Old 02-24-2013, 05:27 AM   #7006
elsalvadorklr
Oddometer: 3,964
captain do you have a pic of your headers from the front? my left pipe looks nothing like yours, its has a flat bend to it at the bottom...yours are very close and neat looking..
ps. your 88 should NOT vibrate...are lugging it too much? maybe go up the rev range more and report back
ever since putting back tthe twin headers and oem muffler the bike is even more smooth as there is not extreme thumping like before...
exhausts make a big difference in perceived thumpiness if you will
If I lug my xr really low it will rattle and shake
but never at the bars, so thats worrisome you have that...I get it in the frame and foopegs but never enough to NUMB me.
also our 88 bikes are nice with vibes because they have a twin gear balancer shaft...that is spring loaded unlike otheryear xr6...this is to help with the slamming effect of the crank when accelerating hard or downshifting...
other year xrs have a nice whine to them and slappiness if you will until warmed up because of this(different cam chain as well on 86 and down models, they were bigger)
anywhoo
hope you get it sorted
nice 88 btw! once again
elsalvadorklr is offline   Reply With Quote
Old 02-24-2013, 05:34 AM   #7007
Royal Club
Royal Club's Avatar
Oddometer: 300
I has a thinner camchain and the works in mn 87 xr6
Royal Club is offline   Reply With Quote
Old 02-24-2013, 06:23 AM   #7008
joexr
joexr's Avatar
Oddometer: 763
anywhoo
The split gear cut down on the gear noise. Some people remove the springloaded half of the gear to reduce rotational mass , if not the whole counterbalancer.
joexr is online now   Reply With Quote
Old 02-24-2013, 07:30 AM   #7009
elsalvadorklr
Oddometer: 3,964
I remeber seing pics of twin carb xr6 with thicker sprockets and chain...is this not so?
I thought all single carb heads have a thinner chain up till 2000.
in any case
royal is yours the same as 88 and up bikes? I thought you posted some pics about that
cheers bud
Old 02-24-2013, 10:56 AM   #7010
IronSpadeCycles
Button Pusher
IronSpadeCycles's Avatar
Oddometer: 160
3rd Gear slip? Anyone?
Have any of you guys had any problems with gears slipping on any of the older XR6's? I have an 88 model with a fair bit of work done but the engine has never been apart to my knowledge.
I'm officially the 4th owner but when I went to title and register the bike as a street legal DS bike I tracked it down to the original owner and he explained the bike had been stolen from him back in 1990. He was totally cool and just signed over the old title to me, mostly he was please to finally find out about what happened to his forest friend.
Over the last couple years that I've owned it, I've noticed that occasionally it will slip or feel like teeth are missing in 3rd gear as I'm accelerating hard to 4th gear. I only notice it on the pavement and only if I'm really pushing it, its almost a feeling of very slight wheel spin on loose dirt, then it catches and runs fine. And it only usually happens once while in 3rd going to 4th. I've honestly never tried to just ride it in 3rd to see if I can get it to slip repeatedly either.
I'm a little hesitent to pull the motor and split the cases to find out that nothing is really wrong but I was mostly wondering if this might be a common problem for our big pigs. Anyone else feel this happens to them? I've checked the oil every time I've changed it and nothing metal is showing itself but again, this could have happened years ago with a previous owner.
Thanks for your input. Later Travis
www.theroadmuchlesstraveled.com
____________________________________
I'm a collector of fine crap!
IronSpadeCycles is offline   Reply With Quote
Old 02-24-2013, 12:19 PM   #7011
Royal Club
Royal Club's Avatar
Oddometer: 300
in any case
cheers bud
converted it bro!!!
Old 02-24-2013, 01:24 PM   #7012
brucifer
brucifer's Avatar
Oddometer: 1,627
Evidently some of the '80s XR600s did have problems with 3rd gear. What you're describing sounds like the gear isn't engaging fully into the "dogs" and/or the dogs are rounding off. Or, possibly a bent shift fork which would also cause that to happen. Regardless, you're going to have to pull it apart and repair it. It will only get worse if you don't.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F
brucifer is online now   Reply With Quote
Old 02-24-2013, 01:35 PM   #7013
IronSpadeCycles
Button Pusher
Oddometer: 160
Thanks a lot for the explanation. That makes perfect sense.
Old 02-24-2013, 02:31 PM   #7014
duxrneet
duxrneet's Avatar
Oddometer: 592
I had a similar issue - it was just old saggy clutch springs. Put in some new EBC units and the clutch stopped slipping. So before you start digging that deep into the tranny, pick up some $15 springs and give it a whirl.
"Pay no attention to that man behind the curtain!"
Current: 1987 CBR600, 1995 XR600R - Past: 1993 DR350 (Dirt Model)
duxrneet is offline   Reply With Quote
Old 02-24-2013, 02:47 PM   #7015
nikolic
Oddometer: 413
good luck man...any tips on racing the xr welcome here! jajaja
Hoped I can get some too Still works in progres, have'nt tried a tm40 yet
but tought someone could advise me what jets should I cary with me. Tought of bringing a few pilots, think everything else I can tune...
works so far...
Home rides ;)
nikolic is offline   Reply With Quote
Old 02-25-2013, 12:31 AM   #7016
HeadTrauma
¯\_(ツ)_/¯
HeadTrauma's Avatar
Oddometer: 1,246
If the gear dogs themselves were slipping out of engagement and then back, it would make a horrible noise. It sounds to me like your clutch is slipping and/or the clutch basket is becoming grooved to the point that is affects engagement. I take it you use the clutch for these gear changes when it slips?
1995 XR628R -Lots of goodies...room for more.
Drinking: Funky Cold Medina.
HeadTrauma is offline   Reply With Quote
Old 02-25-2013, 05:01 AM   #7017
deejay_xr
deejay_xr's Avatar
Oddometer: 471
Originally Posted by headtrauma View Post
if the gear dogs themselves were slipping out of engagement and then back, it would make a horrible noise. It sounds to me like your clutch is slipping and/or the clutch basket is becoming grooved to the point that is affects engagement. I take it you use the clutch for these gear changes when it slips?
+1
'87 XR600R, 17's and fully black
deejay_xr is online now   Reply With Quote
Old 02-25-2013, 06:19 AM   #7018
brucifer
brucifer's Avatar
Oddometer: 1,627
Well, it could be his clutch, but why would it only do it from 3rd to 4th shift? Seems like it would then do it from 4th to 5th change badly. I had an '82 XR500 years ago that would slip in and out of 2nd and it didn't make a horrible noise doing it.
Old 02-25-2013, 06:27 AM   #7019
elsalvadorklr
Oddometer: 3,964
word
check clutch first...measure springs, and discs and fibers and file the grooves if any on both the inner and oute basket...
youll be very pissed if you tear down the whole engine only to find you have the exact same issue...not to mention you will have the awesome conundrum of wether you want to replate or rebore and sleeve the cylinder etc since you have an awesome 88 engine
I just changed my clutch, everything was still in spec but visually I had some browning on the fibers and I also had zddp residue...
btw I slipped in 4th and or 5th at wot...this is becaise its harder on the engine to pull such a tall gear
good luck
Old 02-25-2013, 06:31 AM   #7020
elsalvadorklr
Oddometer: 3,964
I read somewhere that people also were having issues with that stupid little spring on the gear shuft spindle not being strong enough or something causing a bad shift or non shift
could be any of these things at this point but I would start with the easiest stuff
I say this becaue Im so paranoid the first that always comes to mind is the WORST and usually thats when steve comes in and shuts me up and says hey its this simple thing
fix it and ride and well he is always right jajajajajajaja!
Times are GMT -7.   It's 12:14 PM.
