Old 02-23-2013, 12:05 PM   #1
gmtcm OP
KTM RIDER
Oddometer: 316
950 se valve adjustment
I am about to check the valve clearance on my 08 950 SE. Is there a bolt with a thick washer (removed) will go into the crank shaft like on the 525, that will allign the piston with top dead center? If yes, where is it located?
Thanks - gmtcm
Stand Behind Our Troops or Feel Free to Stand in Front of Them.
gmtcm is offline   Reply With Quote
Old 02-23-2013, 12:16 PM   #2
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,734
Its been awhile, but if I remember correctly, it's the large head bolt horizontally inline with KTM the stamp. Forward of it. See that larger head ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 02-23-2013, 02:34 PM   #3
Hootowl
Oddometer: 1,262
The bolt has a copper washer under the head.
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 02-23-2013, 02:36 PM   #4
gmtcm OP
KTM RIDER
Oddometer: 316
Thanks for your reply. I pulled that long 8 mm bolt out and then tried to stick a longer piece of welding rod into the hole to see if it bottomed out a little further in. It kept going on through a long ways into the crankcase , so I'm wondering if that's the right place?
Thanks - gmtcm
Old 02-23-2013, 02:38 PM   #5
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
You must not be a TDC and missed the crank.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 02-23-2013, 02:49 PM   #6
gmtcm OP
KTM RIDER
Oddometer: 316
The copper washer on the bolt is very thin and doesn't seem like removing it and running the bolt in would be enough to penetrate and lock the flywheel?
Old 02-23-2013, 03:00 PM   #7
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 953
Bolt
You remove that bolt and use the special bolt ( slightly longer with a taper end) CJ sells them or you can make your own. Must be inserted at top dead center for each cylinder. If I remember right
dogsslober is offline   Reply With Quote
Old 02-23-2013, 03:05 PM   #8
dogsslober
dogsslober's Avatar
Oddometer: 953
Go here
http://www.ktm950.info/ Look for valve adjustment
Old 02-24-2013, 02:18 AM   #9
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 02-24-2013, 06:00 AM   #10
gmtcm OP
KTM RIDER
Oddometer: 316
Thanks for all the help. My friend has the thr longer tapered bolt.
gmtcm
Times are GMT -7.   It's 12:27 PM.
