Old 02-22-2013, 11:25 AM   #2776
dstriffler
Oddometer: 373
The dealership can't order the OEM sprocket from Honda either. It seems to be obsolete here in the US as far as I know. I did find that Sunstar makes the countershaft sprocket, but I'm not sure if this will be different from the JT sprocket I currently have on there. I know that Sunstar made Honda's sprockets for years so is it possible it is the same as an OEM?
http://sunstar-mc.com/searchresults....NX650&DD3=1988
dstriffler is offline   Reply With Quote
Old 02-22-2013, 12:14 PM   #2777
MartiniUp
Oddometer: 1,817
Maybe send them an email? I can't think of a good reason they would make the sprocket smaller/thinner than the oem if they made the sprockets for Honda originally. Seems they would use the same specs. Please report what you find.
MartiniUp is offline   Reply With Quote
Old 02-22-2013, 12:33 PM   #2778
Bell driver
Bell driver's Avatar
Oddometer: 325
@aadal
Please post your VIN (no need for the last 4 digits)
Or find the applicable data here
http://honda.de/service/motorraeder/service_leistungsumruestung.php
1988 Honda XLV750R
1989 KLR650A
1991 NX650
2007 XR650L
2008 KLR650E
Bell driver screwed with this post 02-22-2013 at 12:42 PM
Bell driver is offline   Reply With Quote
Old 02-22-2013, 12:45 PM   #2779
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 831
Have you tried ebay? Usually a pretty good selection of mechanical parts to be found there, since the bike was sold mostly overseas.
Starchamp is offline   Reply With Quote
Old 02-22-2013, 03:18 PM   #2780
dstriffler
Oddometer: 373
I looked on ebay a little; the problem is shipping and exchange rates can get pricey, so I was hoping to find something here in the states. I sent an email to Sunstar to see if it is basically OEM. I'm thinking I'll just buy the Sunstar and compare it to the JT one. Its the only sprocket I can find available for the 88!
On another note, I installed the new CDI, ignition coil, and kill switch today. While doing so I found the actual problem was not a malfunctioning CDI, it was a faulty wire from the ignition coil. I assumed that since I saw the ignition coil actually working, that is was working at the plug end as well. So now I have a perfectly good backup CDI and kill switch, just in case.
Old 02-22-2013, 03:39 PM   #2781
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 831
Store them in your Faraday cage so you're good to go after the EMP hits.
Old 02-22-2013, 03:48 PM   #2782
Sierra Thumper
Oddometer: 641
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 02-22-2013, 04:06 PM   #2783
mas335
xendurist
Oddometer: 1,959
Originally Posted by mas335 View Post
No, If yours is original then like all electrical components they don't last forever, in this case we are talking about a 25 year old electrical component.
First I would check all your electrical connections, especially the coil and kill switch before buying a CDI. I never leave home without a spare CDI on board. Did you bump ( shut off) the kill switch while riding??
I assume you have the lights, horn, turn signals, starter working but no spark?
DST, I tried to save you some money, I had a feeling it was the coil.
Transalps
mas335 is offline   Reply With Quote
Old 02-22-2013, 06:11 PM   #2784
dstriffler
Oddometer: 373
I never mind spending money on the NX, I feel like any parts I buy will probably be obsolete soon so I might as well buy what I can while I can! Plus I have a couple big trips planned this year, and hope to achieve a goal I've had for many years about riding to Alaska.
The ignition coil was working properly, but the small end of the wire that connects to the spark plug boot had somehow become sorta frayed.
Old 02-22-2013, 06:56 PM   #2785
Sierra Thumper
Oddometer: 641
Originally Posted by Pablo83 View Post
I've searched extensively for that answer and never been able to find it.
So Pablo, did you end up finishing up your NX turbo? I turbocharged my zx14, but I used a kit designed for the stock motor, didn't start from scratch like you. I also had a Yamaha Seca 650 turbo, that was a carb blow through system like your NX. The guys over on TT are dying to hear some more feedback on your project
Old 02-22-2013, 07:11 PM   #2786
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
Getting the NX to its current state has taken a whole lot of effort. Unfortunately there are a few things I wish I did differently; things that are expensive to change and that will wipe out a lot of work that I've done on the bike. So the bike kind of needed to sit on the back porch for a couple years while I forgot about all the effort I've put into it. I also needed to save up some more money. But fear not, just a couple days ago I ordered a brand new Garrett GT1241 turbo for the bike. Now I need to start redesigning the intake/exhaust. There will be updates soon...
Pablo83 is offline   Reply With Quote
Old 02-23-2013, 01:50 AM   #2787
Bounder
ExternallyDisplaced
Oddometer: 774
The sprocket is the same for the XR600R to 1990 and all the XL600
Sprocket specialists make one 5033 is the part number.
I don't think the 7 spline one wears as badly as the later 14 spline version.
Bounder is offline   Reply With Quote
Old 02-23-2013, 05:05 AM   #2788
aadal
Oddometer: 23
Originally Posted by Bell driver View Post
@aadal
Thanks! nice link I looked it up RD02540 but doesn't seem to fit any of the two A / B models. Though when looking at the 20Kw mine matches the preformance :(
But also mentioned is the "Hauptdüsen" (Main jets) with sparepart number I will check that once i get it out of winter storage.
But having just bought the insulator "Vergaser Ansaugstutzen" i can see this is at least the fit for the 35kw one (16211MN9000) :-)
aadal is offline   Reply With Quote
Old 02-23-2013, 05:44 AM   #2789
Bounder
ExternallyDisplaced
Oddometer: 774
What code is on the carburetor?
You'll see it stamped on the side.
VE40XXXXXXXXXX
Old 02-23-2013, 05:45 AM   #2790
Bell driver
Oddometer: 325
You have to look at the 91 model, that's the ...540...
1988 Honda XLV750R
1989 KLR650A
1991 NX650
2007 XR650L
2008 KLR650E
Times are GMT -7.   It's 09:50 PM.
