Old 02-23-2013, 06:58 PM   #74041
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Originally Posted by planemanx15 View Post
Thanks for all the suggestions everybody, I opened everything thing up and found the issue:
The valves were completely fine.
As you can imagine I'm pretty disturbed. Everything ran fine, even on the highway going out to the twistys. On the ride back i assume the rings expanded too much and this happened. As I said in my build thread, I did not measure the end gap. I assume had I done this, I could be riding today.
Dang, I guess I was being optimistic thinking it was a valve. Sorry for your misfortune.
jessepitt is offline   Reply With Quote
Old 02-23-2013, 07:12 PM   #74042
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,166
Originally Posted by Harry94025 View Post
That kind of scoring happens when the oil film fails. Not sure how much engine experience you have, but are the rings positioned correctly? The compression rings are usually directional; they have a top indicated with a dot or other mark. If they were upside down, the blow-by would cause the oil film to fail.
I remember when I did my snowmobile top-end years ago that I posted about, they told me very specifically that the rings went on a certain way and the gap had to face a certain way. I wonder if this step might have been missed in addition to proper gapping?
I'd be tempted to send the cylinder back to Jeff... he's the master of the 790.. I honestly wouldn't want to trust anybody else but him when it comes to determining if the cylinder is still good. Maybe even see if you can pay him a little extra to install and gap the rings for you before shipping the replacement parts out -- assuming they will travel okay like that.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 02-23-2013, 07:29 PM   #74043
planemanx15
planemanx15's Avatar
Oddometer: 1,007
Rob
I did install the rings in the correct direction. They are marked and the directions tell you which way to install them.
Jeff emailed me and offered to hone the cylinder and to purchase a new piston.
I want to personally thank him publicly on here for his generous offer. There aren't many guys like him, thank you so much!
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 02-23-2013, 07:37 PM   #74044
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,166
Awesome! Yep, Jeff's a great guy. It was great the day I got to meet him. He gave me a tour of the shop and everything. Every time I go down there, everybody there is just tops.
So... do we know yet what the problem was? If the rings were put on the right way, was it the gap that was the culprit?
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Old 02-23-2013, 07:52 PM   #74045
planemanx15
Oddometer: 1,007
Rob
My theory is that since I didn't do the ring gaps, they expanded with the heat and pressure and scoured the cylinder and piston. This created some free play and the noise that was heard was the piston not seated properly.
Any other opinions would be appreciated.
Old 02-23-2013, 08:32 PM   #74046
procycle
procycle's Avatar
Oddometer: 2,280
I'm certain the ring gap is the cause of the problem. I just put the top end on the DR900 Stroker Motor and the top ring had about .006" gap before filing.
Performance rings are normally sized to require filing or grinding to give the desired gap. There are lots of variables that prevent the rings from being sized precisely out of the box. The ring manufacturer relies on the engine builder to adjust the gap for his specific setup.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 02-23-2013, 09:08 PM   #74047
doug s.
Oddometer: 1,319
a little ot, but have you had any experience w/totalseal rings? comments?
thanks,
doug s.
ps - about your tag line - do you really think the guy who invented the 1st wheel and the 2nd wheel were different guys?
doug s. is offline   Reply With Quote
Old 02-23-2013, 09:55 PM   #74048
Harry94025
Oddometer: 285
Ok, I can see the ring gap being the issue. The ring gaps are very easy to set. Get a small fine mill file, hold the file tang in a vise, and run the ring gap ends on both sides of the file with light pressure. You're moving the work piece (ring) while the tool is held stationary...
Harry
Harry94025 is offline   Reply With Quote
Old 02-24-2013, 03:43 AM   #74049
Thumper Dan
Oddometer: 325
thanks,
doug s.
Perhaps the first guy liked to ride a unicycle
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 02-24-2013, 08:04 AM   #74050
procycle
procycle's Avatar
Oddometer: 2,280
I have not had any personal experience with Total Seal rings but I did look into them for the 790 kits. They don't offer 'off the shelf' rings in the correct size but there are some for a .002" bigger bore that could probably be used. Total seal rings still have to be gapped before installation. Total Seal calls for a bigger gap spec - .0065" or more per inch of bore. That would be .028" on the 790. The feature that makes them 'gapless' is an insert that fits under the ring that bridges the gap in the main ring.
Old 02-24-2013, 09:27 PM   #74051
Harry94025
Oddometer: 285
Planemanx15,
One last thing... Remember that the metal that used to be part of your piston skirt is now somewhere in the engine. I would check the crank and connecting rod bearings very carefully by rotating them by hand to sense any roughness. Remove the oil filter and cut it apart; hopefully you'll see evidence of the metal trapped there. Drain the oil and see if you see silvery bits of aluminum, then flush things out as best as you can. The oil cooler would also be a good candidate for a flush.
Regards,
Harry
Old 02-24-2013, 09:27 PM   #74052
SkunkWizard
recycle crime scene tape
SkunkWizard's Avatar
Oddometer: 729
Owners Manual
DR 650SE 1st. Generation Owners Manual (1994 printing)
Free!
PM me, pay for postage and it's yours (USA only)
not a shop manual very good condition Owners Manual
1st person to contact me gets it
~DR 650~
Upgrades:
1. dented tank
SkunkWizard is offline   Reply With Quote
Old 02-24-2013, 09:34 PM   #74053
planemanx15
Oddometer: 1,007
Planemanx15,
Regards,
Harry
Thanks for the advice, ill be sure to do this.
Old 02-24-2013, 10:37 PM   #74054
Garak
Cardassian Spy
Garak's Avatar
Oddometer: 266
I haven't had time to keep up with this thread lately, but that got my attention! Can't wait to see how it plays out Jeff!
Across the country on the kindness of strangers and the strangeness of friends (and a DR650).
My LinkedIn Profile
Garak is offline   Reply With Quote
Old 02-25-2013, 02:59 AM   #74055
Load Clear
Oddometer: 35
High Elevation
Hey All - First, I'd like to say thanks for all the advice and info I've gotten and read here. The best advice I've gotten is a) Buy the DR650 & b) put down the tools and walk away
I am looking for some more. I will be moving back to Very Northern AZ in the summer. I bought my bike here in NY at about 300ft. I will be living closer to 6,000 and riding up to around 10,000+ in Colorado/Utah.
Do I need to change anything on the bike for the altitude? Sand storms are routine; as is heavy wet clay. Anything necessary to protect the motor and whatever else may be harmed by the sand and clay?
I have a 2012, completely stock.
Next week I am going to start asking about farkling it out.
Load Clear is offline   Reply With Quote
Times are GMT -7.   It's 01:01 AM.
