Old 09-14-2012, 11:30 AM   #241
propilot10
Oddometer: 121
Originally Posted by ultrachrome View Post
I literally unwound the E string on my Martin (on which I can currently play three or four chords) and it still would not poke through.
I don't know no booster system ramps. Please elaborate.
I haven't noticed any shifting issues. I forgot to check it during the bike's first oil change last year. I just performed its second oil change. The bike has just over 5000 miles.
I tried to use my strings too and it would not fit Im guessing electric guitar strings are finer. I know when you buy the strings it says the diameter of each on the package but I was not really concerned about them fitting into an oil jet for a ktm at the time. Lol. Luckily mine was clear but I need to score the right ones so I have them when I need em.
propilot10 is offline   Reply With Quote
Old 02-07-2013, 06:55 AM   #242
T-Mac
orange
T-Mac's Avatar
Oddometer: 50
Originally Posted by AdvRonski View Post
I tried drilling out the stock #30 jet to about a #45, just to see if there would be any improvement in clutch action.
NOPE!
I didn't really have any complaints since installing an EVO slave cylinder and an updated pushrod, but I was curious. So, I drilled out the jet, and to help move the extra oil out of the clutch, I drilled the inner basket a la Meoni.
There wasn't any difference when cold, but after a few minutes the clutch drag was very noticeably worse. Shifting got pretty notchy, and finding neutral when stopped was impossible.
Easy enough to fix. I got a new #30 jet, installed it, and immediately enjoyed the drag-free clutch action I had before the mod.
One nice little detail about the replacement jet-
If you look close, you will see the center area of the jet is convex, and resembles a volcano's profile, as opposed to my original jet which had a concave center. The old jet allowed even the tiniest amount of debris block the the extremely small opening.
The new-style jet will require a relatively large amount of debris to pile up high enough to restrict flow. Nice!
Which part number is this one? Does it fit the early 990s?
KTM 1190 Adventure
T-Mac is offline   Reply With Quote
Old 02-07-2013, 07:26 AM   #243
beergut
Thumper
beergut's Avatar
Oddometer: 413
I upgraded to the jet that is recommended by CJ, what a royal PITA to remove. I would love to kick in the nuts whoever designed this.
I read recommendations on removing it:
paper clip
superglue/nail
clay
bobby-pin
what worked for me....a q-tip, after messing with it for a few hours. I put the q-tip in, smashed it in there real good and it pulled right out. Not sure if anyone has mentioned it...make sure you clean the area around the cap before you pull the cap off. Knocking grease in the hole is pretty simple to do.
My KLR
beergut is offline   Reply With Quote
Old 02-07-2013, 02:49 PM   #244
DirtyADV
DirtyADV's Avatar
Oddometer: 2,324
paper clip
superglue/nail
clay
bobby-pin
VACUUM CLEANER just tape a thin hose to the end feed hose down the hole and voila!
Addition in red.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 02-14-2013, 01:51 AM   #245
T-Mac
orange
T-Mac's Avatar
Oddometer: 50
How about funnel design instead of volcano?
KTM 1190 Adventure
Old 02-14-2013, 07:47 AM   #246
beergut
Thumper
beergut's Avatar
Oddometer: 413
I believe that is how CJ's is designed.
My KLR
Old 02-14-2013, 01:23 PM   #247
ABuck99
0.0
ABuck99's Avatar
Oddometer: 610
I used tweezers like these to remove the jet once it was loosened. Inserted the tweezers inside the jet and gently removed it with out it falling off. There was enough spring tension in the tweezer to hold the jet, which also works great to put the jet back in and get it threaded lightly with out cross threading.
I think I got a pack of tweezers from Harbor freight for under 6 bucks.
And if you dont have access to a guitar string, you can strip some 10/12 gauge wire and use one of the strands to clean out the jet.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 02-22-2013, 06:16 PM   #248
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,850
the tools that i use to remove the jet all out cleaned jet with compressed air & back together in 15min
(vice grips i use with the allen key to get more leverage to crack the seal on the plug need a bit of copper pipe or something to slip over the short end of the allen key then i can do away with the vice grips)
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 02-22-2013 at 06:23 PM
veetwo _tls is offline   Reply With Quote
Old 02-23-2013, 06:17 AM   #249
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
The jet shown above is a standard Fuel Jet designs and was used in earlier models. It can work, but I don't recommend these or run them anymore in my bikes. Too much hassle, unless you Enjoy cleaning this jet often.
Volcano is better as is offers some protection of the hole getting plugged instead of forcing everything down and into the center. We offer the Volcano design in stock and modified .5mm sizes as this is the current design used on All Newer KTMs. I have found the Volcano design to get plugged much less than the older version in the last few seasons of riding. I would have to inspect and clean the standard version 2-3 times a year, never knowing when it might happen. Seeing the lack of oil on the clear clutch cover was the easiest way to catch it and prevent any damage or over heating of the clutch system. With the new version I traveled all last season and never had an issues. I checked it this fall and it was still unplugged, but there was a very small amount of debris caught along the lower rim. So it looked as if it was doing it's job.
Ready for another season!
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 03-23-2013, 07:46 PM   #250
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,563
OK. '07 -990
I purchase a new CJ Design .5mm jet, and the stock KTM toolkit flatblade screwdriver fits nice and tight/snug into the slot.
I slip that very same screwdriver that 1"-ish down the hole and feel for the stock jet slot.
It fits sloppy and loose, and I can't get enough downward pressure on it to break the contact.
All my other flatblade drivers won't fit into that tight spot.
Any suggestions?
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 03-23-2013, 08:03 PM   #251
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,413
Originally Posted by Apple Jam View Post
Any suggestions?
1/4" hex screwdriver bit, hold down with your finger while you turn it with an end wrench.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 03-23-2013, 08:08 PM   #252
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,563
My work van, 20 miles from home, has the right tools in it including a 3" long flat bit.
I even have a two foot long flat driver that my brain says would be PERFECT to give pressure downward as I turn it....
But, alas, I am limited to the little short 3/4" bits at home.....or regular screwdrivers that won't fit right.
It feels overly tight in it's hole, and I can't get a bite on it, it feels sloppy in the slot.
Frick. Down to 32 degrees now. Brr. Time for Whiskey !!
Apple Jam screwed with this post 03-23-2013 at 08:15 PM
Old 03-23-2013, 08:20 PM   #253
MortimerSickle
Semi-Adventurer
Oddometer: 12,413
Are you sure they are to short to reach?
Edit: I just measured one like the one in the pic, and it is 2", so maybe 3/4 would be too short. So, maybe the whiskey is a good idea.
G.H.W.S. 1878-1962
Old 03-23-2013, 09:24 PM   #254
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,563
I did my Google-foo before I posted, and saw that very pic.
My biggest problem is the sloppy feel in the slot, and it's just so over-torqued that I can't get enough downward pressure.
A good night's sleep is probly all it needs.
See y'all in the morning!!
Old 03-23-2013, 09:40 PM   #255
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,026
When you have the jet out, take time to get a screw driver etc that fits nice before putting jet back in. Dont over tighten. It is only brass after all !
rossguzzi is offline   Reply With Quote
Times are GMT -7.   It's 01:03 PM.
