thanks. I think I will just replace the whole thing before I leave.
02-20-2013, 07:48 AM
#8 |
Life is a trip
Oddometer: 3,125
OEM points are known to fail from 7000miles the shortest longevity. There are no reports of DrBean's system failing yet.
Cheers.
02-20-2013, 07:58 AM
#9 |
Two Wheeled Addict
Oddometer: 5,247
54K miles on my Dr Beans kitted fuel pump (Thanks Zeegman)
Speed bumps never seem to make me go any faster |
02-22-2013, 11:37 AM
#10 |
0.0
gefr; Can you explain the "how to" of where you were adding grease in your comment " Since some inmates have reported seized rod, some grease could help with that."
Ive got 20,000mi on original pump & points. Pulled the pump off & inspected the points and they are pretty worn. Ive already got a spare set of the K&L points to replace on mine. So whats to grease? Thanks
KTM: 06 KTM950S & 10 KTM450EXC (690E sold) BMW: 08 R1200GSA & 74 BMW R90/6 Ducati: 08 S2R1000 MONTESSA: 82 COTA 349 "The White Wonder" |
02-23-2013, 12:35 AM
#11 |
Life is a trip
Oddometer: 3,125
I would suggest greasing the rod
This would also obstruct water getting in there and also prevent the rod corroding in its guide.
Cheers.
