Old 06-21-2012, 03:08 PM   #1
Rockwell OP
Rockwell's Avatar
Oddometer: 663
Removing 990 Adventure Engine
I was looking through the repair manual and it shows a bracket being attached after removing the oil line (see below):
Is this bracket necessary? What is it used for?
not all those who wander are lost | two earthlings ride around the world
Home | Photo Blog | The Route | The Bike | About Us | Participate!
Rockwell is offline   Reply With Quote
Old 06-21-2012, 03:27 PM   #2
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
I used an ATV jack and some pieces of wood. Be careful with the oil lines. I left the oil tank and oil lines connected.
'07 KTM 990 Adventure Long Road to Dug Bar
Nut Clutch is offline   Reply With Quote
Old 06-21-2012, 07:19 PM   #3
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,122
I guess if you are a mechanic at a dealership (mythical...are they really out there??), and you have this hanging on the wall along with all the other special tools the dealer had to buy, well then use it.
Otherwise...yep...you can jack on the engine with a block of wood between the cases and the jack.
2005.5 KTM 950 Adventure
2005 Ducati ST3
Chuckracer is offline   Reply With Quote
Old 06-22-2012, 07:33 AM   #4
Rockwell OP
Rockwell's Avatar
Oddometer: 663
Sounds good. I'll use some pieces of wood. I'd prefer not to disconnect the oil lines, so I'll have to be careful not to damage them.
Old 06-22-2012, 08:53 AM   #5
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Hopefully I won't need that engine-removal bracket anytime soon, but its a cool device that could easily be made with a few scrap pieces of metal that appears to ease the process...
ktm950se
ktm950se is offline   Reply With Quote
Old 06-22-2012, 11:15 PM   #6
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,138
+1 It works very well.
I used a piece of plywood to bridge the gap between the jack's runners.
I don't remember using any blocking to protect the lines, but I may have done so.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 06-22-2012, 11:37 PM   #7
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,275
You don´t need it. grab it
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 06-23-2012, 09:54 AM   #8
MortimerSickle
Semi-Adventurer
Oddometer: 12,138
I figured it would be a little awkward trying to line up the mounting bolts with one hand while balancing the engine in the other hand. But then, I'm kinda skinny.
G.H.W.S. 1878-1962
Old 06-24-2012, 02:48 AM   #9
dmn0507
dmn0507's Avatar
Oddometer: 351
I've used a wood panel and 2 pieces of scrap metal to make an engine stand, it's pretty simple and worked good:
one L shaped piece is bolted to one of the sidestand mounting points, the other bracket is bolted to the front of the engine.
Both are simply screwed to the panel
The pic is big, a bit blurry but gives the idea.
dmn0507 is offline   Reply With Quote
Old 06-24-2012, 12:53 PM   #10
Duckhams
Duckhams's Avatar
Oddometer: 74
Talking Engines crank shaft
Hi 990 guys,
I would like an info on your 990 piston height and crank shaft length if any of you have stripped it down..
I had some experiment i wana try out so I need these measurements.
Hope to hear from any of those who had it done....
thanks
Duckhams screwed with this post 06-25-2012 at 11:46 AM
Duckhams is offline   Reply With Quote
Old 02-23-2013, 10:16 AM   #11
DirtyADV
DirtyADV's Avatar
Oddometer: 2,201
Lifting an old thread about removing an LC8 engine since I have mine out right now cause of an oil leak on the rear cylinder earlier Im looking over the front now!
And an old 80s skateboard to bring it out
Have a better writeup with more pictures on DirtyADV
Also a way to hold the engine on the bench:
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Times are GMT -7.   It's 09:12 AM.
